Old 09-16-2011, 11:31 PM   #1
honeybucket99
Drives: 2SS/RS CGM CAMARO BEAST
Ehaust Gas Temperature at Muffler?
Anyone know or have a good guess? I am trying to build a band stop filter to kill the 149.2Hz noise that is killing my hearing, and my calculations for length and volume are off due (I think) to the speed of sound in the heated air. If anyone has an educated guess, I'd be much obliged.
2010 CGM 2SS/RS; 418 stroker; JE Forged Pistons (offset wrist pin); Forged Crank; upgraded valvetrain; Custom Comp Cams Cam; Kenne Bell 2.8; ID 1000s; Aeromotive Fuel pump with return; ARH Long Tubes; Spec heavy duty clutch; 3" Magnaflow Cat Back; Nick Williams 102 mm Throttle Body; Tune fixed by Dave Steck; 815 HP and 14 mpg
Upcoming--
Disintegrated drivetrain;
Divorce if/when my wife catches on to
my addiction
honeybucket99 is offline   Reply With Quote
Old 09-19-2011, 01:46 PM   #2
Anthony @ LG Motorsports
Anthony @ LG Motorsports's Avatar
Drives: 1994 1LE / 2006 Z51 Corvette
Remember it's going to change based off of outside air temp, load, throttle position, gear, MPH...
Even at the cylinder head exhaust gas will change 400-1800 degree's.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 09-19-2011, 01:53 PM   #3
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
look up Helmholtz chamber. You can build yourself a bandpass filter (of sorts) that way. Make the chamber the right length to reflect the inverse of the incoming 149Hz wave, you will cancel out most of the sound. No need to build an actual bandpass filter. There are lots of online calculators for this as well because this is commonly done for noise cancellation.
cab2g is offline   Reply With Quote
NAPA locking gas cap for Camaro postman2 5th Gen Camaro SS LS LT General Discussions 25 08-23-2011 06:53 PM
Acronyms at C5 hokie2012 5th Gen Camaro SS LS LT General Discussions 34 08-10-2011 04:56 PM
using higher octane on v6 need4spd 5th Gen Camaro SS LS LT General Discussions 66 06-02-2010 03:24 PM
DIY at home Muffler Delete for $20 CDBiker220 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 10-12-2009 07:32 PM
Muffler Rattle / Baffle / Noise Issue - GM Replaced w/Brand New Muffler Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 10-07-2009 04:07 PM
