HeadlightArmor
Old 09-11-2011, 03:19 PM   #1
Pollock
LT1 M6
Pollock's Avatar
Drives: 2018 1SS/1LE
Under drive pulley to buy or not to buy
Should I get an under drive pulley? I am doing a cam swap soon and am on the fence about getting one.
I know the positive is a little more HP and torque. What are the negatives? Money is not an issue for this item.
Pollock is offline   Reply With Quote
Old 09-11-2011, 03:40 PM   #2
Supercharged SS
Drives: 2010 Camaro
Hell, if money is no issue then by all means grab yourself a blower instead! In the past, my experiences have shown that with the UD pulleys the charging system takes a step back. With that being said, I think the later model vehicles don't have this problem. On my 95 full size Blazer I had one and it wouldn't charge for shit. But on my 06 Trailblazer SS is was fine. I say do it then if and when you upgrade you could always sell it.
Old 09-11-2011, 04:32 PM   #3
Parag
Drives: 2010 camaro 2SS LS3
most people never have any problems with it, but to me it is not worth the 4 hp, to sacrifice the systems. the power steering has less flow through the cooler, but it saves it if you are doing all high rpm driving. the ac wont kick on until you hit 1500 rpms, and some people have dead batteries about once a year. on high rpm driving the cooling system will be dying.
Parag is offline   Reply With Quote
Old 09-11-2011, 07:25 PM   #4
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
I bumped up my idle by 150rpm, and that helped the charging.
My MPG on the highway increased by a noticeable 1 mpg.
I don't know about HP, but it is a pretty standard mod once you're trying to squeeze the last drop of HP out of it.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 09-11-2011, 07:47 PM   #5
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
An underdrive pulley is a good 5-10HP mod for the cost..as long as you do it with a cam. With the cam, you have to take the pulley off anyway, so it is easy to change when you are there. I would not do it, just to do it though because getting the pulley off is hard, and takes a lot of time. As far as driving everything slower, I have run them on a few of my own cars, and have never notcied them. Just like stock. It would be different if you have a lot of electronics or big stereo.
443-730-9428 - www.marylandspeed.com - Great Prices and Free Shipping!
* CURRENT SALES * ORDER TERMS * DISCOUNT POLICY
MarylandSpeed is offline   Reply With Quote
Old 09-12-2011, 10:01 AM   #6
Jason 98 TA
Drives: Camaro
A couple automatic guys have had charging errors from the lower idle they run from the factory. I see no way the LS3 cars would have any charging problems at all. We've installed probably 30 of them with no issues here. Typical dyno gains from a underdrive pulley is 8rwhp.
We stock the TSP system & can ship asap!
Jason 98 TA is offline   Reply With Quote
Old 09-12-2011, 04:22 PM   #7
Chris@SPMC
Drives: '99 H/C FRC Corvette and '07 TBSS
The 25% loss in charging can be offset with a 25% increase in idle speed(~150rpm), so I definitely believe it is a good bang for the buck item and highly recommend it with a cam install.
Chris@SPMC is offline   Reply With Quote
Old 09-12-2011, 04:32 PM   #8
Bobby @ LG Motorsports
Bobby @ LG Motorsports's Avatar
Drives: 03 Cobra
If your pulling the car apart for a cam install, I would do it as well. Generally speaking we have seen 4-8 hp at the rear tires from it. While that might not seem like a lot, it can mean the difference from 492 rwhp to 500 rwhp...which for most is a big step.
Given the car is going to have a cam in it, chances are your idle is going to go up anyway...I would not worry about any charging issues.
Bobby @ LG Motorsports is offline   Reply With Quote
Old 09-12-2011, 07:28 PM   #9
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Yes you should. It's a no brainer if your already in there to install a cam. You will never know it's there once it's installed, unless you put a monster stereo in your car.
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 09-14-2011, 08:47 PM   #10
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
I was in the same boat as well. I just did my cam package and did not do it. It will prob be all good, but I was just a lil paranoid about it..
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
Bay Area SS is offline   Reply With Quote
Old 09-14-2011, 09:01 PM   #11
gearhead440
gearhead440's Avatar
Drives: Yellow 2SS, 6 speed manual
I experienced no negative side effects with the UD swap, enjoyed the increased torque (especially coupled with my CAI intake, ADM scoop and Vmax TB) and since you are performing a camshaft swap anyway, by all means install the UD pulley.
Hers & His
gearhead440 is offline   Reply With Quote
To drive or not to drive? FastInTheDesert 5th Gen Camaro SS LS LT General Discussions 59 09-14-2010 12:36 AM
How far did u drive to buy a camaro Thrillz 5th Gen Camaro SS LS LT General Discussions 138 12-07-2009 05:41 PM
