Old 03-29-2009, 05:43 PM   #1
dougmac
Drives: 2011 V6 MCA & 1969 GT Mustang
18, 19, & 20" replacement tires ...
I know there have been a few threads on TIRES that I could have added to, but I wanted to start fresh ...
Anyone shop for replacement tires yet ??
The 18" size (245/55-18) appears to have never been used on a production car as neither TIRE RACK or DISCOUNT TIRE DIRECT have ANY listings for this size.
For the 19" size (245/50-19), only ONE replacement pops up on TIRE RACK and it is a Yokohama Advan S.T. Street/Sport Truck "Summer" tire with a W Speed rating ... $206.00 each.
For the 245/45-20, only 7 results pop up DTD and 12 on TIRE RACK:
2 MP Summer car
2 UHP Summer car
1 Summer truck
2 UHPA/S
2 HPA/S
1 GTA/S
2 A/S truck
For the 275/40-20, only 7 results pop up on DTD and 21 on TIRE RACK:
4 MP Summer car
10 Summer truck
4 A/S truck
2 Snow (V rated)
The 20's have an ok selection (not much for A/S unless you want truck tires), but for the 18/19" sizes GM better either build a TON of Camaros or start putting these sizes on OTHER cars so we eventually have a decent selection of tires to pick from !!
Factory 18 & 19" tires will be "T" Speed rated "Touring Tires" ... Touring tires are for SEDANS and MINIVANS !! Although I suppose they are following suit as this is what Ford puts on the V6 Mustang.
A sporty car with 300+HP on tap like the Camaro should have at least "H" speed rated HPA/S tires; "W", "V", or "Z" rated UHPA/S or HPA/S tires would however be better yet !! If they don't come from the factory, you should at least be able to get better performance tires later on. This being the only car at this time to use these tire sizes, the only replacements for a long while will more than likely be O.E.M. replacement or equivallents from other tire manufacturers.
I really LIKE the fact that Chevy decided to put these large diameter tires on this car because it gives a decent section height (distance between rim & road) for real world driving while giving the wheel sizes everyone THINKS they need ... the shortest section height of all the factory tires (275/40-20) is 4.331" which is the EXACT same section height as the last 2002 Z28's 275/40ZR-17 !!
The 18's have a section height of 5.305" ... the performance tire most 80's Mustangs GT's came with were 225/60ZR-15 which had a 5.315" section height ... losts of rubber between rim & road !!
Doug
dougmac is offline   Reply With Quote
Old 03-29-2009, 05:56 PM   #2
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
$206!! that's it?!
that's a bargain, considering the tires i'm used to buying are that or more easy, but then again, those are for trucks
Old 03-29-2009, 06:21 PM   #3
dougmac
$206 for a "W" speed rated passenger car tire is a bit steep IMO ... I'd hope for something in the $125-150 range.
On tire rack, the 275/40-20 range from ...
$144 for a "V" speed rated truck A/S to
$448 for a "W" speed rated MP Summer
and the 245/45-20 range from ...
$115 for a "V" speed rated HPA/S to
$389 for a "Y" speed rated MP Summer
Those 2 bottom end tires would not be a matched set.
The cheapest 20" matched set would be Yokohoma Parda Spec-X ("V" Speed rated Street/Sport Truck A/S) ... $144 rears & $149 fronts. These also have a decent 420 A A tread wear rating AND are the TOP rated tire in this catagory @ TireRack.
Doug
Old 03-29-2009, 06:27 PM   #4
Vash
Drives: 00 Blazer
Sumitomo's are my favorite. Cheap and really a good Japanese made tire.
about getting 20" all season tires sting39 Wheels and Tires Talk Sponsored by The Tire Rack 15 11-25-2012 12:03 PM
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
are there any 20" all-weather tires out there? card21doc Wheels and Tires Talk Sponsored by The Tire Rack 11 01-15-2010 09:11 PM
Will the SS have 20" run flat tires? Can we go bigger in size? Hoss Wheels and Tires Talk Sponsored by The Tire Rack 18 11-28-2008 11:59 PM
