Old 09-08-2011, 09:41 PM   #1
rrtree
Drives: '11 2lt
turbo?
what turbo are you guys running with the sts kit and/or what size turbo is recommended for a single setup and what size are you running gretchin or tracy n your twin setup im tring to figure what direction to go ?
i have the chance to get a ball bearing t4 with 67 trim (i think, waiting for more info on it) brand new for a steal that a buddy got for his car but he sold the car before upgrading his setup would it work for the llt????????
rrtree is offline   Reply With Quote
Old 09-08-2011, 11:22 PM   #2
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
The sts kit uses a 60-1 with an e compressor housing I believe and a t4 ptrim turbine not sure of the turbine housing size. I run a precision pt6765 journal bearing with an s housing and ptrim turbine with .68ar housing. The 67mm spools just a tad slower than the my old T60 but makes more power and still very daily driveable. Our cars move a lot of air so we can spool the bigger turbos, ask tracy or gretchen for more info. Let us know the specs of the turbo when you get them!
(Sold Sept 2015) Stock 18" Heritage w/ BFG G-Force ZR tires / Blacked out bowties and tail lights / DIY Remote-Mount Turbo Kit (Precision 6776S .81ar ex. @ 6.5psi, Tial 38mm WG, Greddy Type-S BOV) / RX Catch Can / RX-FTI 3600 Stall / Blue Well Lights / Team LLT
Pt_killa is offline   Reply With Quote
Old 09-09-2011, 08:19 AM   #3
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
A 67 mm would be fine. Do like PT did and keep the AR at a moderate to large size to help with charge temps. They do move a suprising amount of air for a 3.6 L, so you can spool a fairly large turbo. Don't go to small because you will get a hotter charge and start impacting you MPG. Also, if you have a A6 you will be putting too much torque on the tranny at low RPMs. I love PTs setup and it is proven (as are the STS setups), but I think you'll be better off with the ball bearing. We've all be struggling with oiling/smoking issues so going with something that requires less OIL is better IMHO.
What ever route you go I think you'll like it. It doesn't take much boost on these cars to get 350 RWHP. That's enough to have fun at the track and you still have a great daily driver.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
Last edited by GretchenGotGrowl; 09-09-2011 at 12:29 PM. Reason: Fixed the bolded word (was smoke)
GretchenGotGrowl is offline   Reply With Quote
Old 09-09-2011, 10:30 AM   #4
mpiper
mpiper's Avatar
Drives: 2011 Black 1LT RS
Can you explain what you mean about smoke? Smoking issues and requiring less smoke?
I'm a non-turbo guy here, so keep the answer in simple terms so I don't have to pull out my "Terms for Dummies" book.
Midnight => 2011 1LT/RS, A6, Roto-Fab CAI & W/W Relocate, MPD Hood, 25%/18% Carbon Tint
See my build journal here.
mpiper is offline   Reply With Quote
Old 09-09-2011, 10:38 AM   #5
GretchenGotGrowl
All turbos require oil. Most car manufactures mount them in the engine bay and gravity helps flow the oil back to the crankcase. The remote mounted systems like PT and I have (as well as STS) are mounted below the crank case. That means we have to pump the oil back to the crankcase. In my case I'm either sending too much to the turbos or not pumping it back fast enough. When the oil builds up in those hot turbos it burns and leads to smoke coming out of the tail pipes. I think PT got his issue resolved. For the most part I've got mine under control but it does smoke a bit a wide-open-throttle. When we do the Tracy does the new torque converter he's going to take them off and replace the seals and mine should be fine.
Old 09-09-2011, 12:03 PM   #6
mpiper
mpiper's Avatar
Ok. Think I got it. So when you suggested rrtree get one that requires less smoke, were you suggesting a larger housing so the oil flows easier?
By the way, I have followed GGG's build, but don't know what PT has, except it was a custom setup. PT, do you have a build thread?
Old 09-09-2011, 12:30 PM   #7
GretchenGotGrowl
Ah, gotcha. Meant OIL not SMOKE. The ball bearing units require less oil than the jounal bearing turbos.
Old 09-09-2011, 03:24 PM   #8
Pt_killa
Pt_killa's Avatar
The gretchen is correct. Ball bearing setups are nice if you can afford! One lazy reason I didn't go ball bearing was because I didn't feel like running water and oil lines to the back of the car.
My master power t60 didn't smoke at all but when I changed to the older precision pt67, I do get some blueish smoke at WOT. I'm not sure if the seal designs are different between the two but the oil inlet is certainly different. The t60 had some type of restrictor flange inside the CHRA for the feed side while the precision is wide open (I use the same 2mm restricted oil feed flange however).
I kinda have a build page but its not up to date and not as comprehensive as the others. I want to do a few more things to my car before I provide another real update.
http://www.camaro5.com/forums/showthread.php?t=143029
Old 09-09-2011, 07:06 PM   #9
rrtree
Drives: '11 2lt
my buddy dropped of the turbo to me so i can take it to tracy and have him look at it i dont know the model number yet to get all the specs on it
Old 09-09-2011, 08:03 PM   #10
rrtree
Drives: '11 2lt
so its not brand new but "like new" and looks like it may be an older model but everything looks great inside i just gotta try to get the specs on it now...
thanks alot gretchin cant get this damn turbo stuff out of my head since seeing your green monster....
Old 09-09-2011, 09:06 PM   #11
Pt_killa
Pt_killa's Avatar
nice turbo! Turbonetics too! how many inches or mm's is it across the top of the compressor wheel and the top of the turbine wheel? With those measurements we can at least tell you what type of flow youll have. That looks like a 3 inch inlet and 2 inch outlet meaning it would be an e housing.
Old 09-09-2011, 11:05 PM   #12
rrtree
Drives: '11 2lt
2 3/4" and 2" on the cold side and 2 1/4 opening and 5 bolt flange and the t4 flange on the hot side so is it a t3/t4 hybrid????
also can i tell if it really is ball bearing (without taking apart) as i was told it is?
Old 09-09-2011, 11:54 PM   #13
Pt_killa
Pt_killa's Avatar
Hmm could be a 60-1 hifi or 62-1 hifi, do you have a picture of the inlet flange on the turbine housing? Others correct me if I'm wrong, but usually T3 hot sides use the 5 bolt outlet flange. If it is a t3/t4, the turbine may be too restrictive for a single setup but still try to bring it to Tracy since your close.
Old 09-10-2011, 03:22 PM   #14
gjarzabek009
gjarzabek009's Avatar
Drives: 1LT
Hey man we need numbers from your car asap! Get 0-60 times and 1/4 miles times
-21" GM wheels -3.73 gears -Injen PowerFlow CAI
-OBX LT headers -Doug Thorley Catback exhaust
-Magnaflow High Flow cats -Trifecta Tune
-VMAX Ported TB
-Maces 25mm Insulator
-Ported Intake manifolds (soon)
gjarzabek009 is offline   Reply With Quote
TT question metallicide Forced Induction - V8 24 01-30-2011 07:30 PM
Granatelli / Turbo Tech Twin Bottom Mount Turbo Systems Granatelli Forced Induction 20 11-30-2010 07:47 PM
Why TT over SC? Jefe's SS Forced Induction - V8 10 10-02-2010 04:14 AM
STS Twin Turbo Kits Coming Soon!!! tbyrne Forced Induction 18 10-19-2009 11:06 AM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
