PFYC
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Sponsor Announcements / Giveaways / Contests
Sponsor Announcements / Giveaways / Contests Announcements, giveaways, and contests from our sponsors
Old 09-15-2011, 11:10 PM   #1
Tampa Tuning
Like us on Facebook!
Tampa Tuning's Avatar
Drives: C5 corvette/ 2012Dodge hemi Charger
The best priced Tuner. Tampa Tuning
Welcome to
www.TampaTuning.com
The Best priced Camaro, Corvette, GTO, Trans Am, GM Silverado, Seirra, Hummer, SSR, Firebird, Caddlac CTS, LSx/ LQx series motors in Tampa. We are the high performance tuner in Tampa.
We specialize in high performance custom computer reprogramming of General Motors powered LS 1 through 9 powered muscle cars and trucks. Our high standard for customer service guarantees you’ll love the performance gains and prices at your spouse can tolerate the fun. Tampa Tuning will design a customized remapping of your vehicle’s computer (PCM) for optimal efficiency. Our tuner has 8 years of tuning experience and has been trained by the basic and advanced tuning school in Odessa Fl, and often return to assist with the class. The home base for operation is about 3 from MacDill Air force Base.
We use the most powerful updated release from HP Tuners software which unleashes the horsepower and torque for an assortment of General Motors vehicles. Our computer enhancements will make your engine run more efficient. Tampa Tuning specializes in the following high performance vehicles and heavy duty trucks for tuning:
  • 1997-2013 Chevrolet Corvette C5 & C6 including ZR1, Grand Sport, Z06s
  • 1998-2013 Chevrolet Camaros Generation 4 and 5 Z28, SS, RS
  • 2002-2013 Cadillac CTS, STS, XLR, SRX, DTS, Escalade
  • 2000-2013 Avalanche, Hummer, Tahoe, Suburban, Yukon, Silverado V8s
  • 1998-2002 Pontiac Firebird, WS6, Trans Am
  • 2003-2004 Chevrolet SSR 5.3
  • 2004-2006 Pontiac GTO
Our total street performance tuning package $280.00
  • Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results
  • Increase power enrichment rate mode
  • Examine and change timing tables for additional horsepower & torque gain
  • Optimize your vehicles Air and Fuel Ratio monitored by the LM-2 wideband unit
  • Measure deivered torque
  • Reduction of intake air temperature table (heat soak)
  • Desired rev limiter adjustments
  • Park, neutral, and in- gear idle adjustments with and without A/C active
  • Adjust power enrichment delay to immediate (*Transmission Performance*)
  • Engine torque management system reduced (*Transmission Performance*)
  • Transmission torque management system reduced (*Transmission Performance*)
  • Transmission shift points enhanced (*Transmission Performance*)
  • Transmission shift times reduced (*Transmission Performance*)
  • Transmission shift pressure firmness enhanced (*Transmission Performance*)
  • Skip shift deleted (CAGs 1st to 4th shift) (*Transmission Performance*)
  • Fuel injector rescaling for aftermarket injectors
  • Check the injector duty cycle
  • Cooling fan activation temperature recalculated
  • Perform speedometer recalibration for rear gear ratio and tire size change
  • Turn off check engine light and remove trouble codes
  • Neutralize rear oxygen sensors
  • Please make sure your vehicle is tuned with 93 octane
  • And has two working cigarette for dual readings
  • The vehicle should be in good working order when it arrives
Transmission performance package
$170.00
Tampa Tuning truly get out the best tranny tune. Tampa Tuning recognizes that the A4 and A6 automatic transmission owners just want their sloppy, slow shifting and sluggish transmissions tuned for a performance feel. For those owners, we designed a transmission only tuning package. We will reduce your vehicles engine and transmission torque management system touch the main spark, and re-flash the transmission settings indicated above by *Transmission performance* notation. This will be a very noticeable change in your vehicles performance! A great bang for the buck!
Torque management reduction tune
$75.00
For the drivers that just want a noticeable change in your vehicles performance, and are tired of the 1st to 4th CAGs skip shift, Tampa Tuning will reduce your vehicle’s engine and transmission torque management system and neutralize your CAGs. You will be surprised and pleased with the torque management tune. Many drivers who use their vehicle daily say just turning off the CAGs are worth the price and the extra seat of the pants torque is a bonus.
Email order tunes
$150.00
If you own or have access to HP Tuners software, you can Email your stock ‘BIN’ file to Tampa Tuning where it will be reviewed and properly enhanced for a “Email order” tune. Your tune will be enhanced by using HP Tuner tables from our library of modified configurations which have a very similar set up as your make and model vehicle. We provide you the best street or dyno tune we have that will work in your vehicle map it to your tables, and send in back within a day. Greatest bang for the buck
Dyno tuning
Forced Induction vehicle start at $500.00 and $120 for dyno time
Heads and Cams and injector start at $350.00 and $120 for dyno time
Street performance package tunes starts at $280.00 and $120 of dyno time
Trucks and vehicles not listed on this page are $100.00 more. www.TampaTuning.com
(We do offer a 10% price discount for active or retired Military or Law Enforcement except on Email tunes)
At Tampa Tuning, We make car fast!
Tampa Tuning is offline   Reply With Quote
Old 09-16-2011, 02:14 PM   #2
JWMotoring
JWMotoring's Avatar
Drives: C5 Corvette
Send a message via Yahoo to JWMotoring
Can't go wrong here guys! Tampa Tuning is legit!
JWMotoring is offline   Reply With Quote
Old 02-08-2012, 07:08 AM   #3
Tampa Tuning
Corvette Camaro GTO Trans Am Truck performance tuner in Tampa
www.TampaTuning.com
street tuning $280.00
Old 04-07-2012, 07:56 AM   #4
Tampa Tuning
Corvette Camaro GTO Trans Am Truck high performance tuner in Tampa
www.TampaTuning.com
We make cars FAST
Originally Posted by Tampa Tuning View Post
Welcome to
www.TampaTuning.com
  • 2000-201 Avalanche, Hummer, Tahoe, Suburban, Yukon, Silverado V8s
$170.00
$75.00
Email order tunes
$150.00
Dyno tuning
Old 04-07-2012, 08:58 AM   #5
SC2150
SC2150's Avatar
Drives: 2001 Camaro SS
And, in over a year we have watched Phil, he has yet to blow up a car......unlike a few of the other fl tuners we show the carnage pics from.
www.RevXtreme.com
941-721-1826
Turbo & Supercharging specialist
VMax porting development from the begining
RX Super Chiller
Old 07-08-2012, 09:10 AM   #6
Tampa Tuning
Tampa Tuning Revs Up Its Staff
July 9, 2012
For Immediate Release
(Tampa, FL) Tampa Tuning is pleased to announce the addition of a tuning master. Ian Thomson, former full-time instructor and research and development analyst for “The Tuning School” and co-writer of the tuning guide for the six speed automatic transmission has joined Tampa Tuning.
Thomson brings a wealth of knowledge to the tuning arena.
He’s spent thousands of hours in the classroom as an instructor and on the dyno tuning cars. Thomson excels in forced induction vehicles and enjoys the challenge of getting the most out of heads and cam packages. His heads and cam C6 Corvette has 540 RWHP with a smooth shifting 6l80 transmission.
Philip Aprea, owner of Tampa Tuning, is thrilled to have Thomson on his team. “He’s one of the best tuners in the country. For those of you who have thanked me for your A6 tuning, you can also thank Ian. He wrote the book on 6l80/90 tuning.”
Tampa Tuning brantley847 USA - Southeast 9 05-29-2011 07:47 AM
Big Thanks to Phil from Tampa Tuning Snake Slayer Local Marketplace 1 05-17-2011 08:35 PM
Big Thanks to Phil from Tampa Tuning Snake Slayer Tuning / Diagnostics -- engine and transmission 0 05-04-2011 08:11 PM
I need a tuner in the Tampa bay area? rpepka USA - Southeast 2 06-16-2009 05:42 AM
