Solo Performance
Old 09-12-2011, 09:43 PM   #1
blk5genss
blk5genss's Avatar
Drives: 2010 Camaro 1SS/RS
Rear Drag Suspension Question?!
I am trying to set up the rear suspension on my 2010 ss for the drag strip/daily driving! the plan is getting a set of 1400hp DSS axles, 50/50 Lakewood Shocks, and a Spohn drag sway bar! The question is has anyone tried any of these products and have any of them worked? Have they reduced 1/4 mile times or 60ft times? Any help will be appreciated!
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
blk5genss is offline   Reply With Quote
Old 09-12-2011, 09:47 PM   #2
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
If you aren't on sticky tires, the drag bar won't do anything for you. The DSS axles are great!
DietCoke is offline   Reply With Quote
Old 09-12-2011, 10:25 PM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Take a look at the BMR Drag Bar instead of the Spohn. I can't really say that one is better than the other, or how either may perform at the track...mainly because I haven't made it to the track since I put my BMR Drag Bar on. But considering Spohn's rather lackluster customer service history, I would certainly rather support BMR who is on these boards every single day trying to help us out.....just my .02 cents.
blazzin1 is offline   Reply With Quote
Old 09-12-2011, 10:31 PM   #4
blk5genss
blk5genss's Avatar
Sorry I neglected to mention the fact that my nitto nt555r's will be on the car this week, so I will be going to the track friday and hopefully gettina few successful passes down the track without hurting anything. My local shop quoted me 300 bucks for the install, is this about right? I will look into the BMR sb but didn't even know they had one till you mentioned it! LOL the only reason I looked at the spohn one is bc I have their LCA's and think they work ok just need a little more help with the added hp from the cam, fast intake and retune! thanks for the input so far!
@ Blazzin1,
how does it feel on the street?
Old 09-13-2011, 10:54 AM   #5
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Thanks for the plug
...and let us know how your car does with the new bar installed!
BMR guy is offline   Reply With Quote
Old 09-13-2011, 12:10 PM   #6
blazzin1
blazzin1's Avatar
Originally Posted by blk5genss View Post
@ Blazzin1,
My experience so far has been outstanding. The install was easy, and I can't imagine the quality could be any better. It is a "monster-beefy" bar compared to the stocker!!! And it comes with the End-Links too. Certainly...no mushy lean on the street!!! I would highly recommend BMR......all the way.....with no doubts!!!
Old 09-14-2011, 10:23 AM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Here is a qiuck picture of the BMR drag sway bar for the 2010 Camaros, if anyone has any questions let us know.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 09-15-2011, 01:10 AM   #8
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
I would suggest going with Pfadt Solid Sub-Frame Mounts, the Pfadt Rear Arm Package, Pfadt Drag Bar and if your budget permits a set of Pfadt coilovers. We've been running this combination for awhile now and it works VERY WELL!!! I generally run the rear sway in the center hole and the rear shocks at 14-18 depending on the track prep. I set the front to full soft and be ready to hook UP!
I've also have experience with the BMR product and I like it a lot! We'll have to get some more local cars running it in the near future! Please feel free to call, email or PM me anytime with questions.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 09-16-2011, 12:59 PM   #9
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Thanks JDP. You don't need to go to a dedicated drag setup to see good improvements in your drag times. Unless the car is going to spend most of it's life at the strip, we strongly recommend our coilovers for some nice gains that can be felt on the strip and on the street.
Supporting modifications in this case will make a huge difference as well. Trailing Arms and Solid Subframe mounts will keep the entire rear end from bounding around while trying to get out of the hole. It's generally wheel hop that kills parts, and the best improvement to effectively put your power down and kill the wheel hop are with Trailing arms and Solid Subframe mounts.
Old 09-17-2011, 04:42 PM   #10
blk5genss
blk5genss's Avatar
@PfadtRacing
Can you pm me your recommendations along with some prices? I went to the track last night on NT555r's (305-35-20) and was still only cutting 12.69@115 with an 8.49@89 in the 1/8! 2.19 60ft was the best however the worst was only a 2.30 this time. I do beleive the track prep was not up to par, but no excuses, I want to hook on the street and the track the car will be an all around daily driven car so what you mentioned earlier sounds like a plan! 1400hp dss axles are in the works as well!
Thanks,
Jesse
Old 09-17-2011, 07:17 PM   #11
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
What tire pressure are you running the 555s at?
HufferSS is offline   Reply With Quote
Old 09-18-2011, 12:30 AM   #12
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
555rs arent very sticky as far as drag radials go. How low pressure?
Old 09-18-2011, 03:41 PM   #13
blk5genss
blk5genss's Avatar
26 lbs I know this is way to high but didn't want to drive home for an hour until I could get more nitrogen. So when I go to San Antion Raceway then I will go down to around 18-20 lbs. On the street they hook great and no road noise. I like them for everyday driving but not the most hooking tire when the track isn't prepped, I had them on my fox body and never had a problem!!
Old 09-18-2011, 04:52 PM   #14
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Get rid of the nitrogen and just use the compressor at the track to re fill.
How are you launching? What rpm? Dumping the clutch or slipping it?
Oh and the Fox body didn't make as much power, and weighed alot less. Plus it had a live axle and a suspension that is better suited to drag racing.
Squintz Palladoris is offline   Reply With Quote
Poll -- Camaro vs Mustang Supercar Shootout JusticePete Suspension / Brakes / Chassis 105 10-09-2013 03:18 PM
HOW TO: Get rid of UNDERSTEER on C5 member Buffnshine's Camaro PfadtRacing Suspension / Chassis / Brakes 6 08-31-2011 10:51 AM
G-Force Rear Suspension and Halfshaft Upgrade! Pics Mike TexaSS Suspension / Brakes / Chassis 11 02-07-2010 07:46 PM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
Independent Rear Suspension? steveo42 Wheels and Tires Talk Sponsored by The Tire Rack 35 05-22-2008 06:58 PM
