Old 09-16-2011, 05:01 PM   #1
Deeboe
Bowtie, FOR LIFE!!!!
Deeboe's Avatar
Drives: Camaro 2SS/RS SW/IOM Interrior
Flowmaster Muffler question.
I am about to buy some FM 44s i (like the tone and sound) but a salesperson at auto zone told my wife if i have a gfx kit that it matters??? Is this true? I can understand a complete CB but just mufflers? heccck no..just doesnt make sense.
2SS/RS Summit White M6
Current: 2011 SW 2SS/RS M6 Fast!!!
70 Chevelle SS (sold) Still kicking myself!
2010 CGM SS/RS A6 (RIP)
one pissed SS right there!!!!
Deeboe is offline   Reply With Quote
Old 09-16-2011, 05:04 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
can you rephrase, im confused. ground effects kit doesn't affect what muffler to put on. just tip placement
Parag is offline   Reply With Quote
Old 09-16-2011, 05:31 PM   #3
Deeboe
Deeboe's Avatar
does aftermarket mufflers effect ground effects kit...you answered it.. thanks!
Old 09-16-2011, 05:34 PM   #4
SilverSS3108
SilverSS3108's Avatar
Drives: 2010 silver SS
Nope... Won't affect it at all... Just need the correct tips
2012 Corvette Grandsport... TSP headers, Borla S-Type, BTR Stage 3 N/A cam, Halltech Super Bee MF108
SilverSS3108 is offline   Reply With Quote
Old 09-16-2011, 06:08 PM   #5
Deeboe
Deeboe's Avatar
thanks..which inlet and outlet do i buy? center/offset correct? 2 and a 1/2 right? i have stock pipes
Old 09-16-2011, 07:21 PM   #6
doctorgpharmd
Drives: 2011 2SS/RS Silver
The only difference between the gfx kit vs regular is what kind of tips they give you. FM is a good choice, I love my FM AT axle back!
doctorgpharmd is offline   Reply With Quote
Old 09-16-2011, 07:39 PM   #7
SilverSS3108
you got it... and you might even look into the square tips... got to see them in person on BACHs car and they are sexy.
Old 09-17-2011, 01:52 AM   #8
Deeboe
Deeboe's Avatar
http://www.autoanything.com/exhausts...3965A0A0.aspx/
ok thanks. so to be sure its the 3rd one from the top right? the 3rd one and 4th looks the same in/out is the same in size maybe its something i dont know. thanks for the help
Old 09-17-2011, 12:48 PM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You might search for a axleback system that is premade for your car. Typically, they aren't a whole lot more than just the mufflers but come with all the pipes and hangars that are meant for your car. Makes fitment a LOT easier and cleaner looking. It would also save you $$ on the install since the muffler shop will just have labor to charge for. That means no pipes, bending, or anything. Just cut, install, tighten up the clamps. Not sure if they have the tips for the GFX but it wouldn't be anything to cut your OEM ones off and reinstall.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-18-2011, 12:58 AM   #10
mdub76
mdub76's Avatar
Drives: 2010 2ss/RS IOM GFX M6
just get flowmaster cat back for ground xfects. i did simple install.
mdub76 is offline   Reply With Quote
Old 09-21-2011, 01:04 PM   #11
flowmann
Drives: 1972 Camaro Z28
Deeboe – What kind of sound are you looking for? If you’re going to install a set of muffler into your existing pipes you’ll probably need to have a muffler shop make a couple of bends for you. If you want to install a system that’s going to fit right out of the box and install with some simple hand tools at home, you should look at our Axle-Back kits. They will save you money on labor of installation and you’ll get a 409S Stainless Steel system with a Lifetime Warranty.
If you want the same warranty when installing mufflers into your existing pipes, make sure to purchase the Flowmaster mufflers listed as 409S Stainless Steel.
flowmann is offline   Reply With Quote
Old 09-21-2011, 04:33 PM   #12
bucketobolts
bucketobolts's Avatar
Drives: 2010 2SS
Why does the #817495 kit not fit the factory GFX?
bucketobolts is offline   Reply With Quote
Old 09-21-2011, 06:00 PM   #13
Deeboe
Deeboe's Avatar
[QUOTE=flowmann;3782704]Deeboe – What kind of sound are you looking for? If you’re going to install a set of muffler into your existing pipes you’ll probably need to have a muffler shop make a couple of bends for you. If you want to install a system that’s going to fit right out of the box and install with some simple hand tools at home, you should look at our Axle-Back kits. They will save you money on labor of installation and you’ll get a 409S Stainless Steel
i am looking, for a deep strong sound.....
Old 09-22-2011, 04:46 AM   #14
Deeboe
Deeboe's Avatar
what axlebacks does FM have work with GM GFX kit?
Question...Is a muffler delete legal? PnCRedJwl2SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 07-06-2010 09:47 PM
Flowmaster and muffler weep holes Dynabyte Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 9 02-15-2010 04:14 PM
Muffler Delete Question sfgiantsfan9 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 01-23-2010 03:12 PM
LS3 Muffler packing insulation question? faninc Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 12-02-2009 09:37 PM
question about the muffler delete SamSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 11-28-2009 12:22 AM
