Gen5DIY
Old 09-11-2011, 12:35 PM   #1
Sidewinder
Sidewinder's Avatar
Drives: 2SS/RJT/A6/Received 09/09/09
Unhappy Dead Battery
Went to start the C5 on 09/09/2011 2 years to the day after delivery and the battery was dead. The car had been sitting only for a week. Jump started today with out a problem but she will not hold a charge.
Has anyone else experienced a similar problem at such an early stage? I wasn't able to find any specific warranty info in my materials stating the battery is covered under the OEM 3/36 Warranty. It's sunday so the selling dealer is not open but will be checking in with them on Monday.
Does anyone know if the battery is covered under the OEM Warranty? This car only has approx 11,500 miles on it.
PS: Priced a new battery at Autozone = $154.00
Sidewinder is offline   Reply With Quote
Old 09-11-2011, 12:43 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Battery is covered under warranty. Take her to a dealer
Click to view my build thread
Old 09-11-2011, 12:45 PM   #3
Sidewinder
Sidewinder's Avatar
Thanks for the come back
Old 09-11-2011, 12:46 PM   #4
~Stacy~
~Stacy~'s Avatar
Drives: 14 camaro 16 sentra
Battery Issues
I use to have lots of battery issues with my previous car a 2008 Pontiac G6 GXP. That car left me stranded in my college parking lot one night when it was about 15 degrees outside and then it died in my garage. Pontiac gave me two free jump starts and they would charge my battery for me but never replaced it Make sure you get a new battery and not just a free battery charging.
~Stacy~ is offline   Reply With Quote
Old 09-11-2011, 12:49 PM   #5
Sidewinder
Sidewinder's Avatar
Thanks, I drove it for a while and parked it back in the garage, shut it down and it would not re-start. I will not accept a battery charge.
Old 09-11-2011, 01:42 PM   #6
~Stacy~
~Stacy~'s Avatar
The camaro is my 4th new vehicle I purchased thru GM and I know from my first vehicle my 03 Grand AM GT I got screwed around by a couple of dealers for warranty issues because I'm a girl they must not think I'm smart about anything I'm suprised I haven't killed my battery off in my camaro I HAVE ALOT OF electrical stuff connected but I took out all of my bulbs and replaced them with leds so that must work
Old 09-11-2011, 01:48 PM   #7
evan
ready...
evan's Avatar
Drives: 2010 Camaro 2SS/RS
My batt died after sitting for a month, but ever since it's been fine. Hope yours works out for you.
evan is offline   Reply With Quote
Old 09-11-2011, 01:49 PM   #8
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
poss bad battery or maybe alt as its not holding the charge
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 09-11-2011, 08:17 PM   #9
Sidewinder
Sidewinder's Avatar
Measured the voltage before and after the jump start
Before: 4V DC
After jump start + about 45 min of driving: 11V DC.
I don't have a charger to run over night but maybe a longer drive would have been in order. It still shouldn't have failed and it will get a new one if the charging system checks out.
Old 09-12-2011, 08:27 PM   #10
jbohannon
Drives: 1969/2012 Camaro
Sidewinder you really need to charge your battery overnight on a 6 to 10 amp charger.
All your doing driving it around is putting a surface charge on it, and straining your alternator.
I have a battery shop, and discharged batteries are one of the most common problems we see.
For whatever reason, it became discharged. Could be your charging system is not working properly, could be you left the dome light on, could be a serious parasitic drain.
But definitely I would charge the battery overnight and then have it load tested. If its not charged first, its gonna check out bad on the load test.
Once the battery is fully charged, or replaced, crank the car, turn your AC and headlights on, and check the voltage output at the battery, it should be at least 13.5. Anything less and the alternator is not charging properly.
My 2 year old daughter is sitting on my lap and really wanted me to put the yellow smiley face with big eyes on the screen, so here it is
Good luck!
jbohannon is offline   Reply With Quote
Old 09-13-2011, 06:42 AM   #11
Sidewinder
Sidewinder's Avatar
Good luck!
Thanks, I just bought a new charger and will give it a try tonight
Old 09-13-2011, 08:32 AM   #12
ibmrs
ibmrs's Avatar
Drives: 2011 2LT RS IBM
It's an acdelco, that's about all you can expect. Not what you want to hear i am sure, but they are total piles of garbage. One draw down and it will never recover in my experience. 3 chevy trucks in the past, all i've ever gotten out of them is 2 years, every one died in year 2. I don't bother with the warranty, because i don't like to deal with being stranded and replacing these damn things every 2 years. Get something with high reserve capacity, i posted this yesterday as someone was complaining of weak battery/start. Does battery seem weak to you?
I'll probably get flamed, but 3 times over last 12 yrs same exact thing happened to all of them, 2yrs and gone, don't hold up to FL heat at all or draw downs, so i trust acdelco junk batteries about as far as i can throw them.
Edit. Saw OP 1st post. I like the autozone duralast (made by interstate), one of highest reserve capacity. One in my avalanche lasted 6 yrs. 5 yrs on the one before that in my other truck when i sold it.
Tampa Bay Camaros, Team LLT
ibmrs is offline   Reply With Quote
Old 09-13-2011, 10:56 AM   #13
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
The stock battery in my 04 GMC 1/2 ton never did die, but I replaced it after 6 years anyways as it was starting to crank slow.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 09-13-2011, 08:07 PM   #14
jbohannon
Interstate doesn't make the duralast battery, in fact interstate does not make batteries.
JCI (Johnson Controls Inc.) makes batteries that are marketed by Interstate, Autozone, Discount, Walmart, and AC Delco.
The majority of batteries made by JCI are now made in Mexico.....
JCI makes the batteries to the specifications of each of these companies.
If you want a great battery, go with an AMERICAN MADE battery, which is unfortunately, very difficult to find these days.
Any battery with a Deka or East Penn label is made in Pennsylvania. I carry there batteries as well as many other independent battery specialists. But the only national retailers I can think of that carries them are Car Quest and O'Reillys.
How long does it take before your battery is dead ? 2010 Bumblebee 5th Gen Camaro SS LS LT General Discussions 69 04-08-2013 12:01 PM
Battery Drained & Knock Sensor Bulletin TSB P10284 tjd24 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 09-10-2011 10:50 PM
Need Help with my Battery! Please advise FirstCamaro23 5th Gen Camaro SS LS LT General Discussions 19 01-11-2011 05:55 PM
Smartest Battery Charger in the World!!! southerncarparts Miscellaneous Items 10 02-15-2010 07:08 PM
Smartest Battery Charger in the World!!! southerncarparts Audio / Visual / Electronics/ Gauges / Nav 0 12-04-2009 08:35 AM
