BeckyD@RodgersChevrolet
Old 09-11-2011, 11:26 AM   #1
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2010 2SS/RS L99
L99 VVT CAM - tell me about your setup and results
After researching all the cams and options for my L99 I am considering a VVT cam. The LS3 conversion is not an option for me since I don't have $4K to spend. It appears that the VVT has proven to provide the most power for a stage I and stage II up to the 5100 rpm. A setup like this would cost me $1500 installed. I don't plan on adding a supercharger so I think this may be a good option for me. Has anyone experienced any issues with a VVT setup? I would be interested in hearing about your experience.
Also, please post video sound clip. I have had little luck finding them on Youtube.
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
1Camaro2SS is offline   Reply With Quote
Old 09-11-2011, 11:37 AM   #2
SM0KE
IN THE CIRCLE
SM0KE's Avatar
Drives: 2010 IOM 2SS/RS
Increasing Circle Size is not important.
Worthiness will knock at the door on it's own accord
SM0KE is offline   Reply With Quote
Old 09-11-2011, 02:10 PM   #3
RED DEMON SS
OFF THE CHAIN
RED DEMON SS's Avatar
Drives: PSHHH UWISH
I second that!
Old 09-11-2011, 05:16 PM   #4
1Camaro2SS
1Camaro2SS's Avatar
Wow! Nobody has a vvt cam?
Old 09-11-2011, 05:24 PM   #5
jeffswhitess
jeffswhitess's Avatar
Drives: 2010 ss2 white w/gold stripes
I would like info on this too!
jeffswhitess is offline   Reply With Quote
Old 09-11-2011, 05:57 PM   #6
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
dont know about the cam but the ls3 conversion would require replacing the 10.4 compression ratio pistons with 10.7 ones.thats what comes in a ls3...i see alot of people talking about LS3 conversions but think almost none have swapped out the pistons.....and that along with turning off the vfm is what it would take for a conversion.a L99 will always be a L99 without the piston swap..period
hunter1660 is offline   Reply With Quote
Old 09-11-2011, 06:38 PM   #7
1Camaro2SS
1Camaro2SS's Avatar
I am interested to know about vvt cams. Don't care about ls3 conversions but you're right, it wouldn't make your engine an ls3 if you converted as most people do.
If anyone has a vvt cam please share your thoughts.
Old 09-11-2011, 07:54 PM   #8
enehrt
enehrt's Avatar
Drives: 2011 SIM RS/SS Convertible
I think that texas speed has l99 vvt cams here is a link
http://www.texas-speed.com/c-234-cam...c-engines.aspx
01/26/11 - 3000 - TPW 2/21
02/22/11 - 3800
03/14/11 - 5000
03/22/11 - 6000
enehrt is offline   Reply With Quote
Old 09-11-2011, 08:29 PM   #9
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
I run a mast stage 1 VVT cam. Good low end power and lope. You will need an aftermarket torque converter though.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 09-11-2011, 08:36 PM   #10
1Camaro2SS
1Camaro2SS's Avatar
Very nice and thanks for the comment.
I see that you also have a supercharger. Do you know what your rwhp was with just the cam? Is it really necessary to have a torque converter with a stage 1?
Also, have you had any issues with the vvt cam? I heard there is a reliability concern. Thanks for the feedback.I appreciate it.
Old 09-11-2011, 08:40 PM   #11
1Camaro2SS
1Camaro2SS's Avatar
your video on youtube is awesome
man you have some serious power in that L99
Old 09-11-2011, 08:49 PM   #12
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
+1 for Mast...
Old 09-11-2011, 09:44 PM   #13
lexlueger
lexlueger's Avatar
I believe it was 419 rwhp cam/bolt ons. You will need a converter, my car had wicked cam surge without it. I had a broken valve spring awhile back, not sure if that was a VVT issue.
http://www.camaro5.com/forums/showthread.php?t=132873
Thanks! She gets up there. That was a couple pulleys ago.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 09-11-2011, 09:51 PM   #14
1Camaro2SS
1Camaro2SS's Avatar
Thanks again lexlueger, you've been very helpful. Now I need to find out what that converter will cost me installed. Would you be willing to share with me what you paid? You can pm me if you prefer. In any case sounds like it is needed regardless of what stage cam is in.
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-17-2012 11:24 PM
My new setup complete today. Mixed results CamaroC-17 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 20 05-28-2011 01:15 PM
ECS Big Blower Cam - Results are in with a solid 51 RWHP gain robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 02-21-2011 09:38 PM
ECS Big Blower Cam installed - full how-to write-up coming robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 24 02-11-2011 10:25 PM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 03:09 PM
