Emblempros
Old 09-14-2011, 02:09 AM   #1
Judge
Judge's Avatar
Drives: 2011 L99 Camaro SS
How would you add power to your L99?
Which way do you prefer to add power to your L99 engine?
Forget about forced inductions, I want to know about your mods like Camshafts, Piston Heads, and so on.
Been researching camshafts for the L99 and found out they're pretty tricky due to the Active Fuel Management and other electronics in the engine.
So It'd be interesting to know your methods of adding more horses.
Judge is offline   Reply With Quote
Old 09-14-2011, 03:23 AM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
You can ad a CAI, longtube headers and do the L99 to LS3 conversion. Vengenace Racing is telling me that would get me 420-440 at the back wheels. If I got 440 that would be 100 more HP than I have now at them.
Scott@Bjorn3D is offline   Reply With Quote
Old 09-14-2011, 06:13 AM   #3
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
See signature. Yes, the L99 to LS3 conversion is more, but worth it in my opinion. However, there are now some pretty stout numbers using a VVT cam. My concern with the VVT cam (unfounded of course) is durability.
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 09-14-2011, 07:08 AM   #4
Judge
Judge's Avatar
More on the L99 to LS3 conversion please (details)
Also, don't you think wen you convert your engine to an LS3, you kinda lost its true identity as an L99 automatic? Thats my opinion though
Old 09-14-2011, 08:10 AM   #5
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
You still have lower compression pistons.
L99 to LS3 conversion involves deleting the AFM/DOD.
From TSP ($390): LS2 Chain Dampener, Qty 8 (or 16) LS7 Lifters, LS2 Lifter Trays, LS3 Head Gaskets, GM LS2 Head Bolts, LS3 Valley Cover, PCV Hose, PCV Plug, Cam Swap Gasket Kit.
Deleting the VVT:
(From TSP $110) LS3 Front Timing Cover with Cam Position Sensor and Harness, 3-Bolt Cam Gear (4X), and ARP Camshaft Bolts.
Then you add an LS3 Cam (~$400) and springs/etc (~$600+).
On the other hand, to your original question:
Look at my Build Journal (sig) for the bolt-on approach to knock a full 1.2 seconds off your 1/4 mile times and add approximately 50RWHP. Bolt-ons, torque converter, and good rims will get you there.
After you've done the bolt-ons, then you can add a VVT cam (delete AFM/DOD, but keep the L99 "identity" with the VVT).
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 09-14-2011, 08:27 AM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
heres the thing though, most shops and people would rather work with a more older v8 style. not saying you cant use the VVt in the l99. but i feel better doing what my shop feels better with.
you can find a lot of info if you google.
Old 09-14-2011, 08:34 AM   #7
Padre
Padre's Avatar
That's the nice thing about the TSP cam. They send you the VVT phaser tables. The rest is gravy. My shop will be doing their first VVT cam.
Padre
Old 09-14-2011, 08:43 AM   #8
Andy@Livernois
Andy@Livernois's Avatar
Drives: 1987 Buick Regal Turbo-T
typically, with your quest, we would recommend our 2c cam, which deletes the vvt and dod system, as well as a roto-fab cai, and kooks long tube headers. Typical power for this is 430-440 rwhp, with no loss in low end torque. It even works well with the stock converter!
We actually are running a special on it this month too, I am not certain where you are located, but we have had numerous people state that even with paying for transportation (which we offer) it's still cheaper than many prices they have found locally to them.
Andy@Livernois is offline   Reply With Quote
Old 09-14-2011, 08:44 AM   #9
FTI-EDC
The stick man
FTI-EDC's Avatar
Drives: 2004 GTO - C5 'vert - SRX
Cool
Just contact Mike at New Era Performance. The N.E.P. L99 project car is a fully streetable, mid-eleven second package.
There are those who talk about and then there's New Era Performance who actually do it!
NEW ERA PERFORMANCE PARTS
PONY WARS
FTI-EDC is offline   Reply With Quote
Old 09-14-2011, 09:08 AM   #10
Jason 98 TA
Drives: Camaro
We have run 11.20s with our heads/cam L99 camaro. Our pacakge uses the VVT-3 camshaft which has been proven to add 100 flywheel horsepower from the camshaft alone! Combine that camshaft with either the PRC CNC Ported LS3/L99 heads or the all new PRC Aftermarket casting LS3/L99 heads and you have huge power potential. Either combo will make big power, the aftermarket casting heads typically make some additional power over the stock ported heads thanks to smaller runners, smaller chambers, and improved air flow!
http://www.texas-speed.com/c-234-cam...c-engines.aspx
http://www.texas-speed.com/p-1388-pr...e-program.aspx
Jason 98 TA is offline   Reply With Quote
Old 09-14-2011, 09:20 AM   #11
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
If it was my L99 I would change to lower rear gears first, like 3:70's. Although you do not add HP you add performance improvement. Then, like Andy at Livernois says above, go to the motor and do LS3 conversion. Your redline will go from 6,200 to 6,800 by eliminating VVT cam and VVT lifters and cam phaser plus you have many more cams to choose from to meet your needs and expectations.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 09-14-2011, 11:39 AM   #12
Jason 98 TA
Drives: Camaro
Absolutely not true at all. The VVT is not limiting the redline to 6200. I have run VVT past 7800rpm without any issues.
Swapping in a LS3 conversion is what you do when your not comfortable with VVT technology. That's exactly the reason we offer VVT tune tables with our camshaft. That way you make 100% your VVT setup is phased correctly.
Checkout the fastest N/A list. I think you'll find our L99 stock motor car outrunning just about every na car including the strokers.
What you have to ask your self is do I want the best possible power at every rpm point or just at the hp peak? If you don't care about bottom and mid range power maximization then buy a standard camshaft. If you'd like better power output throughout the rpm range then VVT will allow you to do that.
Old 09-14-2011, 12:51 PM   #13
jthurik
Drives: 1
how about a 125 shot.....
jthurik is offline   Reply With Quote
Old 09-14-2011, 01:20 PM   #14
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
#Winning. Contact me, please.
StlRomAniaN is offline   Reply With Quote
Stock L99 A6 Supercharger options, opinions, & experiences 2010 Bumblebee Forced Induction - V8 106 07-14-2014 04:17 AM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Engines - How to make the L99 give the same power as LS3? jezzaaa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 02-18-2010 10:33 PM
GMPP headers, exhaust, CAI add no POWER 1camaro70 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 87 10-03-2009 08:50 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
