Emblempros
Old 09-07-2011, 07:27 PM   #1
Wiess
4th gen punk!
Wiess's Avatar
Drives: 94 Camaro Z-28
LT1 to LS1 swap
Yo I really want to replace the tired LT1 engine in my 94 Z28. I'd like some tips or hints that would help with my swap
Wiess is offline   Reply With Quote
Old 09-07-2011, 08:49 PM   #2
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
To my knowledge it should be a pretty easy swap. But you'll def need a new wiring harness for the ECM.
Old 09-07-2011, 09:19 PM   #3
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Hell, aside from the added emissions things post 1994 I'd imagine just find a rear ended LS car and clean out the engine bay of everything that isn't part of the body or holds the engine in place. IIRC the body didn't change much if at all when they went to the LS1 so just finding an LS car and adding all the extras to make that LS engine work in said LS car..
Badabing, you've got an LS engine'd Camaro.
Easier to drop the car on the engine/K member though, so keep that in mind also look for a combo of trans and engine and stay away from TC/ASR BS. LS1tech and LS1.com are your friend too.
Spike.. anything to add oh Jalopy Jedi?
Zabo is offline   Reply With Quote
Old 09-08-2011, 09:56 AM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
of course.
the hood will need to be changed as the LS1 sits higher and the Radiator will need to sit more upright to not come in contact with the engine, not to mention, you will need either a different radiator (LT1's are reverse flow cooled) or a custom plumbing setup for the stock radiator. also, you have a 94 camaro which is an OBDI system, you'll need to convert your data connector over to OBDII. Transmissions wont transfer, Kmember wont match up, all your engine accessories, plus all the little stuff like AC, sensors, etc.
an overview of major items you'll need
-Engine
-Tranny
-K-member
-Wiring harness (sparco does a conversion with the stock LT1 harness)
-Computer & tuning
-Front Accessories
-Steering rack & pinion with steering shaft
-New Fuel pump(LS1-58psi vs LT1-42psi), regulator, and lines (LS1 is a returnless system)
if you truly want to do it, find a donor car that is rear ended and take your time.
IMVHO, save the time and money and have your LT1 freshened up and mod it out. get it stroked, poked and cammed and have more power than the LS1 without breaking the bank.
or if you are adamant about having an LS1, trade out your 94 for one. or find a rolling chassis that needs a motor and interior and swap your interior to the rolling chassis.
I piss excellence
and fart awesomeness
Old 09-10-2011, 01:04 AM   #5
2SSRSinBama
Drives: 2010 2SS/RS Camaro CGM
the LT1 f-bodies are lighter.. and with the LS1 being all aluminum... even lighter
its not a bad swap with a donor car, i'd say that is a must or you WILL be collecting parts off of one anyway on down the road...
find you a LS1 car that has a side impact(or rear impact if the rear end is still good) and go from there...
there was a '96 Z28 here with a LS1 in it.. only one i've seen IRL(a couple online)... it was definitely different and his job looked pretty sleek
2010 Camaro SS L99... has a few mods
2SSRSinBama is offline   Reply With Quote
Old 09-10-2011, 01:23 AM   #6
Blue17CamaroZL1
650HP soon to come
Blue17CamaroZL1's Avatar
Drives: 2017 Chevy Camaro ZL1
http://stores.ebay.com/Fparts?_rdc=1
This guy has a lot of crashed up Corvettes and Camaros. Lots from LT engines to LS engines
2017 Camaro ZL1
Hyper Blue Metallic
A10, PDR, NAV, Premium floor mats
Blue17CamaroZL1 is offline   Reply With Quote
Old 09-13-2011, 12:48 AM   #7
Wiess
4th gen punk!
Wiess's Avatar
of course.
-Engine
-Tranny
-K-member
-Computer & tuning
-Front Accessories
How much do u think it would run me to boost my LT1 then?
Old 09-13-2011, 07:38 AM   #8
CamaroSpike23
Truth Enforcer
depends on what you want to do. rebuild? stroker? heads/cam? spray?
the LT1 can be built relatively easy to make 400+hp reliably and driveable.
biggest questions are what is your budget and your skill level?
I piss excellence
Old 09-14-2011, 12:19 AM   #9
Wiess
4th gen punk!
Wiess's Avatar
I want a strong reliable LT1 engine.I want it to be healthy and powerful
Old 09-14-2011, 07:48 AM   #10
CamaroSpike23
Truth Enforcer
do you want a N/A engine? super/turbocharged? Nitrous?
I piss excellence
Old 09-14-2011, 08:16 AM   #11
dmginc
dmginc's Avatar
Drives: 14 Camaro 1LS AGM
strong LT1...isnt that an oxymoron?
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 09-16-2011, 07:39 AM   #12
CamaroSpike23
Truth Enforcer
lol...
they are rare, but once you've cracked 10's with the LT1, the LS1 just doesnt seem as appealing anymore
I piss excellence
Old 09-16-2011, 02:59 PM   #13
Nvincent4708
1st State Camaro
Nvincent4708's Avatar
Drives: 2014 1SS M6
not if you do it right. lol
my friend has a 95z pushing 450rwhp
i say that's strong.
Nvincent4708 is offline   Reply With Quote
Old 09-16-2011, 03:20 PM   #14
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
lol...
This is true, I've seen some fast LT1's. They just have less aftermarket support, and I'm just not a fan of the Opti spark system they use.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Stock ls1 vs lt1? 96z 4th Generation Camaros 5 04-30-2011 06:28 PM
lt1 Z28 rear carrier vs ls1 transam rear carier.??? lildj2483 4th Generation Camaros 3 03-16-2010 07:05 PM
LS1 and LT1 Parts for Sale - AZ chellzers V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 7 12-07-2009 10:13 AM
v6 to carb lt1 swap quide outlaw85 4th Generation Camaros 0 03-08-2009 10:58 PM
LS1 VS LT1 devildogcollier 4th Generation Camaros 31 02-27-2009 09:12 PM
