GM Parts House
Old 09-08-2011, 02:23 PM   #1
johnaka1stunna
Drives: RS 2010
brake calipers on 2010 camaro?
I have 22k miles on my 2010 camaro.. and the brakes were grinding. so i took it in to a brake shop and they said my pads were worn down.. they also said that my calipers were aluminum and i should replace them because the aluminum ones wear down the pads faster. is there any truth to this.. and has anyone else had their breaks grinding at only 20k miles?
thanks
go easy on me please!
johnaka1stunna is offline   Reply With Quote
Old 09-08-2011, 02:33 PM   #2
MasterZ
MasterZ's Avatar
Drives: 2010 Camaro SS/RS
Sounds like they r trying to pull one over on you. The calipers shouldn't need replacing.
As far as pads go, depending on you driving style is when they r gonna need replacing.
2014 C7 Z51~ M7 custom paint,
Mods soon to come, researching at the moment.
MasterZ is offline   Reply With Quote
Old 09-08-2011, 02:33 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
20k is a bit soon, but how aggressive do you drive? Are you one to slam on the brakes more often then coasting and then gently braking?
Performance brake pads wear down quicker than regular pads. So that's no something unusual or new. I've never heard the comment about aluminum calipers though. Seems a bit shady to me
Click to view my build thread
Old 09-08-2011, 02:35 PM   #4
MUSCLEIT
MUSCLEIT's Avatar
Drives: 2010 REDLINE EDITION#46
Brake pads yes... cal NO....................
REDLINE MOTORSPORTS EDITIONMOTORSPORTS
MUSCLEIT is offline   Reply With Quote
Old 09-08-2011, 02:36 PM   #5
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
I have 80K miles on my car and the pads are fine.
It sounds like your shop is low on work.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 09-08-2011, 03:11 PM   #6
Russell James
Russell James's Avatar
Drives: '69 Drag, #37 TA Stock Car, '15 ILE
If they were grinding, I'd wonder more about the condition of your rotors than the calipers. Calipers should last the life of the car, normally.
Old 09-08-2011, 03:22 PM   #7
RubyCamaro
Jan
RubyCamaro's Avatar
I have over 25K on my 2010 so.............
Old 09-08-2011, 03:26 PM   #8
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
Strongly agree here. This is why I only go to the Chevy dealer (Impala and Camaro) or reputable speed shop (Camaro).
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers with Trunion Bearing, ATI Balancer/keyed, AR Headers/Borla Catback Exhaust, DSS 1400 HP Axles, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)with Hidden Lightweight Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 09-08-2011, 03:42 PM   #9
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
thanks
Were they actually grinding or just squealing? Grinding would normally mean the wear indicators were rubbing the rotors signaling "time for new brakes". Grinding from wear indicators would happen at all speeds every time you apply the brakes.
A high pitched squeal is just a vibration - annoying but not really a problem. Brake squeal is often intermittent and usually occurs at low speeds.
It is possible (albeit unlikely) that you need new pads, but the caliper material doesn't affect brake wear since the pads only wear against the rotors.
I'm guessing that you were quoted a pretty high number for the repairs. I suggest you get a 2nd opinion before doing anything.
Old 09-09-2011, 04:03 PM   #10
madmaxx18
madmaxx18's Avatar
Drives: 07_tundra/08_zo6
I would pull the pads myself and regrease the bolts and stuff. My jeeps brakes where squeeling for awhile until I regreased everything. If you live close enough I'll help you out. No one should have to pay to have brakes done they are way to easy to work on.
madmaxx18 is offline   Reply With Quote
Old 09-10-2011, 08:02 AM   #11
2quick
Drives: none
um your calipers should not need replacing. If they do then i would tell them it should be under a factory warranty because of the low miles.
2quick is offline   Reply With Quote
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 10:10 AM
CAMARO WIKI Tran Wiki 54 02-06-2016 12:33 PM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 01:08 PM
