Old 09-15-2011, 12:21 PM   #1
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
Race Ready Cutouts
Hey guys, quick question.... After a lot of research I am deciding to go with Race ready cutouts.... mainly because of the lifetime warranty and block off plates should they fail. I am going in for LT's, cat delete, cam, and a tune in 2 weeks . I plan on running them where the cats were.... Their low profile kits come in 2 1/2 or 3 inch. What size do you recommend? Thanks
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 09-15-2011, 12:30 PM   #2
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
I've been running the 2 1/2-inch Race Ready's for two years, and I highly recommend them. I don't think you can go wrong either way.
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 09-15-2011, 12:43 PM   #3
Rage
Rage's Avatar
Did you do the down turns also? Or swivel tips? Just curious if they are necessary.
Old 09-15-2011, 12:52 PM   #4
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
i like the remote instead of a switch....post some pics when your finished
bmbbl be is offline   Reply With Quote
Old 09-15-2011, 12:54 PM   #5
kmcd
kmcd's Avatar
I used the turndowns. It's good to get the exhaust down into the slip stream beneath the car.
Old 09-15-2011, 12:59 PM   #6
kmcd
kmcd's Avatar
I mounted the switch on the console. It works well, and it looks like an OEM switch.
Old 09-15-2011, 03:26 PM   #7
Rage
Rage's Avatar
Hey guys, they will give me a 7% discount on my purchase, but if someone else gets in on it we both get 15%! Anyone interested?
Old 09-15-2011, 04:18 PM   #8
faSSt
**Sold n' Sad**
faSSt's Avatar
Drives: 11 F150 Supercrew FX4 5.0
Is this direct from race ready? How much are we talking? I might go in.
2011 Camaro 2SS, SIM, 6M, HUD, 10% tint, black out lenses, SS emblems, TSP 304 LT's, Roto-Fab, MGW shifter, gto res, 8K BFXENON, HP Tuners, Redline Fluids. ***Sold*** Now in an 11' F150 supercrew FX4.
Still addicted to the this forum
faSSt is offline   Reply With Quote
Old 09-15-2011, 04:37 PM   #9
kmcd
kmcd's Avatar
If you guys end up doing this, I have an installation tip:
I ran the wires for the switch up through the drain plug in the floor pan, then under the carpet to the trim on the side of the console. If I had it to do over again, I would route them up through the tunnel, underneath the console. That way the wires are not exposed under the subframe. Use a utility knife to cut a hole for the switch cradle in the trim. Don't worry about how the cut looks. As long as it is smaller than the molding around the cradle, it will look factory after you slide the cradle into place. You can tap into the charging receptacle behind the rear trim on the console for your 12 volts. It makes for a very clean installation.
Old 09-15-2011, 08:39 PM   #10
SShift
SShift's Avatar
Drives: Only Bowties!
What yourself with race ready. The warranty is a scam. they charge you a processing fee to repairs and shipping both ways. They also do not make a low profile one like QTP which is meant for 5th gens. Go with QTP low profile cutouts you will thankful in the long run.
SShift is offline   Reply With Quote
Old 09-15-2011, 10:14 PM   #11
kmcd
kmcd's Avatar
They sent me a new switch when mine went bad a year and a half later, no questions asked, and it didn't cost me a dime.
Not sure what your beef is?
QTP makes a good product as well. I just didn't want to fumble around for a remote every time I opened or closed the valves. In addition, I wanted the turndowns so I could vent the exhaust away from the underside of the car.
I can't remember if QTP offers a lifetime warranty, but I do know that no matter who makes them, the valves will eventually need to be replaced. With the Race Ready cutouts, you have the option to run them open or closed (with the blankoff plate) while you wait for the replacements.
By the way, what's the weather like there in the "Depths of Hell"? It can't be much hotter than it's been here in Texas.
What song are you listening to right now Muscle Master Off-topic Discussions 6390 01-05-2018 10:22 PM
The Official Camaro5 Fest II Track Assault By Pfadt Race Engineering PfadtRacing Suspension / Chassis / Brakes 466 09-16-2011 12:57 PM
Gran Turismo 5 November 24th, 2010 Nezacant Gaming Lounge 562 04-21-2011 10:23 PM
Gforce Engineering 2010 Camaro race axles just about ready for testing GFORCE1320 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 18 01-28-2010 08:56 PM
Factory Drag race ready Challenger 35th02ss General Automotive + Other Cars Discussion 31 08-25-2008 11:13 AM
