Old 09-07-2011, 02:40 PM   #1
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
need advice
ok here is the scene. camaro twin turbo..with lsr sways, and bmr rear diff bushings..also bmr midbody brace and tunnel brace, bmr trailing arms, and all the rest stock... 607 rwhp...i have 20 in rims with the rear pirellis out front and 315/40 rears....to me the car feel so loose...much more then with the stock rims...i am confused...can some please tell e what to do to get a better planted feeling...or lead me in the right direction.
ipimpthisc is offline   Reply With Quote
Old 09-07-2011, 02:44 PM   #2
ipimpthisc
Banned
i hope the tuners like justice pete, apex chase, lsr , bmr and the like jump in..i have little confidence when cornering ...even during hard launches...not the drag race type..but the mash full throttle at 45 mph types
Old 09-07-2011, 02:48 PM   #3
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
The 315s you installed highlight a foundational weakness is the 5th Gen from the factory -- Rear End Step Out. This is common to vehicles with the IRS mounted to the monocoque through Noise Vibration and Harshness (NVH) voided rubber bushes. Under load (acceleration, deceleration, launch, cornering, traversing bumps or basically driving) the sub-frame twists within the rubber bushes. These twists, these shifts are continuous creating changes in the alignment. Keep in mind that alignment is not static. It changes constantly as you drive. These shifts cause the rear end to feel loose.
The fix is simple. Upgrade your sub-frame bushes and make sure we have a good alignment.
Old 09-07-2011, 02:55 PM   #4
ipimpthisc
Banned
thanks pete...well i have the bmr rear sub frames on...i have to do the fronts..what are your recommendations...as i know u know ur stuff and fully respect your expertise...and thank you much....btw u explained it perfectly...it feels like i am on a banana peel...the slightest turn on a highway makes my car feel unstable....scary really
Old 09-07-2011, 03:00 PM   #5
ipimpthisc
Banned
i though stock height played a part but look here against this stock car
Old 09-07-2011, 03:13 PM   #6
JusticePete
VIR Specialist
You already have BMR sub-frame bushes or sub-frame connectors?
Old 09-07-2011, 03:14 PM   #7
ipimpthisc
Banned
i have the rear differental subframes bushings, and the subframe connectors, tunnel brace and bmr trl arms.
Old 09-07-2011, 03:23 PM   #8
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
When you say the car feels loose, what do you mean? Does the car feel unsettled during acceleration? Braking? Cornering?
If the car feels poorly all around I would look at your alignment first. Is this the first time you've taken the car back on the road since this last round of suspension mods? Was the alignment checked after installing the suspension parts?
A little more info will go a long way to diagnosing what's going on.
Old 09-07-2011, 03:28 PM   #9
2quick
Drives: none
What are your alignment spec's? Is something perhaps loose? Did it happen after an install of an item or after you had the same setup. Not sure I'm understanding this. Did it start right after the tires were put on? Need to remember that there is such a thing of to wide of a tire for a rim. I may fit but that doesn't really mean it will perform better.
2quick is offline   Reply With Quote
Old 09-07-2011, 03:36 PM   #10
JusticePete
VIR Specialist
Cool. That bring us back to sub-frame bushes.
Old 09-07-2011, 03:55 PM   #11
caverman
caverman's Avatar
Drives: '69 SS Convertible
From reading what you posted I think what Pete is recommending (I think most other vendors will to) is that you need to replace your sub-frame (aka: cradle) bushings.
With the HP you're probably talking about you should go to the full bushing and not just the bushing insert.
I don't have near the HP you're talking about and I put in just the cradle inserts. I could feel the firmness immediately. I felt it way more than even the Hotchkis Chasiss brace that I added.
There are several brands to choose from Pfadt, Whiteline, BMR, Energy.....but I'm partial to Pedders. Do some searching on cradle bushing inserts and then pick the Mfg you feel is the best for you.
Build Journal
Old 09-08-2011, 12:50 AM   #12
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
It could be multiple issues but the cheapest place to start is with an alignment. I would suggest going with -.2 to -.4 degrees rear camber and zero toe; for the front I would go with -.5 to -.8 degrees of camber and -1/16 toe in. This is a great street/strip alignment.
With the HP you're making I would also strongly suggest going with a good sub-frame bushing replacement. We offer the Pedders bushings as well as the Pfadt mounts. They are both excellent products and they will keep the sub-frame where is is supposed to be.
I would also suggest coilovers with that kind of power; the increased spring rate would make it feel much more planted. Please feel free to call, email or PM me anytime with questions. I'm always happy to answer question and find the right solutions to obtain your goals.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 09-08-2011, 02:52 PM   #13
ipimpthisc
Banned
thank you all gentlemen for the the replies and expert opinions..truth be told the car ran excellent before the new rims and sub frames bushing...THE car has all the rear full sub frame bushings... i will do toe link replacement and full alignment...I think its the alignment at this point, and that combined with so much power doesnt help...Question i also think the shake of the engine due to power shift is making my car veer side ways..what do u all think? ...thanks again guys
Old 09-08-2011, 02:54 PM   #14
ipimpthisc
Banned
I want to thank LSR and JUSTICE PETE personally for their calling me and sit downs over my issues, and i really thank all the rest of the family for taking so much time to entertain my issue...I have a deep respect for you all
College Kid Needs Some Advice :help: iRock4Christ Camaro Price | Ordering | Tracking | Dealers Discussions 6 07-01-2011 02:45 PM
Need advice on a cold air intake system central99 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 07-22-2010 05:33 PM
Need some advice, please. X-Z01 5th Gen Camaro SS LS LT General Discussions 0 04-28-2010 11:58 AM
I need some advice on the color selection here. 13F20 5th Gen Camaro SS LS LT General Discussions 33 02-14-2010 05:31 AM
Need Advice - 2SS vs. 2LT RugbyJimmy 5th Gen Camaro SS LS LT General Discussions 17 07-19-2009 08:13 PM
