JDP Motorsports
Old 09-16-2011, 08:04 AM   #1
Enigma88
Enigma88
Drives: 2011 Camaro SS LS3
High Flow Cats
I have recently installed a cold air intake and an aftermarket cat back exhaust. Now I'm thinking about installing a set of high flow cats, at what point should I start thing about having my ECM tuned?
Enigma88 is offline   Reply With Quote
Old 09-16-2011, 08:49 AM   #2
toilets
Drives: 2010 camaro
Right after. I have the same set up... HF cats, cat back exhaust and a CAI. I now have a 6 degree knock and the car is in desperate need of a tune because of this set up...
BTW, I just dyno'd the car yesterday and with this set up I was at 392 rwhp.
toilets is offline   Reply With Quote
Old 09-16-2011, 09:17 AM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
You don't *need* to tune after the high flow cats. But your check engine light might come on.
Click to view my build thread
Old 09-16-2011, 10:42 AM   #4
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
If you get the right brand of Hi-flow cats you won't get any CEL. Brands such as Solo have engineered their system properly to avoid any CEL. A CAI and high flow cats should not require a tune. Once you start putting on long tube headers, it affects the readings from the o2 sensors too much for the ECU to think that it's in the normal range however. But CAI+HF cats will not throw any codes. The exhaust itself does not matter as there are no sensors behind the o2 sensors connected to the cats.
cab2g is offline   Reply With Quote
Old 09-16-2011, 10:47 AM   #5
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
If I'm not mistaken, there is a old post regarding this. I believe Ted Jannetty says that the high flow cats with a cold air intake could require a tune due to the changes in air flow?
Fishdadddy is offline   Reply With Quote
Old 09-16-2011, 10:54 AM   #6
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
some CAIs require a tune, some cats require a tune. But I can attest that if you buy two brands that do not require a tune, their combined effect will not require a tune.
CAI Inc CAI + Solo HF cats = no tune
Old 09-16-2011, 12:09 PM   #7
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
That is correct. I had to tune because it was running too lean. You should get a scanner and keep an eye on the fuel trims if you add the hi flows.
13 ZL1 is offline   Reply With Quote
Old 09-16-2011, 11:20 PM   #8
Enigma88
Enigma88
So correct me if I'm wrong but it sounds like if I don't get a CEL I might not need a tune? How much does altitude play into it? I live at 5900 feet.
Old 09-17-2011, 01:26 AM   #9
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
It doesn't require a tune but I would recomend one. If you plan on doing some more mods in the near future you might want to wait it out. You should do a tune if you get the cel or not.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 09-17-2011, 08:59 AM   #10
Fishdadddy
Fishdadddy's Avatar
If you are going to tune it anyway. Just skip the High Flow Cats and get Long Tube Headers.
Old 09-17-2011, 09:58 AM   #11
Juiced1
Juiced1's Avatar
Another good idea. Way more power with headers.
Old 09-17-2011, 11:59 AM   #12
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I have the Vararam cai, VMax TB, and SOLO high flow cats without tuning. My LTFTs are great and AFR at WOT is on the rich side.
But if you are going to tune, I agree with the others, go headers.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 09-17-2011, 01:11 PM   #13
13 ZL1
13 ZL1's Avatar
Well that may or may not be true. I didn't expect to need a tune with my mods but I was wrong. You can read about my saga here.
http://www.camaro5.com/forums/showthread.php?t=147113
Old 09-17-2011, 01:30 PM   #14
IndeedSS1
IndeedSS1's Avatar
I remember seeing that thread and your FT's being that far off. That seems like it may have been a rare case. Mine are great without a tune. I should add that if your results are the norm then everyone absolutely needs to scan no matter what the vendor claims about no tuning needed.
High flow cats vs no cats steven32708 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 02-08-2011 07:36 PM
Help regarding high flow cats and headers Rabamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-30-2011 10:20 PM
High flow cats or just removal CamaroCrazy7 USA - Texas 6 12-13-2010 08:21 AM
what high flow cats to buy? dcmock Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 0 11-15-2010 12:45 PM
Kooks 3 inch Axle Back Exhaust and 2.5" High Flow Cats for Sale usmcjlp V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 16 11-01-2010 04:05 PM
