Old 09-21-2011, 08:51 AM   #29
toilets
Drives: 2010 camaro
Originally Posted by Li0nel1234 View Post
T shirt?
sure thing, LOL
http://www.amazon.com/Autocross-Kill.../dp/B004DS0HWQ
toilets is offline   Reply With Quote
Old 09-21-2011, 08:52 AM   #30
toilets
Drives: 2010 camaro
Once it stops raining, I will take it out and try 12, 6, 10 5 and 10 10 and report back.
Old 09-21-2011, 09:03 AM   #31
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
I have mine set at 12 front and 10 rear for street driving and 23 front and rear for track.
Bruce@raymondsperformance is offline   Reply With Quote
Old 09-27-2011, 09:23 AM   #32
caverman
caverman's Avatar
Drives: '69 SS Convertible
Went to the drag strip this weekend and tried 0F/25R. Now I'm having to deal with learning to launch the car all over again. The process I had before that worked pretty good now causes the tires to smoke.
Of course there are alot of factors here. The track make not have been prepped as good. Could be the coilover settings and/or I've also added cradle bushing inserts as well as rear diff bushings since my last time a the track.
I only got 4 runs in and by my last one I started getting my 60' back down into the low 2.0 area but my times were still slower than the last time I went out. I also realized I wasn't speed shifting like I did last time either.
Next time I think I'm going to try 3F/25R and see if it helps at all. I'm also going to try to pay more attention to the shifting and not let off the throttle once I leave the line.
Hope to make it to an AutoX event at the beginning of Nov as well.
Build Journal
Old 09-27-2011, 12:46 PM   #33
toilets
Drives: 2010 camaro
wouldnt softer be better on the dragstrip in the rear? I have never been so I dont know but I would think the softer setting in the rear would help the car "sit" more...
Old 09-27-2011, 12:52 PM   #34
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
I would try 0 Front and 20 Rear next time. If the track is really hooking and you've got drag radials/slicks then go for 25-30 rear.
Not on an IRS chassis; you get camber and toe change with squat. The idea is to hold the rear camber and toe as close to zero as possible (more contact patch). With the soft front settings you allow the front end to lift which provides the weight transfer.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 09-27-2011, 02:26 PM   #35
caverman
caverman's Avatar
Thanks....
No drag radials though. I'm still on stock tires running 25 psi in the rear and put the fronts at 40 psi.
Guess I might try 0/20 next time.
With only 4 runs I was changing my launch RPM where I guess I should've tried a couple coilover settings.
Build Journal
Old 10-02-2011, 06:01 PM   #36
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
I ran 3 front/20 rear at the track today. Managed a 1.88 60' on the P-Zero's. Could probably do better than that, I was babying it off the line.
Squintz Palladoris is offline   Reply With Quote
Old 10-02-2011, 08:50 PM   #37
caverman
caverman's Avatar
Very Nice!
I would be real happy with that on stock tires. The best I've got was 1.98 but typically I'm in the very low 2.0 60' times. I'll definately give those settings a try next time.
BTW: PM (trying not to side track this thread) what psi you ran in the rear tires. I typically run 25 psi and 40 psi in the front.
Build Journal
Old 10-02-2011, 09:30 PM   #38
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
For street I have it very soft - 10f/8r. Did 1 autox so far and had it at 19f/12r - will go a lot stiffer next time around - but it definitely felt good.
BC Coilovers.
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 10-02-2011, 09:47 PM   #39
Squintz Palladoris
Very Nice!
31 PSI with a nice easy launch. I say "easy" because the car in my Avatar I launched at 6000 rpm and sidestepped the clutch lol. The street tires are tricky. The shocks definately did their job!
Brad
Old 10-03-2011, 02:35 PM   #40
JDP Motorsports
Nice!!!
Old 10-03-2011, 02:55 PM   #41
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
1.88 is dam good on OE tires,
that's a great job!
Info@PeddersUSA.com is offline   Reply With Quote
Old 10-03-2011, 03:26 PM   #42
Squintz Palladoris
Thanks guys!
Pedders Xa Coilovers and Springs | In stock | Free Shipping | Best Prices JDP Motorsports Suspension / Chassis / Brakes 115 02-16-2015 09:42 PM
Remote Reservoir Seperate Bound and Rebound Adjustable 5th Gen Coilovers JusticePete Suspension / Brakes / Chassis 144 12-07-2011 04:50 PM
