BeckyD@RodgersChevrolet
Old 09-11-2011, 12:55 AM   #1
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
no spring compressor and in the middle of an install
How did you guys get off the nut off the top of the factory spring/strut housing? I didnt get the spring compressor because they say it wasn't really necessary. HMMM...I am regretting listening to that part of the coil over install.
Any help would be appreciated. If I don't hear back I am going to have to call it a night. Sucks because I live in a condo so security is going to trip in the morning probably.
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 09-11-2011, 01:00 AM   #2
Rogan
No Pain No Gain
Rogan's Avatar
Uploaded with ImageShack.us
Old 09-11-2011, 01:59 AM   #3
Nessal
Drives: Exige, Miata, Ghia
You're going to need a standard combo wrench with at least the minimum offset below. Or you can get the one pictured behind the combo wrench which is a offset wrench that will work perfectly.
Nessal is offline   Reply With Quote
Old 09-11-2011, 02:05 AM   #4
Nessal
By the way, a spring compressor will not help you with this part. If your wrench can not turn that nut, it ain't coming off spring compressor or not.
Old 09-11-2011, 09:25 AM   #5
Rogan
No Pain No Gain
Rogan's Avatar
I'm going to head to Sears to get that wrench with the high offset. Mine obviously required a lot more effort to get the nut off. But I got it off. Don't want to fight the other side too much.
Old 09-12-2011, 12:47 AM   #6
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
personally i would take some channel locks and squeeze the strut rod while loosening the nut,i also suggest air tools but whatever works
firestone_ss is offline   Reply With Quote
Old 09-12-2011, 12:51 AM   #7
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
That offset wrench isn't the problem. You were just fine to start with. Shouldn't require that. It's just tight. Plain and siimple. A straight wrench does just fine.
Of course you're probably done by now.
Old 09-12-2011, 02:12 AM   #8
SSmoothie
SSmoothie's Avatar
Drives: 2010 Camaro 2SS/RS 6SP Blk/Blk
Don't need a spring compressor, it will spring off some just do it outside and point it away from you.
SSmoothie is offline   Reply With Quote
Old 09-12-2011, 04:51 PM   #9
BLACK10
BLACK10's Avatar
I hope you didn't hurt yourself trying to get that nut backed off without the spring being compressed. That's a VERY dangerous thing to try.
Old 09-12-2011, 05:18 PM   #10
PQ
Booooosted.
PQ's Avatar
Not with these. Trust me. The pop was quite small. Could do it against your leg and it wouldn't hurt at all.
The tightness of the nut has nothing to do with the spring.
Old 09-12-2011, 05:46 PM   #11
White_2_SS
White_2_SS's Avatar
Drives: 2011 2SS M6
He is right. What you can do is put the lower shock bolt in on the rears. Take a 1" rachet strap hook to one side of the bolt loop over the top of spring perch and down to the other side of the bolt. Make sure to position the strap so you can get to the nut. Spool up the strap some once it's tight give it 2-3 pulls. That will take plentty of tension off. I have done more then a few like that... at least 10 cars. New springs you just use body weight to push the perch down and spin the nut on.
White_2_SS is offline   Reply With Quote
Old 09-12-2011, 06:06 PM   #12
Rogan
No Pain No Gain
Rogan's Avatar
I never got over to Sears but the other side was easy. I just shouldn't be working on things like this in the AM. Plus security in the highrise didn't even car. I could have started that morning during daylight time and get the whole thing done in one shot.
Old 09-12-2011, 10:12 PM   #13
Nessal
Live and learn man. Happens to the best of us.
Old 09-12-2011, 10:48 PM   #14
PQ
Booooosted.
PQ's Avatar
So......?
Let's see pics of the lowered ride.
