Caryle Racing
Old 09-08-2011, 01:15 PM   #1
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
Torq 675HP S/C Upgrade Kit
We take all of the guess work out of making power by providing you our street, track and road course proven packages. This 675HP package has gains of over 200HP over stock almost and a 2 second reduction in 1/4 mile times.
The new 2010 Whipple Supercharger Camaro system boasts the largest positive displacement supercharger currently available, the massive 2.9 liter W175AX. The new system utilizes the new Force Fed front feed inlet system for maximum airflow and maximum performance. With the industries biggest twin-screw superchargers, Whipple has also incorporated the biggest aluminum air-to-water intercooler for any of the LS series engines to make more power than any other positive displacement supercharger on the market. All while fitting nicely under the stock hood with zero modifications.
Our MSD Fuel Pump Booster comes 100% complete as a plug and play kit with our OEM style plug and play wiring harness, pre-programmed for operation. It hooks up to the Whipple lower intake manifold and comes with a beautiful laser cut mounting bracket to attach to the battery for a factory installation.
The Siemens fuel injectors are OEM quality and meet OEM standards. We do not use modified or drilled injectors.. The MSD fuel pump booster kit is the highest quality kit available on the market.
675HP Package Contents**:
Whipple Supercharger w/ 4.25" Pulley for 9psi
Siemens 60lb/hr Fuel Injector
MSD Fuel Pump Voltage Booster
Roto-Fab Cold Air Intake
Kooks 1 7/8" Long Tube Headers w/ Cats (comes with additional 02 sensor bung for wideband air-fuel sensor)
OEM HEADER GASKETS
Torq Custom Tuned SCT Handheld Programmer
NGK TR6 Spark Plugs (pre-gapped)
**L99 Automatic Kit is 600-625HP
Installation is available at our Miramar, FL location. We can facilitate shipping of your vehicle.
Meister@Torq is offline   Reply With Quote
Old 09-08-2011, 01:46 PM   #2
Synner
Drives: not stock
For customers with an existing cam upgrade would you be able to provide a tune for that if someone bought a whipple and probably the LPE pump instead of a BAP? Also would the 60lb injectors be enough or would an 85lb be necessary for roughly 630rwhp on a stock internal LS3?
Old 09-08-2011, 02:12 PM   #3
Meister@Torq
We are making 650RWHP on our MD with the 60lb injectors without breaking a sweat but anything above 615rwhp will require the ADM or LPE dual fuel pump upgrade kit. We can provide a tune that would work perfect. We have additions/subtractions from our kits to suit your needs or Check out our 750HP Kit that is guaranteed to make the power you want with tuning
http://www.camaro5.com/forums/showth...49#post3728449
Old 09-08-2011, 02:47 PM   #4
Meister@Torq
You will also notice we are making over 570RWHP at 7000rpm and this bad boy is still climbing and not even starting to crest over. I would bet it should make 590+RWHP at 7300 RPM and I am confident in the stock engine and our valvesprings upgrade kit to spin it there (not forever) but it really shows the potential of this package....would work amazing on a built engine as well.
Old 09-08-2011, 07:28 PM   #5
Meister@Torq
PM for pricing
camaro, kooks, torq, whipple
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
92206992 - GMPP 2010 Camaro (SS) L3 & L99 V-8 Exhaust Upgrade Kit, Round Tip mlamb Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 39 11-14-2010 04:46 AM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
GM perfomance exhaust upgrade kit ? Hawks Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 06-06-2009 01:23 PM
