sjm autoprod
Old 09-11-2011, 02:17 PM   #1
black.
Drives: IBM 2SS
Aircraft remover + MS wheel question
Just a question but if you put aircraft remover on a factory MS wheel will it remove the paint to give it a polished wheel effect? Tried this on my streetbike wheels and the wheel ended up with the polished result.
black. is offline   Reply With Quote
Old 09-11-2011, 02:49 PM   #2
Carver1
Drives: 2011 1SS/RS LS3
Since the polished wheel is an upgrade from the MS, I doubt it is polished underneath. It is most likely just aluminum. You could polish it afterwords maybe?
Carver1 is offline   Reply With Quote
Old 09-11-2011, 03:05 PM   #3
Bonanza7
Drives: 2010, Rally Yellow, Black stripes
Hmmm.....Don't know of anything you can put on an aircraft that will remove it. Maybe David Copperfield, but......
Bonanza7 is offline   Reply With Quote
Old 09-11-2011, 04:31 PM   #4
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
If you do this, you will come to a black primer layer under the silver clearcoat and then the actual aluminum beneath the black primer.
I've seen guys strip the paint off motorcycle wheels but let me tell you, it took a good amount of time behind the polishing wheel before they shined up like mirrors. You will encounter the same thing here. LOTS of work.
TheHorse13 is offline   Reply With Quote
Old 09-11-2011, 07:32 PM   #5
black.
Drives: IBM 2SS
Thanks, that makes sense.
Old 09-11-2011, 07:36 PM   #6
CFD
Drives: 2SS/RS L99 BLACK
I recently stripped a midnight silver wheel using aircraft paint remover and the wheel WAS polished underneath the paint.
CFD is offline   Reply With Quote
Old 09-11-2011, 09:39 PM   #7
RED DEMON SS
OFF THE CHAIN
RED DEMON SS's Avatar
Drives: PSHHH UWISH
I have the silver 20" wheels, definitely would like the polished wheels better!
Anyone else do this?
Old 09-11-2011, 10:47 PM   #8
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
How did you get an Aircraft stuck to your wheels?
KEEP RT is offline   Reply With Quote
Old 09-11-2011, 10:51 PM   #9
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 09-12-2011, 06:47 AM   #10
TheHorse13
TheHorse13's Avatar
I'm really surprised to hear that they are polished at the base. Makes you wonder how the primer was able to stick to the surface.
Did you strip the entire wheel? How much work is involved? Do you have any decent pics of the polished surface.
Thanks.
Old 09-12-2011, 07:37 AM   #11
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
Thanks.
I would be shocked if GM would take a polished wheel and "downgrade" it by painting it, smells fishy to me......
h2oplay is offline   Reply With Quote
Old 09-12-2011, 08:16 AM   #12
CFD
Thanks.
When I bought the wheels used here on the forum, one polished and one midnight silver, I was planning on doing some mods to them. When I stripped them the clear coat on the polished wheel came off very easily, the midnight silver wheel was a lot more work. I did strip the whole wheel, it took several coats to strip it. When stripped there was very little difference between the polished and painted wheels finish. I did take a couple of pictures although not that great as you can see by the old paint on the floor this shot is of the wheel during the stripping process. The spokes of the wheel have been scuffed to prep for welding but the outside rim area is untouched and as stripped. As you bcan see there is no real difference.
Old 09-12-2011, 08:19 AM   #13
TheHorse13
TheHorse13's Avatar
Yea, I can see what you're saying. I would not have guessed that a smooth surface existed under the primer and clearcoat.
How long did it take you to strip the painted wheel?
Old 09-12-2011, 08:35 AM   #14
CFD
I was surprised at the finish under the paint myself although because of my plans I was not concerned.
As I mentioned, the polished clearcoated wheel stripped almost instantly, the painted wheel was quite a bit of work. 1st coat of remover took off the clearcoat, second painted surface and or base coat(at that point couldn't tell the difference) it took several more coats. The inside of the wheel is especially difficult as it is not a smooth surface. I used a plastic body filler aplicator cut so it has a sharper edge to scrape the paint off, this does not harm the surface like a scraper will and allow for easier polishing after.
steering wheel air bag question.. rxfox3 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 6 05-10-2011 05:51 PM
Steering Wheel Controls and PDIM Add-On HUGE question havoksin Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 02-23-2011 11:53 PM
Question: Cars only driven by one wheel? JMROD General Automotive + Other Cars Discussion 17 08-29-2010 05:04 PM
Lug wrench in SS? + wheel lock question... DDustiNN Wheels and Tires Talk Sponsored by The Tire Rack 8 09-05-2009 01:52 AM
Question about steering wheel and shift knob jeansonne627 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 15 08-27-2009 04:45 PM
