Old 09-17-2011, 10:50 AM   #1
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
Question Side marker light removal
Does any one have any tips on removing the front side marker lights? I would kind of like to get an idea before I get my LED lights in. Thanks
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 09-17-2011, 11:22 AM   #2
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
HAHA good luck... Took me around an hour just to get them out. A lot easier if u jack the car up (and use jack stands of course... that's a no brain-er). You will see bolts holding the plastic onto your bumper. Unscrew those and get that big plastic piece off. Then you have to reach your hand all the way under and around in a U shape to get the lights out. And you have to take the lights out too and its easy after that. I installed black ones on my car. PAIN IN THE ASS.
Animated Gif not allowed
Ant32894 is offline   Reply With Quote
Old 09-21-2011, 04:39 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
here's a pic for reference
I piss excellence
and fart awesomeness
Old 09-21-2011, 04:49 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
for the front ones you just need to unscrew the wheel well liner and then pop it out with your hands. For the rear ones you want to lay down with your head even with the exhaust tips. Then you can reach up with the inside arm and you can reach the side marker, then you just pop it out.
Click to view my build thread
Old 09-21-2011, 04:53 PM   #5
Bulldogwinters
SS #2431
Bulldogwinters's Avatar
Drives: 2001 Pewter Camaro SS
Soo.. I had to replace my front turn signal bulb, and it seemed way too easy. I removed the headlight and the side marker assembly is just right there. I didn't try to remove it, but is it possible just to take it out that way?
2001 SS Lid, LT's, 3" Y to 4" Borla XR-1 dumped, LCA, LCA Brackets, Dbl. Adj. Panhard, Subframe Connectors, Shock Tower Brace, Eibach Prokit, Eddlebrock Shocks, C6 ZR1 Wheels 18x9.5
Bulldogwinters is offline   Reply With Quote
Old 09-21-2011, 04:59 PM   #6
insidethreat07
thats what my dad was thinking too, take the headlight out and go from there
2001 Camaro V6
2016 Camaro 2SS
Old 09-21-2011, 05:01 PM   #7
insidethreat07
all i wanna do is put LED lights in there, so I could just put the lights in just like you said
2001 Camaro V6
2016 Camaro 2SS
Old 10-26-2011, 01:12 PM   #8
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Easiest way to take the blinker/marker light out is to remove the headlight (only 1 or 2 bolts) then its right there, it has 1 screw in the back. It takes some forcing to get it in and out sometimes, but dont bother with the wheel well liner. If you need to change the bulb, you dont even need to take the headlight off, just reach around
Old 10-30-2011, 06:40 PM   #9
davidbecker
Drives: 1998 camaro
i just got black ones as well and got the 7 color changing LED bulbs for them.
davidbecker is offline   Reply With Quote
Old 10-31-2011, 09:51 AM   #10
Evil35th
Drives: 02 35th Aniversary SS/'11 RJT 2SS
there is an access panel on each side under the nose. it takes a 10mm socket to remove the bolts then just reach up in there
02 35TH LE#3089 and 2011 2SS/RS
Evil35th is offline   Reply With Quote
Old 10-31-2011, 10:02 AM   #11
The Stig
The Stig's Avatar
Removing the headlight involves taking the front bumper off. It's not just 1 or 2 bolts
Side Mirror: Upgrade to heated and auto dimming shiftz33 Camaro DIY & HOW-TO instructions & discussions 11 08-01-2016 08:57 AM
2010+ CHEVY CAMARO BUMPER SIDE MARKER LIGHTS - SMOKE 131 SS Exterior Parts & Accessories 9 05-07-2011 10:13 PM
AAC LED Side Marker Lights Stealth 2010 2SS/RS Cosmetics and Lighting Modification Discussions 21 04-20-2011 09:57 PM
THE smoking of the Brake lights and Side marker lights. baranowski Cosmetics and Lighting Modification Discussions 8 05-23-2010 03:06 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 01:49 PM
