sjm autoprod
Old 09-12-2011, 09:55 PM   #1
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
Timing bushings
I know it is a smart idea to get your suspension alignment done early.. I hear some suppliers mention timing your bushings. I tried searching, but didn't see what the purpose was.. what are the benefits?
I am trying to find a shop that does alignment and bushings in one pop... hopefully not break the bank.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 09-12-2011, 10:03 PM   #2
Camaro427
Drives: 2010 SS2 Camaro
Unless you have installed new drop coils or coilovers, you do not ever have to time the bushings doing an alignment
Camaro427 is offline   Reply With Quote
Old 09-12-2011, 10:06 PM   #3
brantley847
v It bites.
Yes...Sorry, I forgot to mention. I am installing the bushings with 1 inch drop springs and sways
2011 2SS/RS
Old 09-12-2011, 10:08 PM   #4
Camaro427
No problem. When the vehicle is on the alignment rack with the tires on the ground, they should loosen the front and rear control arm bushings, jounce the car as much as they can, then retighten, It is a really easy thing to do,
Best of luck
Old 09-12-2011, 10:20 PM   #5
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
Hey guys i will also be doing alot of suspension upgrades over the weekend... Craddle, differential, front radious, sway bars, end links, subframe connectors... But not lowering the car. I will be keeping my stock factory springs!! Do i have to time my bushings???
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
BAWLZ SS is offline   Reply With Quote
Old 09-12-2011, 10:48 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
No...you shouldn't have to. As long as you don't change the ride height you shouldn't need to time the bushings.
Build Journal
Old 09-12-2011, 10:50 PM   #7
caverman
caverman's Avatar
OP...do a search. There are a few threads with the info you are looking for.
Here is one
http://www.camaro5.com/forums/showth...ghlight=timing
Build Journal
Old 09-12-2011, 10:52 PM   #8
brantley847
v It bites.
Here is one
You sir... must have the magic searching touch...
2011 2SS/RS
Old 09-12-2011, 10:57 PM   #9
caverman
caverman's Avatar
Nope...I struggle with the seach sometimes. I just knew there was one fairly recent and found it pretty quick.
BTW: at least in this area it would probably cost $125 - $150 to time the bushings and get a good alignment. You can time your own bushings if you can't find someone that knows how to do it however it will be a lot easier to do it at one stop.
Build Journal
Old 09-13-2011, 10:24 AM   #10
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Here is a link to our recommendations for re-clocking (timing) the bushings:
http://www.camaro5.com/forums/showthread.php?t=153188
As long as the bolts are tightened with the weight on the suspension you will be fine. Lowering is the only reason you need to re-clock bushings but for the same reasons you should never tighten suspension bolts with the wheels hanging...
BMR guy is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 290 02-10-2018 10:11 AM
Timing bushings gtfitter597 Suspension / Brakes / Chassis 41 07-09-2014 12:02 PM
Put More Power To The Pavement With Pfadt Engine Mounts And Differential Bushings!!!! Apex Motorsports Transmission / Driveline 28 11-27-2010 11:46 AM
Urethane Bushings from Energy Suspension Bewenched Suspension / Chassis / Brakes 1 04-30-2010 06:12 AM
