B&M Racing
Old 09-07-2011, 09:37 PM   #1
55Designs
Drives: 2010
Considering switching our Hurst shifter to the MGW, Will it be an obvious change?
I have the first iteration of the HURST shifter which I had the dealer install back in 2009 prior to delivery. Its def cool looking and i like the fact it feels shorter but its still harder to shift no matter what fluid i run in the trans etc.
I am now upping the power on the car alot and will need to row through gears much quicker and am considering doing the shifter when we pull the tranny out for the ZR1 clutch.
Just want to get some feedback for anyone who has switched from HURST to MGW, I am not considering any other shifter but the MGW.
thanks guys.
55Designs is offline   Reply With Quote
Old 09-07-2011, 09:47 PM   #2
shines
Drives: 2010 Camaro SS/RS
MGW will be much tighter and the throw will probably be even a bit shorter than the Hurst. I've only missed 3rd power shifting once, and I do it a bunch!
shines is offline   Reply With Quote
Old 09-07-2011, 09:53 PM   #3
55Designs
Drives: 2010
i guess my complaint is the clunky feel from 1st to 2nd then to 3rd granted the tremec all tend to feel this way but i wanted to know if the MGW will smooth this out at all.
gearboxes in BMW M and Porsche feel amazing i would like to get close to that feel but am not keeping my hopes up
Old 09-07-2011, 11:54 PM   #4
shines
I have the MGW and RPM level 6 TR6060 transmission, it's 10X better than stock.
That said, I doubt it's as good as a $130k Porche.
Old 09-08-2011, 11:53 AM   #5
MGW
Drives: 2010 CAMARO SS
just to clarify...
the aftermarket hurst i believe is a 40-44 percent reduction and i'm sure a rep from hurst can give exact.
our shifter is a 30 percent reduction so it will be longer throw but smoother and less notchy.
remember the shifters are NOT notchy the tranny is!!!
Hurst also makes a factory option which i believe is 20-25 so thats also an option.
other features that we have in our shifter that no one else offers is the added spring back to the 3-4 gate for flawless 2-3 shifting and more precise gear definition.
george
MGW is offline   Reply With Quote
Old 09-08-2011, 03:18 PM   #6
55Designs
Drives: 2010
Originally Posted by MGW View Post
just to clarify...
george
I agree i never felt a Tremec equipped car feel silky smooth but any improvement will help. George is it the rod that connects the shifter to the tranny the main cause of the notchy feeling?
TAG's 2010 THRSS #2 TAG UR IT Member Car Journals 3129 08-14-2014 10:29 AM
GM Factory Hurst Shifter GPC1 Transmission / Driveline 10 06-10-2011 06:44 PM
Hurst Shifters from GmPartsDirect.com GmPartsDirect.com Transmission / Driveline 0 01-24-2011 05:41 PM
Comments on my Hurst Throw Shifter Blueclyde V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 03-19-2010 05:46 PM
Hurst shifter questions caverman V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 12 02-04-2010 01:16 PM
