Old 09-15-2011, 12:54 PM   #1
JWoj3540
JWoj3540's Avatar
Drives: 2012 2SS/RS M6
Having the stock SS rotors to be drilled and/or slotted
Are there places where you can take your stock rotors and they can actually drill and/or slot them for you? As opposed to buying new rotors that are already drilled/slotted, I imagine this is more cost effective, especially if the stock rotors are essentially brand new and you don't want to waste them.
Anyone know of some reputable places in the Detroit area that do this?
Thanks!
JWoj3540 is offline   Reply With Quote
Old 09-15-2011, 02:02 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
I don't know enough about brakes to say this with confidence, but I don't think you can drill rotors after the fact.
Click to view my build thread
Old 09-15-2011, 02:18 PM   #3
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Yeah, idunno about doing it, the rotors are designed a certain way, when that way is changed after the fact, there are different stresses and weak points introduced.
It may very well lead to early failure, in a really bad way.
Plus, cross-drilled rotors aren't really good if you are often in heavy braking situations like the track, they often like to crack under hard usage.
JDP Tech is offline   Reply With Quote
Old 09-15-2011, 07:48 PM   #4
mikeyroche
Drives: 2011 VR Camaro 1SS/RS M6
Would highly advise against that and just upgrade to drilled or slotted. I'd rather spend the money on other parts, but I want to make sure the brakes are perfectly sound and top performance. I'm upgrading to the Brembo Sport slotted and really the price isn't that bad
2011 Camaro 1SS with RS - K&N Typhoon CAI, Borla Atak Exhaust, Hawk Performance Ceramic Pads, SLP 'SS' Front Grille Emblem, Blue LED interior lighting, Camaro Victory Red Seatbelt Harness pads NEXT - Corvette LS3 Victory Red Fuel Rail Covers(Awaiting Installation), Window Tinting, Custom Leather Interior.
mikeyroche is offline   Reply With Quote
Old 09-15-2011, 10:16 PM   #5
L99CAMA2011
L99CAMA2011's Avatar
Thanks!
From past experience I highly recommend you guys to stop being cheap and buy well engineered pre drilled rotors. Drilling plane face rotors will lead to cracking and warping. May look cool but not worth the consequences.
Old 09-16-2011, 07:57 AM   #6
2quick
Drives: none
We sell stock rotors that have been slotted. Its is not recommended to drill them.
2quick is offline   Reply With Quote
Old 09-16-2011, 08:31 AM   #7
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Brakes are one of the last places you want to cut corners!
DarkneSS is offline   Reply With Quote
Old 09-16-2011, 10:35 AM   #8
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
I don't think he new that you shouldn't do this. I REALY think he just needed to know if it was possible which it's not. Like it's been said you need new ones if you go drilled or slotted.
chevy 3 is offline   Reply With Quote
Old 09-16-2011, 02:06 PM   #9
JWoj3540
JWoj3540's Avatar
I hear you guys loud and clear. Thanks for the knowledge.
Old 09-18-2011, 02:33 PM   #10
Mike2ss
Airborne Pathfinder
Mike2ss's Avatar
Drives: Camaro ZL575
buy a set, they are not that expensive
2010 Camaro Indy 500 Pace car, LS3-ZL575
Other cars are- 95 BMW 325 sedan- AA exhaust, AA CAI, AA Strut bar, AA chip, M3 rotors and calipers, racing clutch, oversized injectors, upgraded M3 interior- Audi A4 SLine, with black out optics
Mike2ss is offline   Reply With Quote
Old 09-19-2011, 11:17 AM   #11
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
There are companies like this that can drill or slot rotors:
http://www.brakewarehouse.com/rotor_...g_slotting.asp
It definitelycan be done but it has to be done correctly to prevent heat cracking. The ones that do it right know all the secrets and you end up paying almost what a new set costs (or more sometimes). Rotors that are specifically designed with gassing holes are vented differently and go through a different manufacturing process than a factory rotor so no matter how good the shop is, the rotor will never be as good as one designed this way. Companies like I listed above specialize in this mostly for obscure vehicles that don't have a large range of aftermarket suppliers. The new Camaro has so many options, I doubt you caould get it done cheaper than buying a set of drilled or slotted rotors.
BMR guy is offline   Reply With Quote
Old 09-22-2011, 08:22 PM   #12
JWoj3540
JWoj3540's Avatar
Thanks BMR guy...I figured someone had to be doing it
OEM SS Rotors, Lines, Pads, Bowtie Delete, And V6 Brake Set Up Aequitas & Veritas Suspension / Chassis / Brakes 38 09-04-2015 10:50 AM
2010+ Camaro StopTech Drilled Rotors & Power Slot Slotted Rotors | Cyro Treated! AutoAgenda Suspension / Chassis / Brakes 37 02-02-2013 09:12 PM
For sale - Stock 2010 SS rotors front and rear topgun1 Suspension / Chassis / Brakes 5 01-14-2012 05:14 PM
