Old 09-13-2011, 12:29 PM   #1
hillbennerdeluxe
the legend
hillbennerdeluxe's Avatar
Drives: 2010 Camaro 2SS 6 speed manual
2010 Camaro SS/2 misfired spark plugs are junk.
hello all,
Just wanna worn everyone of the crappy spark plugs put in a factory. My Camaro had to be picked up and towed to the dealer cause it wasnt wanting to run right. end up the spark plugs r crap from factory. They r known to break at the ceramic. Just wanna give a heads up to everyone that they might want to check there plugs or do what i am doing and buy better ones so i don't break down and hour away from home!
hillbennerdeluxe is offline   Reply With Quote
Old 09-13-2011, 01:49 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I can honestly say that you're the ONLY person that i've seen post about bad plugs from the factory. Many shops swear by the OEM plugs. Sometimes things happen. Bad engines, trannies, struts, etc. Doesn't mean they are shit parts, you just got a bad one.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-13-2011, 01:59 PM   #3
siriusdish
Drives: 2010 Camaro L99
Search for my spark plug thread, sure oil did not cause it???
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 09-13-2011, 10:14 PM   #4
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Seems odd. Delco makes a fine plug.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 09-13-2011, 10:49 PM   #5
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
Millions and millions of Delco Spark plugs with no problems. Hmmmm...
MRGOODWRENCH3 is offline   Reply With Quote
Old 09-14-2011, 07:51 AM   #6
Infern0
Bring It
Infern0's Avatar
Drives: '17 Camaro ZL1 (M6)
Hmmmm, not likely.
2017 Camaro ZL1 M6 - Everything but the sunroof - New Daily Driver! Commuting has never been so fun.
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 09-14-2011, 08:00 AM   #7
bi11ymc
"Silver Street"
bi11ymc's Avatar
Drives: 2010 2SS/RS L99
The only time I have heard of spark plug failures is after a header swap with the spark plugs in. Bump them during install and they can crack.
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing
bi11ymc is offline   Reply With Quote
Old 09-14-2011, 10:01 AM   #8
MikeOD
Drives: 2010 M6 2SS
I had a friend with a 94 Vette chase an issue for MONTHS that turned out to be a junk plug...but he didn't have headers on it, and they weren't AC Delco plugs by then either. Other than his car though...the ONLY time I've ever seen plug issues is like you said...if you bump one working on the exhaust manifolds/headers.
For what it's worth, at 30K my plugs all look great...I had them out sunday while I put my longtubes in...they looked perfectly fine, so I stuck them right back in the heads.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 09-14-2011, 02:36 PM   #9
cruznls
cruznls
cruznls's Avatar
Drives: 2010 CAMARO
Cool
Any plug can crack... possibly the installers fault...
cruznls is offline   Reply With Quote
Old 09-14-2011, 04:18 PM   #10
bucketobolts
bucketobolts's Avatar
Drives: 2010 2SS
My name is Bolts, and I'm a AC-Delco plug user. Been using in all my GM products since 1990...never a problem. Though I'd like to have nickle for every Champion or NGK I have removed to fix a drivability problem. I'll leave them for the imports and bikes.
bucketobolts is offline   Reply With Quote
Old 09-14-2011, 05:28 PM   #11
Brian@LGMAC
Drives: a slow 2010
NGK makes AC Delco plugs
Brian@LGMAC is offline   Reply With Quote
Old 09-14-2011, 06:07 PM   #12
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
I am guessing this guy just did a header swap.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 09-14-2011, 07:41 PM   #13
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 99 Silverado
HI BOLTS!
molsonbrador is offline   Reply With Quote
Old 09-14-2011, 07:46 PM   #14
siriusdish
Oh the other side was cracked, well never head of that unless trying to break car windows, ha ha
2010 L99
A lot of complaints that the Camaro seems very large. OHIOSS 5th Gen Camaro SS LS LT General Discussions 71 03-01-2011 02:10 AM
