Old 11-24-2012, 07:47 PM   #15
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Thanks Jordan!
Old 11-24-2012, 08:08 PM   #16
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
I have them with the new 2012 zl1 spec sways I bought.Not problem putting on and setting. Work great and no noise at all.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 11-25-2012, 04:12 PM   #17
SSSoon
SSSoon's Avatar
Drives: RY 2011 2SS A6
Guess what?
Maybe it's not the end links. I was under the back having a look around at the sway bar, and lookee here... cracked bushing on the sway bar mount. I wonder if that might be what is making my clunking noises.
Dry sump LS7, cage, JPSS suspension, Wilwood brakes, fire suppression, ARH 3" headers/exhaust, Z/28 DSSV coilovers, Kirkey seats, TeamTech 6-point harnesses, 19" Forgeline GA3R, 325/30R19 Re11 tires, oil cooler, monster JPSS splitter/wickerbill, CAI, brake ducts.
SSSoon is offline   Reply With Quote
Old 11-25-2012, 06:53 PM   #18
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
Originally Posted by Ventmaster View Post
Thanks Jordan!
No problem! Please feel free to call, email or PM me anytime with questions.
That split is cut in the bushing so it can be installed on the sway bar.. If that isn't bolted to the sub frame that would be your issue.
In all seriousness I would go back through everything and make sure everything is tight. I would use blue or red loctite on the bushing brackets as well.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 11-25-2012, 07:11 PM   #19
SSSoon
SSSoon's Avatar
Kind regards,
Jordan Priestley
888.308.6007
Well that clears that up - thanks Jordan. Didn't see the split on the other side but I am sure you're right and it's there too, just hidden.
Don't know what to do - I already had everything tight as it could be. I'm back to square one.
Do these need some kind of lubrication perhaps inside the bushing?
Old 11-25-2012, 08:21 PM   #20
SSSoon
SSSoon's Avatar
Yeah, looks like I have the same end link versions as you are selling now Jordan:
Old 11-26-2012, 11:32 AM   #21
Ventmaster
Ventmaster's Avatar
Just asking to be sure- but I'm guessing you loosened the locking nuts while removing those endlinks.
Usually when set up for use, the ends are oriented about a 1/4 turn away from each other and locked in place. If the ends are able to rotate, it could be causing your noise.
Old 11-26-2012, 11:43 AM   #22
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
Is that just road grime or rust? I live in Chicago where they salt the roads like its going out of style so I hope that they are resistant to oxidizing.
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
JHall651 is offline   Reply With Quote
Old 11-27-2012, 02:30 PM   #23
JHall651
JHall651's Avatar
Bump???
Old 11-27-2012, 02:32 PM   #24
SSSoon
SSSoon's Avatar
Pretty sure it's just lubricant plus dirt. Will let you know for sure tonight.
Old 11-27-2012, 08:39 PM   #25
SSSoon
SSSoon's Avatar
Yup. Cleans up fine. No rust.
Old 11-27-2012, 08:57 PM   #26
JHall651
JHall651's Avatar
Shhhhhoooo. Scared me for a sec. I just ordered the Pfadt Stage 4 Package and was. Little worried as this is going on my daily driver in Chicago. On a side note you mentioned it was lubricant. You lube those? Are you suppose too?
Old 01-06-2013, 07:31 AM   #27
SSSoon
SSSoon's Avatar
Problem solved
I took my end links off and sent them back to Pfadt, who found some play in the bronze lower rod end and in one of the upper rod ends. They sent them back with these parts replaced and I put 'em back on yesterday. Super quiet. Problem solved.
Great customer service!
Old 01-07-2013, 02:04 PM   #28
JDP Motorsports
Kind regards,
Jordan Priestley
888.308.6007
Pfadt Stage 2 Performance Handling Package Is Now $600 Shipped At APEX Motorsports!! Apex Motorsports Suspension / Chassis / Brakes 167 08-09-2012 06:05 PM
Camaro5Fest III location nomination Atti2de 2012 Camaro5 Fest (III) 2717 05-31-2012 12:59 AM
HOW TO: Get rid of UNDERSTEER on C5 member Buffnshine's Camaro PfadtRacing Suspension / Chassis / Brakes 6 08-31-2011 10:51 AM
Pfadt end links popping? Berean Suspension / Brakes / Chassis 12 09-03-2010 01:58 PM
2010 CAMARO HEAVY DUTY END LINKS Hotchkis Suspension / Chassis / Brakes 0 04-14-2010 06:47 PM
