Old 09-10-2011, 08:37 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question burn out question
OK so i have the M6 and when i do burn outs and after a few seconds the computer in the car shuts down the power. I turn off the traction control and the stability control. after i do a few donuts it comes up service "stabi trac". Even then after doing a burn out it cuts down the power.
2010_camaro is offline   Reply With Quote
Old 09-10-2011, 08:43 PM   #2
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
The light comes on due to the front and rear tires rotating at different speeds, happens on a dyno run as well...
the power being pulled is probably from hitting the rev limiter....
Old 09-10-2011, 08:45 PM   #3
2010_camaro
I can hold it at 4 or 5K and after doing a burn out for a bit it shuts the power down. I never do burn outs and hold them at redline nor do i hit the redline. I never take it above 6k
Old 09-10-2011, 08:45 PM   #4
Parag
Drives: 2010 camaro 2SS LS3
If it actually drops power to nothing, you have computer glitch in the traction control system.
Parag is offline   Reply With Quote
Old 09-10-2011, 08:47 PM   #5
Parag
Hey new question sorry to over run thread, can you completly disable traction control, like unplug the sensors?
Old 09-10-2011, 08:48 PM   #6
2010_camaro
no it dont go to nothing. it pissed me off one day so i just kept my foot on the brake foot on the gas and said ill either stall it or it will let me melt the tires. the power dropped and the rpms fell to about 2,300. the tires kept spinning just very slow.
Old 09-10-2011, 08:49 PM   #7
2010_camaro
I think on the SS's you can pull some fuse's but can you do it on the v6?
Old 09-10-2011, 08:53 PM   #8
Parag
That is to nothing, thats as far as the traction control will reducepower it wont stall the car. And do the same thing pull fuse and see if it dixes problem if so ypu know the problem.
Old 09-10-2011, 08:54 PM   #9
Parag
Or its your brakes. Get a line lock
Old 09-10-2011, 09:00 PM   #10
2010_camaro
I hold the brake to melt the tires.
Old 09-10-2011, 09:07 PM   #11
Parag
When you do a brake burnout you should be holding the brake as lightly as possible and to check you should keep the car creeping forward. Why would you ever want to melt your tires, at the strip with street tirea you should just clean them off
Old 09-10-2011, 09:14 PM   #12
2010_camaro
I melt them to piss my neighbors off! Doing a little burn out with little smoke aint me. I want to repave my road with my tires!
Old 09-11-2011, 12:54 AM   #13
Parag
Its probably stabilitrac. You need to hold the traction control button for 7 seconds to disable.
stereo question bigted83 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 04-07-2011 05:56 PM
Burn out question GQ4Life Dragstrip and Launch Techniques Discussion 13 10-21-2010 12:10 PM
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 08:27 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
