Old 09-11-2011, 10:30 AM   #1
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
Did something wrong and doing something wrong. Pfadt sway and BC coilover over instal
Remind me never to tackle a job like this late at night. I tried to avoid the heat that way, but I forgot rest is equally if not more important than trying to cool.
Problem one is that I can't snake the stock sway bar out. I dont have a saw and I'm determined to get it out without having to get a saw. Can I get a torch and burn the clamps? If those were off it would be cake to snake out. I tried to be patient...like an hour patient but no luck. Was worried about screwing up the hoses below.
Ok below are some pics. Problem two is... The spring top bolt is protruding through too high. I read that OE rubber will protrude about 1/4" but the bolt is the problem.
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 09-11-2011, 10:31 AM   #2
Rogan
No Pain No Gain
Rogan's Avatar
The two washers in the lower pic where the ones I used on the coilover that came off the stock assembly. Should I have used the washer in the middle in the top pic?
NOTE TO SELF - Print out instructions because laptop is not going to last during the install.
Old 09-11-2011, 10:36 AM   #3
Rogan
No Pain No Gain
Rogan's Avatar
Top pic is the passenger side with the coilover. The driver side is still with the OE parts.
Old 09-11-2011, 10:47 AM   #4
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Not sure what instructions you are using but these may help.
http://www.planetlsx.com/tech/How_To..._Camaro_SS/143
As for removing the front sway, loosen your motor mount bolts till the nuts only have a few threads left. Place a wood block under your oil pan and jack the motor up. That should give enough clearance to get the bar out.
Squintz Palladoris is offline   Reply With Quote
Old 09-11-2011, 11:02 AM   #5
Squintz Palladoris
Looks like you mounted the upper spring mount (Rubber) upside down.
Old 09-11-2011, 11:12 AM   #6
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
First, check out my install tips for removing the front sway bar. You don't need to cut anything, but you do need patience and some grunt work.
http://www.camaro5.com/forums/showthread.php?t=123818
Second, your strut tower mounts should not stick out like that. You either reassembled things wrong or forgot to take out the OEM plastic bushing. Re-check your coilover install instructions.
Third, get some sleep.
Good Luck.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is online now   Reply With Quote
Old 09-11-2011, 11:40 AM   #7
Squintz Palladoris
It should look like this
Old 09-11-2011, 12:23 PM   #8
Nessal
Drives: Exige, Miata, Ghia
The top rubber mount is on upside down. Also i dont believe that I had that middle washer. Mine went in this order, spring, BC washer, dust boot, BC pillow mount, OEM rubber bearing, upper retaining washer, upper retaining nut. Then once it gets onto the car i put in the top retainer and lock nut.
Nessal is offline   Reply With Quote
Old 09-11-2011, 12:25 PM   #9
Nessal
Let me say one thing. This is the reason why I always start a project early in the morning. Murphy's law is a bitch. Trust me. I've been where you've been and it sucks.
Old 09-11-2011, 01:37 PM   #10
Rogan
No Pain No Gain
Rogan's Avatar
Great info. I will try to take off the bushings first. If I can't get them off - I will lift the motor a little.
And wow to the bushing being upside down.
Old 09-11-2011, 01:38 PM   #11
Rogan
No Pain No Gain
Rogan's Avatar
If I had printed or brougt down a second laptop I would have caught that.
Old 09-11-2011, 02:52 PM   #12
L99CAMA2011
L99CAMA2011's Avatar
I installed springs on a Porsche 944 overnight during a rain storm, desperation I guess.
Old 09-11-2011, 05:49 PM   #13
Rogan
No Pain No Gain
Rogan's Avatar
Kind of wanted out the way to enjoy my Sunday. Ha..should have started early today. Got the fronts on. Will hit the back tomorrow afternoon. About to at least get the front sway. Removed.
Old 09-11-2011, 08:00 PM   #14
Nessal
After this install you'll feel like a pro if you have to do it over again.
