Old 09-10-2011, 09:29 PM   #1
TJeezey
Drives: 2011 SS/RS M6
Problem with skip shift eliminator
Just installed it along with the borla atak cat back. When I started the car up, I noticed the car would not go into reverse. Only after I used a considerable amount of elbow grease would it go into reverse. The skip shift does work though, just having a problem with reverse. Any suggestions?
2011 IOM SS/RS M6 w/Hurst. C.A.I. inc Intake, Borla ATAK catback, ARH LT's with HFC, Vmax TB, Apex Scoop, 91 oct Jannety Tune
TJeezey is offline   Reply With Quote
Old 09-10-2011, 09:30 PM   #2
IROCanSS
Drives: 89 IROC 350
LOL, you put it on your revese lock out. Common mistake.
THe reverse lock out is the one that is VERY accessible. The skip shift plug is WAY.... UP... on top of the tranny. Sorry, but you have to go back under there!! If you thought it was super easy to install,... it isnt. Its a tough reach.
It really is common but you need to switch it ASAP.
Old 09-10-2011, 09:33 PM   #3
TJeezey
Horray for me... Where does it go then? Haven't found a picture of a camaro install.
Old 09-10-2011, 09:35 PM   #4
DCC1464
COTW 5/27/13
DCC1464's Avatar
Drives: '11 S/C SS/RS CGM
you hook up to the wrong connector!
http://www.camaro5.com/forums/showth...ght=skip+shift
post 2
622RWHP/512FTLBS on 91 octane
2.9l Whipple 4" pulley. Vengance VRSP3 cam. Lots of BMR & AAC. Body work by Gary's Customz. Nic D tuned
My build thread
DCC1464 is offline   Reply With Quote
Old 09-10-2011, 09:36 PM   #5
IROCanSS
Drives: 89 IROC 350
shoot... top side of the tranny is all I really remember... Just go back under there and look for another place that it will go, sort of up on the top... cant recall if its driver or pass side, its towards the back of th tranny Ithink... sorry not mcuh help, its been 2 years since I put mine on.
Sorry I cant give more help... There are good pics floating around somewhere but the search fxn on here sucks.
Old 09-10-2011, 09:37 PM   #6
DCC1464
COTW 5/27/13
DCC1464's Avatar
here the post with install pics
http://www.camaro5.com/forums/showth...inator+install
hope it helps
My build thread
Old 09-10-2011, 09:37 PM   #7
IROCanSS
Drives: 89 IROC 350
post 2
Its post 3
Originally Posted by Apex Chase View Post
There are two plugs on the transmission that the skip shift eliminator will fit, the CAGS solenoid and the reverse lock out. Plugging it into the wrong one is a common mistake. The skip shift solenoid is located half way up the transmission case, towards the top, on the drivers side.
Old 09-10-2011, 09:37 PM   #8
The Stig
knows 2 facts about ducks
The Stig's Avatar
Hahaha, I did that too the first time. I think almost everybody plugs it into the reverse solenoid the first time.
Click to view my build thread
Old 09-10-2011, 09:38 PM   #9
IROCanSS
Drives: 89 IROC 350
I didn't
Old 09-10-2011, 09:42 PM   #10
TJeezey
Thanks for the links and suggestions. Is it gonna be a problem aka damage to the car if it stays there for a couple trips? Any risk damaging the shifter or gears?
Old 09-10-2011, 09:44 PM   #11
TJeezey
It's also crazy that I've never read about the problem. Also crazy, I had a response in like 20 seconds. I love this forum...
Skip Shift Eliminator Pollock V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 55 11-04-2013 11:29 PM
Skip shift eliminator available at GMPARTSHOUSE patrickt Audio / Visual / Electronics/ Gauges / Nav 33 10-26-2011 10:47 PM
Skip Shift Eliminator velociSSimo Transmission / Driveline 6 08-10-2011 10:26 AM
Skip shift eliminator problem Rob V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 10 02-24-2011 07:39 PM
