Cold Air Inductions
Old 09-12-2011, 12:57 PM   #1
crazysyrian720
Drives: SS
CAI question
So I went to my mechanic the other day and asked him about installing my a cold air intake in my ss. He told me that if i get an intake i have to get a programmer for my car and tune the air flow and that itll cost me about 6-700 dollars. He also said its the only way that i can notice a difference in performance and that just getting an intake without a programmer will not make a difference. Does anyone know if this is true? and what intake brands do you prefer? please and thank you
crazysyrian720 is offline   Reply With Quote
Old 09-12-2011, 01:23 PM   #2
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
A. Our systems do not require a tune and get 16 RWHP on a stock vehicle with no tune.
B. You can get a tune and you will see more gains, but it is NOT neccesary or required (at least for our intake) The dealer is trying to get your $$.
Heres a little bit about us:
Cold Air Inductions, Inc. intake systems benefits:
: Tig welded aluminum air box (high luster finish reflects radiant heat)
: Insulated air box (this adding another layer of thermal (convection) protection)
: Aluminum lid with stainless steel ¼ turn fasteners (fast filter removal)
: Viewing window for fast easy filter inspection.
: High Luster ceramic coated intake tube (coated inside and out, yet another layer of thermal protection)
: Smooth bore (88.9 mm) intake tube construction (this minimizes bends and restrictions within the system)
: 8” V-stack air filter with built in velocity stack (helps reduce turbulence for truer MAF reading)
: 8 layer air filter (maximizing filtration for prolonged engine life
: LIFETIME WARRANTY
We have sold thousands of intakes, have thousands of happy customers, and incorporate design features that make our system a true Cold Air Intake. We see great #’s on the Dyno as well as the track, and can keep our intake temps within 2 degrees of ambient air due to our design features.
Check out these links as well:
Testimonials Video - http://www.coldairinductions.com/testimonials
3D Filter Video - http://www.coldairinductions.com/air-filters/filters-in-action/
Let me know if you have any questions, I would be happy to help!!
Sales @ CAI Inc is offline   Reply With Quote
Old 09-12-2011, 02:00 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
It's the act of making the intake more efficient that adds more HP. The stock unit is a good design but it has several places that create turbulent airflow. Turbulence kills airflow. The better CAI's on the market will decrease turbulence while keeping the IAT's close to or at ambient air temps. They also do this without needing a tune. The PCM will adjust for the increased efficiency and properly fuel your car. When companies change the diameter of the tube around the MAF, a tune is needed to reprogram the MAF for the added airflow. To better explain it, the cartridge style MAF is calibrated to a certain diameter tube around the MAF. It determines airflow based off this predetermined circumference along with temps and a few other things. If you change the diameter of the tube, the MAF is still calculating airflow based off the original size. If your tube is bigger, it will allow unmetered air to enter the system, thus making you run lean. There is a science to making a good CAI that adds HP, yet still plays nice with the PCM. Anyone can make a tube with a filter on the end.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-12-2011, 02:55 PM   #4
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
We sell a ton of CAI and Roto-Fab intakes. Both are quality made, look great, sound cool and perform well. That being said we carry tons of options, check out our site and shop around a bit.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 09-12-2011, 04:46 PM   #5
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '112SS/RS'12CruzECO'11CruzeLTZ,Mini
Welcome to the MB crazysyrian720 CAI was my first Mod and yes it makes a difference without a tune. Misinformation out there does everyone a disservice Have been around the block but was new to the 5th Gen. Joined this MB and came here looking for advice as well. Some great C5 Sponsor Vendors and people in the know on here. Case in point are the last replies to you. Free to choose where to go but if you decide to buy, imho buy from a Sponsor. 100% of my Aftermarket parts have came from Sponsor Vendors on this MB 100% Satisfied so far. Hope you are too in the future.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X,Monster Triple,Alky Control Meth Inj Feb12th Install.
SSBUSDRVR is offline   Reply With Quote
Old 09-12-2011, 05:19 PM   #6
crazysyrian720
Drives: SS
awesome thanks everyone! i think im gonna go for it
Old 09-12-2011, 05:25 PM   #7
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
: LIFETIME WARRANTY
So Bill, are you saying that with only your cai installed I can get 16 hp more on a stock SS? No tune required?
bannonm is offline   Reply With Quote
Old 09-13-2011, 08:34 AM   #8
Sales @ CAI Inc
Correct, we see an avg. gain of 15 rwhp on the V8 and 16 rwhp on the V6. These #'s are on a stock vehicle with no tune. Of course if you decide to add a washer bottle and scoop kit you will bring these #'s up about 4 rwhp. Then later if you decide to add a tune your looking at an additional 10-15 rwhp. I can promise you this, if you get our kit you will love it! Let me know if you have any other questions, thanks!
Noob Question: Cat-Back And CAI Powhusku Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 08-25-2011 10:01 PM
question about CAI & Relocation of the washer Bottle luis nunez Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 07-28-2011 11:48 PM
CAI question... mikester0612 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 04-27-2011 09:05 AM
Made my own CAI (Now with pictures)! I have a question though BaylorCamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 33 01-26-2010 09:30 PM
Hennessey CAI Question 2010SSRS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 01-03-2010 11:36 AM
