Solo Performance
Old 09-07-2011, 10:21 PM   #1
billjw
Drives: 2013 ZL1 Black
will the new upgraded suspension parts fit on a 2012 convertible?
I would love to know if this would be an inexpensive suspension upgrade or if it is not worth it.
billjw is offline   Reply With Quote
Old 09-08-2011, 08:19 PM   #2
billjw
i presume no one else knows either hmmmm
I was hoping someone on here would know.:(
Old 09-08-2011, 08:55 PM   #3
garcmol
garcmol's Avatar
What upgraded pieces are you talking about? 2012s have a different sway bar altogether. However, from what I've seen under the 2012s, the Lower Control Arm tabs are there for the endlinks on the 10s and 11s. So I would assume you could () bolt up a 10 or 11 model aftermarket bar and endlinks.
I believe the 12s are dubbed the FE4 suspension in the SS. Don't know what the aftermarket world has planned, but it will come!!!
Old 09-08-2011, 09:03 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
I don't actually know if the parts are interchangeable, but my question is why? Like why buy 2012 parts when you could just get aftermarket pieces for the same price?
Click to view my build thread
Old 09-08-2011, 09:10 PM   #5
garcmol
garcmol's Avatar
I think he's getting a 2012 convertible and wants to upgrade the suspension on it. I don't know of upgrades yet, but they will come.
And the 2012s rear sway bar mount points to the rear cradle are the same. The LCAs also have the tabs for endlinks like on the 10s and 11s
Old 09-08-2011, 09:59 PM   #6
billjw
I have a convertible and of course GM only put the new suspension on the coupe.
Old 09-09-2011, 06:45 AM   #7
garcmol
garcmol's Avatar
Ah, I didn't know they were doing it that way. Well, then I would assume it's the same sway bar that's on the 10s and 11s. If that's the case, then there are a plethora of aftermarket options available Check with some of the suspension vendors/manufacturers that are on the boards, they'll get you in the right direction.
I can't remember where the thread is, but one shop guy had a 2012 in and put up pics of the new rear sway bar. The LCA looked the same and had the tabs, but the sway bar attached outboard of the shocks. You would have to mod (or get 2012) LCAs in order to connect the sway bar to it. And I don't know if there is an aftermarket option available yet for the FE4 swaybar.
Old 09-09-2011, 08:00 AM   #8
2quick
Drives: none
Here are some pictures.
http://www.camaro5.com/forums/showth...&highlight=lsr
BTW we are already working on upgrades. They are in the testing R & D stage.
We have had the CAD file for some time now.
2quick is offline   Reply With Quote
2012 FE4 suspension 1st glance R6P Suspension / Brakes / Chassis 151 08-17-2011 07:54 PM
WILL MY 2010 COUPE FACTORY COVER FIT 2012 CONVERTIBLE? BLACKCAMARO2SS Camaro Convertible Forum 3 07-17-2011 08:39 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 02:51 AM
