Elite Engineering
Old 10-19-2011, 07:56 PM   #15
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
-28.7
DietCoke is offline   Reply With Quote
Old 10-20-2011, 10:05 AM   #16
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
Originally Posted by DietCoke View Post
-28.7
Where and how much?
Could this battery be used on a daily driver with an under-drive pulley? ...what are the downsides to this battery?
thanks
Black 2016 1SS A8 NPP
Drag pack, CAI, Headers, Mamo ported MSD intake, Pray ported TB, E85
1/4 - 11.10@122.08
1/8 - 7.15@97.83
+1500 DA 1.64 60 ft stock converter 3740 RW
ULTRAZLS1 is online now   Reply With Quote
Old 10-20-2011, 12:16 PM   #17
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Its a braille #2317, got it from summit. One of the site sponsors prob carries them. Too
Old 10-20-2011, 12:34 PM   #18
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
In colder climates you would want to keep an eye on that lightweight battery on a DD. If you hooked it up to a charger at night it would probably last alot longer. Definately worth it for almost 30lbs.
Squintz Palladoris is offline   Reply With Quote
Old 10-21-2011, 09:48 AM   #19
ULTRAZLS1
ULTRAZLS1's Avatar
I live in Michigan but I put the car up for winter. The car never sees anything below ~45 degrees or so.
Just wondering if it is safe/reliable for a daily driver etc? Any problems with mounting?
1/4 - 11.10@122.08
1/8 - 7.15@97.83
Old 10-21-2011, 12:28 PM   #20
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
I rejust rebent and redrilled the holes in the factory battery mount sides. Uses the factory topplate and holds the battery sturdy.
Old 10-30-2011, 04:22 PM   #21
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Very nice list, thank you sir!
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 10-31-2011, 11:58 AM   #22
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
I talked to an ex-Braille rep recently and he said that they are fine for most late model cars that are driven regularly. They have a low reserve capacity so if the car isn't charging the battery daily they will have difficulty starting. He basically said that they were not recommended for "weekend cars" unless you use a battery tender. Also, with such a low reserve capacity you only get about 2-3 starts on the battery per charge so using them on older, carbureted cars is a no-no...
BMR guy is offline   Reply With Quote
Old 10-31-2011, 12:01 PM   #23
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Since I was harassed to type it out in the other forum , here you go. Additional numbers courtesy of BMR
-6 Airbags (Side Curtain, Seats, dash) (-13.4 pounds)
Dash removed, lightened, tubular steel loop cut off of cross brace, cross brace lightened, sound deadening removed from backside of FW (-30 lbs)
Removed rear seats, belts and brackets, and sheet metal holding bracket mounts (-45.4 pounds)
Weld RT-S & tires vs stock 20s (-85 pounds)
Headers/X/Dumps at axle for weight (-60 pounds)
Tubular front crash support (-12 pounds)
Remove rear crash support (-26 pounds)
!Evap (9.7 pounds, not including evap line, which I left in)
!A/C (-49 pounds)
!Wiper Motor Assy (-9 pounds)
!Junk Block Oil Cooler/Heater, unnecessary (-7 pounds)
Lightweight Billet clutch vs. stock (-12 pounds)
Sound deadening removed from under seats, backseats, trunk, including hood/trunk liner (-8 pounds)
Braille battery (-29 pounds)
Windshield Washer Tank + Pump and lines empty weight (4 pounds)
ITEM
WEIGHT (LBS.)
LOWER REAR SEAT
10.2
UPPER REAR SEAT
28
DRIVERS SEAT
54.6
PASSENGER SEAT
44
A/C EVAPORATOR CORE ASSY.
13.4
A/C COMPRESSOR
13.2
A/C CONDENSER
6.4
A/C-HEAT BLOWER MOTOR ASSY
4.2
A/C LINES AND DUCTING
7.6
A/C FIREWALL COVER
3.6
DRIVERS AIR BAG
1.6
PASSENGER AIR BAG
5.4
SIDE AIR BAG (EACH)
3.2
FIREWALL INSULATION
2.8
FLOOR INSULATION
12
TRUNK CARPET AND WELL COVER
15.2
TRUNK COMPRESSOR
6
TRUNK-LID STRUTS (PAIR)
1
FRONT BUMPER
14.6
REAR BUMPER
26.4
RADIO
4
DOOR SPEAKERS (PAIR)
3.6
FLOOR MATS (FRONT PAIR)
4.8
CENTER CONSOLE
8.2
EMERGENCY BRAKE LEVER W/CABLES
6.2
FRONT SEAT BELTS (PAIR)
6
REAR SEAT BELTS (PAIR)
3.6
FRONT BRAKE ROTORS (EACH)
25.4
REAR BRAKE ROTORS (EACH)
24
FRONT CALIPERS (EACH)
11.4
REAR CALIPERS (EACH)
7.4
HOOD
25.3
HOOD INSULATION
1.2
HORNS (PAIR)
1.4
WIPER ASSEMBLY W/MOTOR
8.6
WINDSHIELD COWL PLASTIC
3.6
DRIVESHAFT – 6 SPEED MANUAL
24
FUEL TANK SHIELD
2.8
DRIVE SHAFT HEAT SHIELD
.8
STOCK AIR BOX
7
ENGINE COVER
4.4
CLUTCH ASSEMBLY (INCLUDING FLYWHEEL)
57
How fun was that removing the dash and evaporator? Did you cut the (2) firewall bolts or pull the windshield? It's pretty ridiculous that the first step in the service manual for replacing an evaporater core is to remove the windshield!
Old 11-18-2011, 07:28 AM   #24
Sawyer
Sawyer's Avatar
Drives: '13 5.0
Thanks for posting.
2013 Mustang GT Black M6
Sawyer is offline   Reply With Quote
Old 09-08-2012, 05:24 PM   #25
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Confirmed drivers seat @ 54.6 lbs.
17" Kirkey pro drag seat @ 14.6lbs with cover, 17 pounds with bracket+brace.
Net savings 37.6 pounds
pouncer72 is offline   Reply With Quote
Old 09-10-2012, 10:48 PM   #26
alex33x
Drives: 2013 Camaro ZL1
No pics of the interior work other then right after I pulled the dash, I didnt take any when I did it. The supports are hiding behind the bumpers, and the dash stuff isn't visible. But yeah, other then brakes/coils I've got a few ideas to get the car to 3500 lbs. It's VERY close. Lexan back glass will drop another 40, and contemplating getting a sheet metal drivers seat to swap in for race days for another 30.
I rather increase the HP in the car with mods, rather than destroying it like that.
Remove the crash support from both front and rear? Seriously?
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 09-24-2012, 01:57 PM   #27
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Back to the topic, has anyone figured out how much weight reduction equals what drop in ET for these cars? Back in the 4th gen days we always said a 100 lbs would be a tenth.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 09-26-2012, 07:35 AM   #28
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Seems to be close to the same from my experience so far, but I haven`t removed anything other than lighter whels exhaust, cai..
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Official 1/8 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 734 07-24-2017 07:17 AM
Cost-Effective Camaro Weight Reduction CamaroFemme 5th Gen Camaro SS LS LT General Discussions 34 12-21-2010 10:52 PM
weight reduction options 2K05GT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-18-2010 08:05 AM
weight loss CamaroSpike23 Off-topic Discussions 8 09-17-2009 07:16 PM
Camaro Weight JeepinMatt 5th Gen Camaro SS LS LT General Discussions 62 03-26-2008 09:17 AM
