JUICEDMOTORSPORTS
Old 09-15-2011, 06:48 PM   #1
carls2010
carls2010's Avatar
Drives: 2010 SS
Angry noise -trans or clutch
I got rid of my 2010 R.S., that had 5,000 miles as i hated the man, trans.-was like driving a 1985 S/10 2WD Pickup/-lol .--currently found a sweet deal on a 2010 SS,with 2,000 miles for 29,000, and i love it.--Only thing now is the noise i hear.-in neut, and let clutch out with windows up there is some what i call throw out bear noise ???, which ive been ignoring, but now the major rattle ?- which i describe as loose exaust clamp type noise, or cat conv insides have come apart.- seems it is more evident if you are on gas lightly like your conserving fuel or driving like a old man.- happens the most when going from 1 to second,-went to dealer today that will agree to look at, and they drove with me and at that time was fine. -- im thinking the rattle is pressure plate, but i thought i ask,, and what is normal amount of noise when you let out clutch in neut, that i here with windows up ?? - goes away when you push clutch in.- does the SS have a commom problem with these
carls2010 is offline   Reply With Quote
Old 09-15-2011, 06:56 PM   #2
Synner
Drives: 2011 2SS/RS M6
Yeah they're noisy trannys; same for the mustangs, vipers, etc that use these trannys. Its tough to type on the internet what "normal" noise is as it varies with each person. I can say I've driven/owned 5 different manuals and none ever had noise like this one at low speeds disengaging. I don't normally get any noise when just cruising very slow in 1st. Only when I depress the clutch.
Get a real loud exhaust then you'll never hear it.
Synner is online now   Reply With Quote
Old 09-15-2011, 07:09 PM   #3
carls2010
carls2010's Avatar
Drives: 2010 SS
loud exaust, was hoping for other answer.- as i heard there was a bulleton from gm on the clutch rattle, but they had have not come up with a fix as of when i read.- i thought i heard the clutch pressure plate and its springs in it were the cause ???-- i think gm knows our issues and fixes but wont amit so as to not having to do warr
Old 09-16-2011, 08:42 AM   #4
Chevrolet Customer Svc
Drives: GM Vehicles
Carl, what you might want to do is to get into contact with our Customer Assistance team so they can help you in working with your dealer. Also you could try suggesting that your dealer check with our Technical Assistance team to see if there's anything in our database that might help with this. If you need help contacting Customer Assistance let me know.
Jeff Morris, Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 09-16-2011, 09:01 AM   #5
carls2010
carls2010's Avatar
Drives: 2010 SS
yes i would like to know how to get in contact with cus. assis.--AS i had problems getting my rs casmaro issue fix so i got rid off it.--- i see now that with my clutch pedal reliesed in neu, it has a noise like imput bearing
Old 09-16-2011, 09:25 AM   #6
Drives: GM Vehicles
Ok, well what you can do is send me your contact information and I can setup the case for you or you can call 1-800-222-1020 and they can get you all setup and call your dealer for you. I hope this helps.
Old 09-16-2011, 09:55 AM   #7
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
This is a very well known issue. There are several threads about the clutch rattle noise. According to GM, this is normal operation, and they will not fix it. That is what my dealer said, as well as several others...
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 09-16-2011, 04:22 PM   #8
carls2010
carls2010's Avatar
Drives: 2010 SS
Hey jeff.m.at cust service.- - i sent you a private message as to your post
Old 09-23-2011, 01:33 PM   #9
carls2010
carls2010's Avatar
Drives: 2010 SS
Hey jeff, from gm customer service..--- look at your private message--
Old 09-23-2011, 04:09 PM   #10
carls2010
carls2010's Avatar
Drives: 2010 SS
Cant believe gm,----Jeff, on here [thanks jeff] put me thru to gm with my issues and i have a case # and a girls name.--But you cant get ahold of this girl ????? -So i called back and the guy pulled up all info, and said Jeff is in total control of my case, and i know that he just relayed my issues and where i am with my car.-- I THEN ASKED THIS GUY then why did nicole give me her exten # to call her and he said , JEFF IS IN CONTOL OF YOUR CASE ?????? -So i then said , who is nicole and his responce was ,she is nicole ??????? -[I guess gm cust serv needs major over haul.]-So i said then i guess i have to email jeff, and that i would tell him that he said that jeff is in COMPLETE CONTROL OF MY case, and his exact answer was , go right ahead ? - Sounded like I DARE YA.--------Getting very pissed off.- So i asked if there was anyone else that could help and all he said was Jeff is handling my case. ?????????? ----------Car has a appointment to get trans tore down but is getting worse and it is not going to make it to the appointment, 3 weeks from now to be torn apart, then wait for parts.--And this is my ransfertation i rely on and need. ----I TRADED IN A 2010 V6 MANU R.S, as i couldnt get my,, no second gear fixed , and got a S.S, - I GUESS I made a mistake getting another camaro
Old 09-23-2011, 04:39 PM   #11
Shu71
Drives: 2011 Camaro RS M6
Dang Carls2010 I can't believe your luck. Were there no noises when you test drove the SS?
Shu71 is offline   Reply With Quote
Old 09-23-2011, 05:01 PM   #12
carls2010
carls2010's Avatar
Drives: 2010 SS
None at all, only took about 300 mile approx and all started and is getting worse.- I PREDICT IT WILL BLOW UP LIKE A GRENADE BEFORE THE DEALER CAN GET IT IN 3 WEEKS. [SORRY FOR CAPS] -- Car Has been babied since it was new, never even saw rain, and me and my wife drive it like were a couple of 60 year olds, lol,, and the trans is fallen apart.- and shifter is so loose i expect it to fall off.-- I THINK GM SHOULD AuTHORIZE a R & R,, under my condition and car only having 4,000 mile.-It's-def poor workman ship issue for sure ON GM.--Where i work, [chrysler] if i bought say a new chalenger right now and i got to 4,000 miles and had this issue it would deff be a R&R ,,as chry wants alot of this stuff back so as to take it apart and find out what went wrong and to correct the issue . for customer satisfaction,,,so as to actually fixing isues and not just having a dealer take apart and replace parts, and never finding out what is causing the issue's in first place..-- guess gm doesnt care about what they need to do to fix the manule tran;s issues except for,, just have a tech, r&r parts.------I myself have worked for V.W, Ford, and now Chrysler [21 years] --and they all would if there was issue with say thier man tran in a certain veh, they would want the tech to R&R, untill they [engineers] found the problem;s and corrected ,then they would let the dealer fix the tran's with the up date of what to do to fix correctly, -not just throw new parts in just like what came out.--After working next to many tech's the worst thing i hated was one that thru parts at a veh one after another, untill he/she got it right.--And thats all gm is doing with our issues
Old 09-24-2011, 11:23 AM   #13
carls2010
carls2010's Avatar
Drives: 2010 SS
Guess i gotta wait to call gm monday.-As i dont think the girl on my case is in on a saturday. ??
Old 09-26-2011, 08:44 AM   #14
Shu71
Well waiting for the dealer may not be the worst thing...if it does in fact grenade then you will probably get a whole new transmission. To me though it sounds like the throwout bearing is howling or the clutch pressure plate is loosening up. Chances are it will get a new throwout bearing and pressure plate and clutch disk. How does it shift? If the transmission shifts fine and this is just in the clutch assembly, then that is all they should replace IMO.
Clunking/clattering noise when pressing clutch - INFO HERE DarkObsession V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 20 12-30-2016 03:06 AM
Just lost faith in this car DarkneSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 70 10-08-2010 02:13 PM
Clutch noise. luisgayoso V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 12 06-23-2010 05:18 PM
Heads Up - Clutch Spring noise ffrcobra_65 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 11-22-2009 09:04 AM
