HeadlightArmor
Old 09-11-2011, 12:25 PM   #1
Hendu
Hendu's Avatar
Drives: 2SS 45th Anniv LS3
Skip Shift
So....
After not triggering the skip shift for 300 miles, I decided I didn't need to watch for it.
Two stop lights in a row this morning I coudln't shift into second...it freaked me out. I am glad I ordered the eliminator from apex. I think I will be getting that in this week.
Hendu is offline   Reply With Quote
Old 09-11-2011, 12:33 PM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
<3 skip shift eliminator, a cheap mod that saves us from the gas guzzler tax
Old 09-11-2011, 03:33 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by Hendu View Post
So....
Thank you for your order. Looks like it shipped USPS on Tuesday so it should be there any day.
Old 09-11-2011, 04:18 PM   #4
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
I noticed the same thing with my car, the skip shift would not work consistantly. I put a skip shift eliminator on and had a hard time making sure it worked because I couldn't get the skip shift to activate. It used to be the skip shift notice would show up on the DIC until I hit like 2500RPM, sometimes it does and sometimes it doesn't.
When you put the skip shift eliminator on the skip shift notice will appear on the DIC but you can put it into 2nd gear.
Russ
OHIOSS is offline   Reply With Quote
Old 09-11-2011, 04:31 PM   #5
Apex Motorsports
CAGS is only activated in the 5th Gen Camaro SS when:
  • you are in first gear
  • you are using 21% throttle or less
  • you are traveling between 15 & 19 mph
  • and your engine coolant temperature is greater than 169°F (76°C)
Old 09-11-2011, 04:37 PM   #6
Hendu
Hendu's Avatar
It came Friday, before my car arrived. Boy scouts paid off, Be Prepared!
I meant I just need to get it installed
Old 09-18-2011, 08:43 AM   #7
Captronp
Ron P
Captronp's Avatar
Drives: 2011 1SS/RS - LS3 6 stick - Yellow
I bough one, installed it. Works just like you said BUT, reverse is a real pain to get into. Now my hurst shifter is loose. I dont now, should not have installed.
Captronp is offline   Reply With Quote
Old 09-18-2011, 08:53 AM   #8
Apex Motorsports
If you are having an issue with reverse then you in all likelihood have it plugged in to the reverse lock out solenoid instead of the CAGS solenoid. This is a pretty common error. The CAGS solenoid is located on the drivers side towards the top of the transmission in the case. It is kind of out of the way. Looseness with your shifter would not be related to the skip shift eliminator. It does not change anything mechanically.
Old 09-18-2011, 03:15 PM   #9
Captronp
Ron P
Captronp's Avatar
I see 3 solenoids - the picture seem to show the one at the tail end of the trans. The other is mid trans on the side and one 1/3 from front of trans near the top, is that the one?
Old 09-21-2011, 09:10 PM   #10
Captronp
Ron P
Captronp's Avatar
Update, it wasthe right one. Top center, drivers side
Old 09-21-2011, 09:43 PM   #11
Parag
Drives: 2010 camaro 2SS LS3
the skip shift eliminator will not affect reverse unless it on wrong wire, or the physical part is pressed against moving parts
Parag is offline   Reply With Quote
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 11:34 AM
Who's looking for a deal on a Skip Shift Eliminator? Apex Paul Transmission / Driveline 51 07-07-2010 06:32 PM
Hurst Billet/Plus 2 Shifter $319.95, get Skip Shift Eliminator FREE! Apex Motorsports Transmission / Driveline 22 06-15-2010 10:55 AM
$26.95 Skip Shift FREE w/ purchase of Hurst Billet/Plus 2 Shifter Apex Paul Transmission / Driveline 9 04-23-2010 08:08 PM
St. Louis, MO Tune Special - Turn off Skip Shift or AFM! DSteck V8 Bolt-Ons & Tunes 3 04-19-2010 04:20 PM
