JDP Motorsports
Old 03-30-2009, 07:19 PM   #1
The BIRDman
Master ****sman
Drives: 1991 silverado
superchargers/turbochargers & mpg
exactly how much do superchargers/turbochargers affect mpg?
in relevance to a camaro ss that is.
The BIRDman is offline   Reply With Quote
Old 03-30-2009, 07:57 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
depends on the charger and setup
I piss excellence
and fart awesomeness
Old 03-31-2009, 04:05 AM   #3
fierodeletre
Drives: 02 WS6 TA, 88 Fiero Formula
Typically, traditionally, a turbo setup better allows you to keep some of your mpgs as you can 'nurse' the engine to not make as much boost. That being said, there's still the facts of exhaust restriction and (hopefully) larger or higher flow injectors, so... The other factor to consider in both SC and TC is that the engine will make more power at a lower RPM, meaning that you won't need to down shift as much, which helps mileage a bit. wither way, if you're looking at mpgs, FI might not be your thing.
fierodeletre is offline   Reply With Quote
Old 03-31-2009, 08:08 PM   #4
O2BQIK
Drives: 1991 Camaro RS
In my '98 Camaro SS with twin turbos, I got around 15 to 18 mpg on a tank, depending on how much highway time and how much I got my foot into it. If I cruised on the highway with a tail-wind for the entire tank of gas I could hit 21 mpg. That was with upgraded (30 lb/hr) fuel injectors. The gearing on the 4th gens was not much different from the 2010 and the motor is similar, so I'd guess that would be a reasonable expectation for a turbo setup on a 2010, but there are a lot of variables.
And as stated above, if reduced fuel mileage would be a concern for you, you probably should not be looking at forced induction. I can guarantee you that the initial cost will not be the last money you spend on it. Some part will break, it will need retuning, something. Forced induction = $$
2010 Camaro SS in black/beige: Sold. | '91 Camaro RS: Still the dream car!
'98 Camaro SS: Incon twin turbo. Sold | '99 Camaro SS: Heads/cam/bolt-ons. Sold.
O2BQIK is offline   Reply With Quote
Old 04-01-2009, 01:02 PM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I've heard that forced induction tends to help a little bit (under low to moderate boost levels) but encourages more 'spirited' driving so real world economy almost always goes down
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 04-01-2009, 01:05 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
TheBIRDman - Please check your Private Messages.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Official V6 MPG confirmed at 29 MPG hwy! fastball Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 83 03-23-2009 07:45 AM
Let me get this straight....LS3 vs. L99 MPG JMAN311 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 03-18-2009 05:27 PM
Ready or not: 36 MPG by 2015 mandate from Feds Scotsman 5th Gen Camaro SS LS LT General Discussions 76 03-07-2009 03:19 PM
Florida Senator Calls for 50 MPG Mandate In Exchange for bailout DMX General Automotive + Other Cars Discussion 44 11-19-2008 09:31 PM
35 MPG Standard Will Kill the Muscle Car? Uh-Huh. Sure. Mr. Wyndham General Automotive + Other Cars Discussion 6 01-09-2008 02:29 AM
