Rick@Livernois
Old 09-12-2011, 08:16 PM   #1
sixd8z
Drives: 2010 Camaro SS
trying to fix the wheel hop! any suggestions?
Any suggestions on rear suspension parts to stop the wheel hop and achieve a better launch? I started to look into the lower control arms but not too sure what brands have performed better. Plus they offer both adjustable and fixed so I don’t want to invest in the wrong ones.
sixd8z is offline   Reply With Quote
Old 09-12-2011, 08:27 PM   #2
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Trailing arms seem to be the biggest hit/lowest cost towards getting rid of wheel hop. Many brands out there that all improve on the stock part.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 09-12-2011, 08:29 PM   #3
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Sticky tires. If you never lose traction, you cant hop.
DietCoke is offline   Reply With Quote
Old 09-12-2011, 08:30 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
rear cradle bushings, rear suspension bushings, trailing arms, drag radial tires or slicks, lower control arms, *that's all I can think of now*
There really is no "wrong" answer as to whether adjustable/non-adjustable. Depending on what your needs are, that's the one you get. I would talk to some of the guys from Pfadt, Pedders, BMR, etc about what you are trying to do with the car and then they can help you get the right set up.
Click to view my build thread
Old 09-12-2011, 08:42 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The "wheel hop trifecta" for these cars is rear trailing arms, toe rods, and bushings (rear cradle and differential). Those three things will generally take care of wheel hop for most 5th gen Camaros.
Old 09-13-2011, 10:10 AM   #6
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
What he said
Chase is right, minimizing suspension deflection will minimize wheel hop. The three biggest contributors to this are the Trailing Arms, Toe Rods and Cradle Bushings. Trailing Arms control wheel movement forward and rearward while Toe Rods control toe variation, insuring that the tires are always pointed in the right direction. The Cradle Bushings locate all of the rear suspension and driveline making them a very important factor for handling, acceleration, braking, and traction.
Trailing Arms will usually reduce the majority of your wheel hop and are the easiest (and most economical) to install. If you want to save some money, start there and see how the car responds. If they don't control your wheelhop, then do the other two. The Toe Rods and Cradle bushings should be done at the same time since you must lower the cradle to do both.
BMR guy is offline   Reply With Quote
Old 09-13-2011, 10:17 AM   #7
BLACK10
BLACK10's Avatar
I did the whole BMR rear suspension upgrade and it cut 7/10ths off my 1/4 mile time
Old 09-13-2011, 11:28 AM   #8
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Great feedback, thanks!!
Old 09-13-2011, 11:52 AM   #9
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
i have most of these things i can say u need them all...i still need stickys and i need a couple of others mods, the subframe bushings and trailing arms alone helped out a lot however
ipimpthisc is offline   Reply With Quote
Old 09-13-2011, 04:17 PM   #10
Apex Motorsports
Very nice! Most people modifying their cars get too focused on adding horsepower and forget about supporting mods. You can make all the power in the world but if you can't put it to the pavement it doesn't matter.
Old 09-13-2011, 07:54 PM   #11
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
well said.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 09-13-2011, 08:10 PM   #12
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
+1 and a big +1 to BMR for some great parts.
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 09-13-2011, 08:24 PM   #13
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Brett,
What rear toe settings do yall use on the red car at the drag strip? How will different toe settings effect straight line traction?
Thanks!
Brad
Squintz Palladoris is offline   Reply With Quote
Old 09-13-2011, 09:05 PM   #14
sixd8z
Thanks for the info. I talked to a couple manufactures today and felt most comfortable with the knowledge of the BMR guys. I ordered rear trailing arms, toe rods, and a bushing kit. Guess I’ll see what happens!
Different Wheel Construction Types Explained Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 44 07-06-2016 08:51 AM
BMR or Pfadt Trailing Arms ITGuy11 Suspension / Brakes / Chassis 55 05-20-2011 12:26 PM
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 05:00 PM
Wheel hop or something else? blufin Dragstrip and Launch Techniques Discussion 6 10-16-2010 11:25 AM
wheel hop Gr8_syder 4th Generation Camaros 8 02-09-2010 04:24 PM
