JDP Motorsports
Old 09-16-2011, 11:21 AM   #1
ducq
ducq's Avatar
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM
Subframe bolts
This is gonna sound like I'm not ready to install my bushing inserts..
The bolts that are on the subframe bushings are the ones removed to lower the cradle right? I was under the impression that you need to remove those bolts to pry out the metal washers and then remove 4 additional bolts for lowering the cradle?
TSP 229/236 cam .Magnaflow Comp axleback .KOOKS LT w/ high flow cats .magnapack bullets. C.A.I. Vmax ported TB. Dyno tuned 452hp / 422tq.
ducq is offline   Reply With Quote
Old 09-16-2011, 11:29 AM   #2
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Correct, those 4 bolts hold the subframe on, and hold the metal washers in as well.
Those 4 will do the trick; but don't take out all 4 at the same time unless you have the subframe supported.
JDP Tech is offline   Reply With Quote
Old 09-16-2011, 11:31 AM   #3
ducq
ducq's Avatar
Got it, thanks
Old 09-16-2011, 11:34 AM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
There are only 4 bolts holding up the cradle. You'll need to remove the bolts in order to get the metal washers off.
If you plan to lower the whole cradle at once you'll remove all 4. If you plan to do either a side by side or front to rear install then you would only remove the bolts you need and loosen the others as much as you can.
Ex: I went side to side install. So I installed the driver's side first. I removed both the front and rear bolts on the driver side and then loosened the bolts a bunch on the passenger side. Meanwhile I had a trans jack with a 6x6 chunk of wood under the rear differential. I used that to control how far down the cradle would go. Once I did the drivers side then I put in the bolts on the driver side back in a couple threads and then went to the passenger side, removed the bolts, and did the inserts.
Hopefully that makes sense.
Build Journal
Old 09-16-2011, 01:00 PM   #5
ducq
ducq's Avatar
Yea it makes sense, I think I will try side to side
Old 09-16-2011, 02:11 PM   #6
ducq
ducq's Avatar
So far I got the drivers side washers off, I see what people mean when they say the front washers are a PITA! I know the inserts will only fit in one way but the instructions for the bmr inserts threw me off. They show a picture of the smaller inserts marked as "REAR" and the bigger ones marked as "fRONT".
http://www.bmrsuspension.com/siteart/install/BK016.pdf
Old 09-16-2011, 08:36 PM   #7
ducq
ducq's Avatar
Edit *Oops wrong thread
Old 09-19-2011, 10:04 AM   #8
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
There was an error in the instructions. The bushings were labeled incorrectly in the picture but they have been corrected now.
BMR guy is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 282 05-04-2017 10:18 AM
BMR Subframe Connector Installation How-to BMR guy Suspension / Brakes / Chassis 13 05-06-2011 11:59 PM
Subframe Bush Upgrades. From Simple DIYer to Full Race Capable Info@PeddersUSA.com Suspension / Brakes / Chassis 16 05-03-2010 09:29 PM
New to Suspension (look over list please) Brokenlizrd Suspension / Brakes / Chassis 19 04-23-2010 11:31 PM
