HeadlightArmor
Old 01-26-2012, 10:56 PM   #71
4thGen427CI
5th Gen
4thGen427CI's Avatar
Drives: 10 SS
Originally Posted by CFD View Post
I will take some detailed pics and post them, perhaps it will give you some direction.
Thanks!
I did finish up the scoop and finished fitting it to the facia although I didn't weld in the channel yet. I got a donor facia from a local body shop to make the pieces out of but when I did a test weld it wasn't very strong. Reason being the Camaro's facia is made of TEO, the one I got was PP. PP is the worst for welding or use of adhesives as it has an oily content to it, when trying to weld it the oils come out and contaminate the weld. I am going to scavenge through their pile of facias tomorrow and see if I can find one of TEO.
I had no idea you could weld onto the facia.. Learning something new everyday on here! Such a great forum
4thGen427CI is offline   Reply With Quote
Old 01-26-2012, 11:01 PM   #72
CFD
Drives: 2SS/RS L99 BLACK
Originally Posted by 4thGen427CI View Post
Thanks!
Most peole don't know you can weld plastics. If you take a look on pg1 about half way down you will see an example of plastic welding I did on my plate mount.
CFD is online now   Reply With Quote
Old 01-27-2012, 11:27 AM   #73
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
awesome!
Old 01-28-2012, 02:45 PM   #74
CFD
I was finishing up some wiring on a custom bike I built. I sometimes use clips that fasten with double sided tape to hold wiring harnesses in place where there is no provisions for them and then it hit me. Rather than glue or weld something in place I could use the clips to hold the scoop up and make it easily removeable, it works like a charm, they hold like crazy and the scoop snaps right in place. I took a few pictures and have started the body work, now I can move on to the drl lenses and get the facia painted once and for all.
Old 01-28-2012, 02:48 PM   #75
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Man that's awesome..
Old 01-28-2012, 02:50 PM   #76
CFD
Thanks, I phsyched I can finally move on, that was a sticking point.
Old 02-18-2012, 08:16 PM   #77
CFD
Finally got the mailslot scoop finished, tied in the upper and lower scoops, installed the new lower grille/plate mount and had the facia painted. With the facia back on the car today was the first time I have been able to really drive the car after the VVT-3 cam install and it is running real strong. I can finally move on to a new project, perhaps I'll finish the wheels next. Here's a fewv quick pics.
Old 02-26-2012, 09:51 AM   #78
Moreno Motorsports
Moreno Motorsports's Avatar
Drives: G5.R
Nice job! Are you going to tie it in to you intake?
Moreno Motorsports is offline   Reply With Quote
Old 02-26-2012, 10:01 AM   #79
CFD
Yes, the upper scoop and lower scoops all feed the intake, I originally had them going into the stock snorkel, I am in the process of fabricating a new snorkel that will be much cleaner than the setup pictured.
Old 02-26-2012, 04:20 PM   #80
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
Nice work!
Will you adjust your tune for the additional air?
mike.nite is offline   Reply With Quote
Old 02-26-2012, 04:41 PM   #81
CFD
Originally Posted by mike.nite View Post
Nice work!
The car was tuned before with the lower scoops functional, I have since installed the VVT-3 cam and will be having it fine tuned when everything is finalized.
Old 02-26-2012, 06:54 PM   #82
Moreno Motorsports
Drives: G5.R
Here are some pictures of an intake done for a 69 Camaro. Thought I'd share them with you. Perhaps you can use for ideas on your project. Keep us posted.
Old 02-26-2012, 07:14 PM   #83
CFD
That's a cool set up.
I originally was working on a filter housing behind the facia but decided on keeping the intake tube shorter so decided to fabricate the snorkel so that it is fed by my scoops only and completely sealed from the engine bay but leaving the filter under hood. It will be tied in to an airaid as I had one on before and everything fits that system whereas it utilizes the stock snorkel as the oem intake.
Old 03-09-2012, 08:43 PM   #84
CFD
Finally I am competelly done with tying in all the scoops. I decided to make an aluminum scnorkel similar to the stock one. I increased the size and changed the angle to direct more air from the factory location as well as adding two inlets for the mail slot and lower scoops. I did this in the event I ever was forced to drive in outrageos rain fall, I could easily disconnect the added scoops and still have adequate air flow from the stock location. I was going to take a couple of pics of the snorkel but got involved with the install and forgot but I did get a few on the setup installed.
Although I have been driving the car since the cam install, now with the air intakes finished I can have Ted @ Jannety Racing dial in my tune then I will decide if/or what converter I will get.
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 604 11-13-2017 04:26 PM
Pyr0b0y's SS Build Thread [COTW 5/23/11] pyr0b0y Member Car Journals 825 09-25-2014 01:20 AM
Well, I guess I should start my own build thread. Powhusku Member Car Journals 140 09-23-2013 01:13 PM
Ph4r's Car - Boobies - Build Thread Ph4r Member Car Journals 42 03-20-2013 07:09 PM
Neogenix's 2011 SS/RS BLK/BLK Build Thread neogenix Member Car Journals 7 02-27-2011 11:15 PM
