Gen5DIY
Old 10-01-2011, 07:54 PM   #43
The Stig
knows 2 facts about ducks
The Stig's Avatar
This calls for moar popcorn
Click to view my build thread
Old 10-01-2011, 08:05 PM   #44
CFD
Drives: 2SS/RS L99 BLACK
It's gonna take more than popcorn to get through this one.
Although this is a complicated unit as I go along I am also trying to figure out a way so the mail slot scoop can be installed by the average guy. So far it's a pice of cake. The most important piece will be the trim around the mail slot but I can't do anything with it untill the scoop is finished and fitted, hopefully by next week end.
CFD is offline   Reply With Quote
Old 10-02-2011, 04:40 PM   #45
CFD
Didn't have a chane to do too much today. I did remove the Airaid CAI and put back the stock unit. I needed to do this to gain access to some areas that were not accessable with the Airaid. I still have my two scoops from the facia attached. I snapped a quick photo of the snorkel and inlets, this will be discarded when I finish the new CAI as it will no longer be needed.
Old 10-03-2011, 06:17 PM   #46
CFD
Got my Argon today so had a chance to do a bit more to my scoop. I got the top/back welded together, I am hoping to do the front tomorrow, once I fit that I will make the sides and weld it all together, what sucks now is that I will have to take the facia off to fit the scoop and finilize the routing of the intake tubes and decide on the filter housing, as of now I'm still thinking of putting the filter behind the facia completely isolating as much of the system as possible from the engine compartment, not that big of a deal except for the fact this is my DD so the facia will be coming off and on at least a million times.
Old 10-03-2011, 06:27 PM   #47
The Stig
The Stig's Avatar
Taking the fascia off isn't too bad, but there are two screws (one on each side) way up near the top of the fender, they are the biggest PIA
Old 10-03-2011, 06:35 PM   #48
CFD
I've had it off a few times already to do the heratige grille, my plate mount and lower two scoops,I have been leaving those two bolts out untill final assembly, it's just that this is a time consuming project and cannot be done all at once.
Old 10-04-2011, 06:30 PM   #49
CFD
The mailslot scoop is about as far as I can go untill the facia comes off. Then I can fit it and weld the sides and fabricate the outlets. If everything goes right I'll get to it this weekend. If so I will post pics of the scoop mounted in the mailslot. From there I will do the trim/grille and start working on the filter housing. Here are a couple of quick shots of the scoop, no the duct tape isn't permanent. lol.
Old 10-08-2011, 04:53 PM   #50
CFD
Finished the mailslot scoop today. I decided to leave it open on the bottom. This will allow more airflow to the radiator as well as to the filter housing. I ordered the filter I will be using, when it comes in I will make the filter housing and then finish the CAI. The photo's below show the scoop finished, still need to make the grille but at this time it's not that important, and the template for the CAI.
Old 10-08-2011, 05:36 PM   #51
The Stig
The Stig's Avatar
looks good.
Old 10-15-2011, 08:40 PM   #52
CFD
Had a chance to tinker under the hood a bit. Relocated the heater hoses and re-routed some wiring as well as worked on the mail slot scoop and filter housing a bit. Next I will do something with the fuel rails/ lines as well as continuing with the filter housing. I am waiting on headers then I will finish up some wiring . I also came up with some ideas on a few misc. items for under the hood. Here are a few photos on the engine compartment, it's starting to clean upp nicely.
Old 10-21-2011, 07:52 PM   #53
CFD
Had a chance to play with my car a bit. I swapped the fuel rails around. Because my coil mounts reposition the coils away from the valve covers and lower on them there is room to put the injector harness undrneath rather than on top of the rails. I still need to play with the other fuel line, wiring and the heater hoses but am waiting on headers to check for clearences. I also had a chance to clean up the mail slot openning to it's final size and finished the filler on the radiator support. Here are a few pics.
Old 10-27-2011, 03:13 PM   #54
CFD
DT long tubes have been installed. I didn't have room in my shop to do it so I had a buddy do it, he does quite a bit of hp work and reported that the headers went in real easy. The only problem is it's to friggin' loud. The car sounded great with the solo hf cats and mack xl exhaust but the mach xl and headers together with no cats are crazy loud, I'm hoping adding the hf cats will help some.
Old 10-29-2011, 02:22 PM   #55
CFD
Had JRE update my tune after the header install including firming up the shifts a bit more, the car is really running good but still waiting on the cats.
Came up with a couple of ideas on the heater hose location. The hoses were fine with the stock manifolds but to close to the headers so I moved them temporarily while I work on my new idea.
Also started on the trim piece for the mailslot scoop. If I have time I will finish forming it on a mini anvil and then weld in the last piece. Once this is finished I can permanently mount the mailslot scoop and get it connected to the filter housing. I'll post a couple of pics of it a bit later.
Old 10-29-2011, 03:43 PM   #56
CFD
I was getting ready to snap a picture of the trim piece and then it hit me. the piece pictured is three pieces welded together, now that I have it I can make a template and cut it out of one piece and then form it. This wal it will eliminate so much time and extra fabrication. If it works out I could even program the piece to be able to duplicate it with minimal time spent. Yes, I'm expecting to screw this one up at some point. LOL
Here are a few pics
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 606 01-19-2018 05:18 AM
Pyr0b0y's SS Build Thread [COTW 5/23/11] pyr0b0y Member Car Journals 825 09-25-2014 01:20 AM
Well, I guess I should start my own build thread. Powhusku Member Car Journals 140 09-23-2013 01:13 PM
Ph4r's Car - Boobies - Build Thread Ph4r Member Car Journals 42 03-20-2013 07:09 PM
Neogenix's 2011 SS/RS BLK/BLK Build Thread neogenix Member Car Journals 7 02-27-2011 11:15 PM
