BeckyD @ James Martin Chevy
View Poll Results: Drive shaft to lower drag times or not?
carbon drive shaft 6 54.55%
aluminum drive shaft 1 9.09%
none, it wont lower the times at all 4 36.36%
Voters: 11. You may not vote on this poll
Old 09-15-2011, 10:39 PM   #1
SilverSS3108
SilverSS3108's Avatar
Drives: 2010 silver SS
Gears & ...???
Just got my 3.73 gears in today!!! Debating on doing a single piece aluminum or carbon driveshaft. Does the drive shaft make any gains in the 1/4 times? What are yalls opinions on them?
2012 Corvette Grandsport... TSP headers, Borla S-Type, BTR Stage 3 N/A cam, Halltech Super Bee MF108
SilverSS3108 is offline   Reply With Quote
Old 09-15-2011, 10:43 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
No the driveshaft will not have any noticable power increase, on the dyno you will get a couple hp but varibles usually obscure it out. People get them more cause they are cool to have
Parag is offline   Reply With Quote
Old 09-15-2011, 10:50 PM   #3
SilverSS3108
I don't care if my car dynos high or not... I'm after lower 1/4 mile times. Dyno #s are just for talkin shit. 1/4 times are where the action is at.
Old 09-15-2011, 11:07 PM   #4
Parag
Well technically the carbon fiber will lower your times, and Aluminum would be slightly better than stock too, just be aware that i dont have these parts on my car, just what people have told me. But to me they are so miniscule the money would better spent else where unless you are running so much power you will break stock
Old 09-15-2011, 11:50 PM   #5
SilverSS3108
My goal is 10.XX NA on stock bottom end with no bottle. With that being said every .1 is going to count.
Old 09-16-2011, 09:22 AM   #6
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
That could not be more true my man Personally I dont know for sure, but a lighter drive shaft and getting rid of the 2 sections should help. Its less rotating mass and less parts to break, I would do it! You will have a lighter and stronger setup so it only makes sence it would be faster, depending on how much lighter will depend on how much faster. Good luck with your goal, its going to take some thought.. my new goal is trying for 11s bolt-ons only now, then low 11s cammed.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 09-16-2011, 09:40 AM   #7
SilverSS3108
Check out TSP on the fast list... I'm gonna base my motor off what they did and take it 2 steps further. 11.174 with
* 2010 Camaro SS L99 A6 (raceweight prob about 3850 to 3900+)
* 6.2L 100% stock shortblock
* TSP/PRC LS7 6-bolt small-bore heads (final prototypes for future release)
* LS7 Rocker arms (for the LS7-derived heads)
* TSP VVT Camshaft 23x/24x
* TSP 1 7/8" Longtubes / Induction
* Yank 4000 Stall Converter
* Stock A6 Transmission
* Stock Gearing
* 100% Stock Suspension, nothing at all aftermarket
* Weld 17" Drag Wheels
* Hoosier Slicks
Old 09-16-2011, 09:48 AM   #8
JETG
Drives: 2011 Camaro SS/RS
I figure for my build, which I am in progress of getting it ready for the track. My car is a M6, and has 504rwhp 445rwtq on the 22's. The next round of stuff will be clutch, axels or 9" which will include the driveshaft. I figure, if I really want to launch this car on dr/slicks I had better replace the driveshaft, clutch, and axels. Why take the chance of breaking something like the driveshaft and have it screw up the bottom of the car ???
JETG is offline   Reply With Quote
Old 09-16-2011, 10:21 AM   #9
SilverSS3108
mines an Automatic though. Breaking isnt a concern as Ive yet to hear of an auto tearing one up. Ive read on DSS's website that it drops 60ft times but Id rather get it from some real life, non biased users. Depending on feedback I should end up with a driveline consisting of a 3600 stall converter, 3.73 gears, JRE posi mod, and maybe the d-shaft. Im kinda squirly about the carbon one though because it seems like I read somewhere that it weakins after prolonged use and due mainly to stress and heat from the exhaust?
Old 09-16-2011, 10:40 AM   #10
Bad70supreme
That is a killer setup they have, I would stick with the 4000 stall though. I personally dont think a 3600 is going to be enough if you want 10s! The biggest concern with these cars is getting all the weight out of the hole, There setup would most likely go 10s with some suspension work seeing that they are stock! I would look to drop a little wieght and mabey even go with MORE convertor like a 4200, add some suspension parts and I think 10s are there.
Old 09-16-2011, 11:44 AM   #11
SilverSS3108
Ya... I'm thinking if they can run 11.1x on that... If I add BMR springs, trailing arms and sways, 3.73 gears, driveshaft, fast intake and 102mm TB, and little weight reduction I should hit 10s just fine. My deal is I don't want to wate money on a shaft if it's not going to help my goal.
Old 09-16-2011, 12:46 PM   #12
Bad70supreme
Well I dont see the shaft being cheap, so I would wait on it if your going to do this in stages! I personally think it would help some, but there allot of work you need to do. I dont know jack about the auto trans, can you use a brake in that thing?
Old 09-16-2011, 12:57 PM   #13
SilverSS3108
I am doing it in stages but not for the typical reasons... I did full bolt-ons... Now I'm doing drive line (converter, gears maybe shaft), then suspension, then maybe I'll have finally made up my mind on my exact eng build Lol
Old 09-18-2011, 12:47 PM   #14
SilverSS3108
BUMP..... results from someone with a single piece aluminum or carbon drive shaft...
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
AAM 3.91 Gears...Very Nice StreetStrip V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 36 06-05-2017 08:44 AM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 11:36 AM
