Old 09-15-2011, 02:18 PM   #1
scottywheels
Drives: 2010 A6 SS/RS
Jannetty Racing-Moroso True Subframes and other parts Pics inside.
Jannetty racing is now offering the new Moroso subframe connectors, Moroso oil/water catch can, Moroso performance wires, Drive shaft loops and more coming out next week. Here are some pics of whats going to be available. call Jannetty racing for any questions.
Scott(Retired Navy)(Paralyzed Triathlete)
New Car 99 Camaro SS with Dart 427, F1x, Rossler 210, 9 inch and BS3... scary ride
SOLD
2010 A6 ss/rs White-VORTECH YSI/LPE fuel system/ID 850's/LG Motorsports full Exhaust/Protorque 3400 stall/Livernois Stage 3 Heads/Cam/Bogarts/ Moroso subframes/JRE Rear with 3:70 gears/Aluminium DS/line lock/drag alignment/Suspension/JW Racing 10 pt cage/13.6 psi 719.34 rwhp 558.4 TQ/ Best Pass 1.51 60ft 10.08 136.78 mph JRE Built
scottywheels is offline   Reply With Quote
Old 09-15-2011, 02:22 PM   #2
scottywheels
when testing these subframes, we saw 1/2 less body twist when doing the front tire test to see when the back tire come off the ground. These are definatly going to help in the overall performance of the car. And they are not tied into the rear independant so it is still able to do what it was ment to go from the factory.
SOLD
Old 09-24-2011, 06:34 PM   #3
scottywheels
60ft went from 1.71 to 1.65
SOLD
Old 09-24-2011, 09:23 PM   #4
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
Are those bolt on or weld-in? Will they work with 3" exhaust. I had to space my down.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 09-24-2011, 09:31 PM   #5
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Looks like a 3" system and a bolt in not weld in those photos.
Squintz Palladoris is offline   Reply With Quote
Old 09-24-2011, 09:35 PM   #6
Squintz Palladoris
Scotty, looks like these bolt into the rear subframe at the front bushing. Does it just use a longer bolt there?
Old 09-25-2011, 11:33 AM   #7
scottywheels
yes these can be welded in, they bolted mine in because its an easy install...
that is 3 inch exhaust on my car and it fit perfect, just had to loosent he exhaust and move it up a bit and tighten it down.
the bolt in the rear irs is longer yes...
SOLD
Old 09-25-2011, 11:36 AM   #8
scottywheels
Originally Posted by Squintz
Palladoris;3798176
ties in at that bolt, but other subframes built by other companys go further to the rear of the car into the actually movement and flex of the IRS. these are perfect
SOLD
Old 09-25-2011, 12:36 PM   #9
navyblueSS
Drives: 2002 Camaro SS
Nice, they look good.
2015 1LE - CAI intake, TSP longtubes,
NPP, Futral Motorsports tuned, BMR 1"lowering springs, BMR trailing arms
navyblueSS is offline   Reply With Quote
Old 09-25-2011, 01:57 PM   #10
blk5genss
blk5genss's Avatar
Drives: 2010 Camaro 1SS/RS
What's the price tag? Also since they are designed to tie in and stop the twisting, is there still a need for the aftermarket cradle bushings or does it solve that problem?
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
blk5genss is offline   Reply With Quote
Old 09-25-2011, 01:59 PM   #11
Squintz Palladoris
Ace, this does not affect the rear cradle movement due to the way it mounts. You would still need to put either inserts or a stiffer bushing in the rear cradle to control the movement.
Old 09-25-2011, 02:03 PM   #12
looks great, where did you get the chrome moroso covers under the hood
Old 09-25-2011, 02:48 PM   #13
ducatisl
Emerald Coast Camaros
ducatisl's Avatar
Drives: 2010 2SS 6m
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
So it's one solid piece? That's a nice 60ft improvement.
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread
ducatisl is offline   Reply With Quote
Old 09-25-2011, 02:58 PM   #14
nitto85
Caffeine Injected
Drives: Chevrolets!!
wow
nitto85 is offline   Reply With Quote
