Caryle Racing
Old 09-16-2011, 12:15 AM   #1
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Best priced Tuner in Tampa
Welcome to
www.TampaTuning.com
The Best priced Camaro, Corvette, GTO, Trans Am, GM silverado and seirra Trucks, SSR, Firebird, Caddlac CTS, LSx series motors in Tampa
We specialize in high performance custom computer reprogramming of General Motors powered LS 1 through 9 powered muscle cars and trucks. Our high standard for customer service guarantees you’ll love the performance gains and prices at your spouse can tolerate the fun. Tampa Tuning will design a customized remapping of your vehicle’s computer (PCM) for optimal efficiency. Our tuner has 8 years of tuning experience and has been trained by the basic and advanced tuning school in Odessa Fl, and often return to assist with the class. The home base for operation is about 3 from MacDill Air force Base.
We use the most powerful updated release from HP Tuners software which unleashes the horsepower and torque for an assortment of General Motors vehicles. Our computer enhancements will make your engine run more efficient. Tampa Tuning specializes in the following high performance vehicles and heavy duty trucks for tuning:
  • 1997-2012 Chevrolet Corvette C5 & C6 including ZR1, Grand Sport, Z06s
  • 1998-2012 Chevrolet Camaros Generation 4 and 5 Z28, SS, RS
  • 2002-2012 Cadillac CTS, STS, XLR, SRX, DTS, Escalade
  • 2000-2012 Avalanche, Hummer, Tahoe, Suburban, Yukon, Silverado V8s
  • 1998-2002 Pontiac Firebird, WS6, Trans Am
  • 2003-2004 Chevrolet SSR 5.3
  • 2004-2006 Pontiac GTO
Our total street performance tuning package $280.00
  • Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results
  • Increase power enrichment rate mode
  • Examine and change timing tables for additional horsepower & torque gain
  • Optimize your vehicles Air and Fuel Ratio monitored by the LM-2 wideband unit
  • Measure deivered torque
  • Reduction of intake air temperature table (heat soak)
  • Desired rev limiter adjustments
  • Park, neutral, and in- gear idle adjustments with and without A/C active
  • Adjust power enrichment delay to immediate (*Transmission Performance*)
  • Engine torque management system reduced (*Transmission Performance*)
  • Transmission torque management system reduced (*Transmission Performance*)
  • Transmission shift points enhanced (*Transmission Performance*)
  • Transmission shift times reduced (*Transmission Performance*)
  • Transmission shift pressure firmness enhanced (*Transmission Performance*)
  • Skip shift deleted (CAGs 1st to 4th shift) (*Transmission Performance*)
  • Fuel injector rescaling for aftermarket injectors
  • Check the injector duty cycle
  • Cooling fan activation temperature recalculated
  • Perform speedometer recalibration for rear gear ratio and tire size change
  • Turn off check engine light and remove trouble codes
  • Neutralize rear oxygen sensors
  • Please make sure your vehicle is tuned with 93 octane
  • And has two working cigarette for dual readings
  • The vehicle should be in good working order when it arrives
Transmission performance package
$160.00
Tampa Tuning truly get out the best tranny tune. Tampa Tuning recognizes that the A4 and A6 automatic transmission owners just want their sloppy, slow shifting and sluggish transmissions tuned for a performance feel. For those owners, we designed a transmission only tuning package. We will reduce your vehicles engine and transmission torque management system touch the main spark, and re-flash the transmission settings indicated above by *Transmission performance* notation. This will be a very noticeable change in your vehicles performance! A great bang for the buck!
Torque management reduction tune
$75.00
For the drivers that just want a noticeable change in your vehicles performance, and are tired of the 1st to 4th CAGs skip shift, Tampa Tuning will reduce your vehicle’s engine and transmission torque management system and neutralize your CAGs. You will be surprised and pleased with the torque management tune. Many drivers who use their vehicle daily say just turning off the CAGs are worth the price and the extra seat of the pants torque is a bonus.
Email order tunes
$125.00
If you own or have access to HP Tuners software, you can Email your stock ‘BIN’ file to Tampa Tuning where it will be reviewed and properly enhanced for a “Email order” tune. Your tune will be enhanced by using HP Tuner tables from our library of modified configurations which have a very similar set up as your make and model vehicle. We provide you the best street or dyno tune we have that will work in your vehicle map it to your tables, and send in back within a day of 2. Greatest bang for the buck
Dyno tuning
Forced Induction vehicle start at $500.00 and $200 for dyno rental
Heads and Cams and injector start at $350.00 and $200 for dyno rental
street performance package tunes converted to a Dyno tuning starts at $280.00 and $200 of dyno rental
Trucks and vehicles not listed on this page are $100.00 more.
(All prices are for based on stock or minor bolt on modified vehicles)
(We do offer a 10% price discount for active or retired Military or Law Enforcement except on Email tunes)
Call at 813-727-8720 or you can Email Phil at Tuning@TampaTuning.com
Tampa Tuning is offline   Reply With Quote
tampa dyno tuner
The best priced Tuner. Tampa Tuning Tampa Tuning Sponsor Announcements / Giveaways / Contests 4 04-07-2012 09:58 AM
The best priced tuner in Tampa Tampa Tuning USA - Florida 5 02-08-2012 08:10 AM
Camaro tuner in Tampa. Corvette tuner in Tampa. Firebird tuner in Tampa. Trucks Tampa Tuning Tuning / Diagnostics -- engine and transmission 0 02-24-2011 07:42 AM
Best priced camaro corvette GTO Firebird Trans Am GM Truck tuner Tampa Tuning Tampa Tuning V8 Bolt-Ons & Tunes 1 01-30-2011 06:02 PM
Best priced Camaro Corvette GTO tuner in tampa fan mail Tampa Tuning USA - Southeast 0 01-25-2011 09:24 PM
