Old 09-12-2011, 05:27 PM   #15
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
This is needed to get proper camber for road course or autox applications as the stock replacement are shorter than stock and bring camber back to stock specs for lowered vehicles. We can assure you everything here is strong enough to take any abuse people will put to them.
Meister@Torq is offline   Reply With Quote
Old 09-12-2011, 05:38 PM   #16
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
PM a price for a set please to 37042
Old 09-12-2011, 07:10 PM   #17
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
Do you have a set in stock when I visit the shop tomorrow?
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 09-12-2011, 07:13 PM   #18
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Originally Posted by 55Designs View Post
Torq any idea is these control arms make adjusting the compression on the Kwv3 a bit easier because the stock arms and the Spohn arms we use make it a total pain in the ass.
BMR made their control arms to facilitate the adjustments on those particular shocks.
Squintz Palladoris is offline   Reply With Quote
Old 09-12-2011, 09:07 PM   #19
Darkstar November
Drives: 2011 Mustang GT
whoops. wrong thread
Darkstar November is offline   Reply With Quote
Old 09-13-2011, 11:28 AM   #20
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Originally Posted by John@Torq View Post
This is a Pedders Coil Over
Nope.
BMR guy is offline   Reply With Quote
Old 09-13-2011, 11:44 AM   #21
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
We did design a lower "window" into the control arm in an attempt to make adjusting the KW's easier but it is still a PIA. Ideally it needs material removed from the top of the control arm to provide accessability to the shock adjuster but doing so would have weakened the design of our arm...
Old 09-13-2011, 11:57 AM   #22
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Originally Posted by BMR guy View Post
Nope.
Curiouser, and curiouser.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is online now   Reply With Quote
Old 09-13-2011, 12:01 PM   #23
Meister@Torq
Nope.
My mistake. This was an assumption based on what we saw.
Old 09-13-2011, 12:02 PM   #24
Meister@Torq
Pricing has not yet been set....a few more weeks and we will have some in stock
Old 09-13-2011, 12:03 PM   #25
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
Will these arms work with Drag wheels 16" or 17"???????????
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 09-13-2011, 12:14 PM   #26
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Nope.
See, I knew I was right!!
blazzin1 is offline   Reply With Quote
Old 09-13-2011, 12:17 PM   #27
blazzin1
blazzin1's Avatar
I know they are going to be working this winter on a version made specifically to work with the 17" Weld Wheels. But these may work with the 17" Bogarts, I can't say for sure. I'm sure the experts will be along soon. 16's....I would guess not.
Old 09-13-2011, 12:20 PM   #28
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Originally Posted by Avalnch View Post
What is the benefit to an adjustable length rear lower control arm? I don't see how chopping a perfectly good LCA in the middle and putting in a twist point would be an advantage.
It's all about camber. The biggest issue with lowering these cars is rear camber adjustability. The inner bolt on the lower control arm is very limited in its adjustability. Lowering the car more than about 1.375" makes it not possible to get the rear camber back within OE specs. If the customer specifically wants to run lots of negative camber he is fine but doing so will cause excessive tire wear on regularly driven vehicles. To combat this issue we developed our standard Lower Control Arms (TCA028) which are pre-shortened to allow alignment specs within the OE range. This is fine for the majority of customers but since you are still bound by the OE camber bolt, it is still difficult to get camber outside of the OE range of adjustability. For OE height vehicles or vehicles that require aggressive negative camber, we developed the adjustable version of our control arms (TCA029). Our heavy duty 1.125" adjuster allows an inch of adjustment, more than enough to cover OE to 3"+ lowered vehicles.
We are getting close to production on these but may delay the release to revise the outer box slightly for even more wheel clearance. As more and more wheels become available for this application, we continue to "evolve" this product to accomodate as many combinations as possible.
bmr, camaro, control arms, torq
Join Team BMR at the Holley LS Fest!! BMR Suspension Suspension / Brakes / Chassis 7 09-07-2011 01:06 PM
Join Team BMR at the Holley LS Fest!! BMR Suspension Dragstrip and Launch Techniques Discussion 4 09-07-2011 10:02 AM
SNEAK PEAK at our 6LE 2010 Camaro Spoiler... 6LITEREATER Cosmetics and Lighting Modification Discussions 72 05-13-2011 04:44 AM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 11:32 AM
SNEAK PEAK at our 6LE 2010 Camaro Spoiler... 6LITEREATER Exterior Parts & Accessories 2 10-21-2009 08:26 PM
