Solo Performance
Old 09-17-2011, 02:26 AM   #1
alybudhwani
alybudhwani's Avatar
Drives: 2010 Camaro 2SS Aqua Metallic Blue
Question throttle body, cold air intake, and mass airflow sensor
hey you guys!
okay so im deciding to get more mods for the camaro!
i want to get a FAST big mouth throttle body.
i have a bbk cold air intake installed as of right now.
also, is the jet performance mass airflow sensor compatible with the intake i have? and is it worth it to get?
finally, do i get 92mm or 102mm for the throttle body? do i get it with tips or without? (what are the tips btw? and do they make a difference) and will a tune be required for any of this?
heres the website link
http://JUICEDMOTORSPORTS.COM/2010CAMAROINTAKE.html
thanks for all the help!
http://www.camaro5.com/forums/showthread.php?t=167460
check out my build
seriously though...
alybudhwani is offline   Reply With Quote
Old 09-17-2011, 05:57 AM   #2
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Originally Posted by alybudhwani View Post
hey you guys!
The FAST big mouth throttle body is NOT drive by wire and requires converstion to throttle cable. You might want to exchange your stock TB for a V-Max ported TB. No tune is needed with the V-max. The Jet MAF is probably a waste of money, check your stock MAF and see if it is a strong or weak one. There is a thread on here to tell you how to check. If it is weak, buy a strong one.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 09-17-2011, 10:25 AM   #3
alybudhwani
oh okay. i looked up v-max and it looks legit! and yeah i remember seeing that post about the mass airflow sensors, ill go check it out.
check out my build
seriously though...
Old 09-18-2011, 01:41 AM   #4
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Correct, don't waste your money on an aftermarket mass airflow sensor. If you have the strong one (Letter and numbers) then that is as good as you will ever need.
If its a weak one, you're probably still ok, but depending on your intake, tune, etc, the strong factory one is worth it.
We can get them for you for a fraction of the dealer's price.
The VMax throttle body is an awesome upgrade to your car.
It greatly improves throttle response, and increases horsepower and torque.
The price to power increase ratio is spectacular!
I believe we have one last brand new ported VMax throttle body remaining, and we also have a few used ported VMax's as well.
Give us a call and we'll hook you up!
JDP Tech is offline   Reply With Quote
Old 09-18-2011, 02:32 AM   #5
alybudhwani
cool sounds good! ill give you guys a call tomorrow!!!
thanks!
check out my build
seriously though...
cold air intake, fast, intake manifold, mass airflow sensor, throttle body
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 07:50 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
Acronyms at C5 hokie2012 5th Gen Camaro SS LS LT General Discussions 34 08-10-2011 03:56 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 03:34 PM
