Old 09-17-2011, 01:53 PM   #1
oakaro68
oakaro68's Avatar
Drives: 2015 Camaro Z/28
Small metal shavings in engine oil
Hey everyone,
After running 10 runs at the 1/4 mile drag strip last night I checked my oil this morning and found a few very small shiny metal shavings on my dipstick :( I'm wondering if this is a common occurrence or if this is something I should be very concerned about....idk if the shavings were there BEFORE I raced since I didn't bother checking the oil because I just changed it about 500 miles ago or so. I'm using 5w30 mobile 1 and an AC Delco oil filter.
Your thoughts?
oakaro68 is offline   Reply With Quote
Old 09-17-2011, 02:00 PM   #2
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Most likely from bearings, best way to know is to hold off on the track, pull an oil sample send it to a lab and let them determine what's going on.
SamHouseIII is offline   Reply With Quote
Old 09-17-2011, 04:49 PM   #3
MikeOD
Drives: 2010 M6 2SS
Is it a brand new engine? If it is...I'd change the oil immediately and cut the filter open to see what's inside...how is your oil pressure, especially if you change from steady state (say holding 30 mph) to tipping into the throttle to accelerate...does pressure hold or fall?
If it's a new engine, I'd also call the builder ASAP and ask them what you need to do.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 09-17-2011, 05:46 PM   #4
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
I had the same thing on my new SS. I checked the oil at 500 miles and had a bitch of a time pulling the dipstick in and out. Noticed some shaving on the dipstick as well. I am guessing it came from the dipstick tube itself since I could feel it drag as I pulled it out. You would think they could design it better not to be so friggen tight.
bannonm is offline   Reply With Quote
Old 09-17-2011, 11:38 PM   #5
SamHouseIII
I Carry!
Metal shavings in any oil is not good, have it checked out ASAP.
Old 09-18-2011, 08:22 AM   #6
ADM PERFORMANCE
Drives: 2016 CAMARO SS
The metal is generally from the dipstick tube internals.We have seen this for years.
A sure fire way to tell is to save those slivers to a napkin,Drain your oil and remove your filter,If the same slivers are in the filter you may have an issue.
I would put my money on the Internals of the dipstick tube being softer metal than the indicator itself sticking to the tip.
You can also send a 1 quart sample of your oil to blackstone labs and they tell you what is in it.
Good luck
ADM PERFORMANCE is offline   Reply With Quote
Old 09-18-2011, 10:29 AM   #7
bannonm
bannonm's Avatar
Originally Posted by ADM PERFORMANCE View Post
The metal is generally from the dipstick tube internals.We have seen this for years.Good luck
+1. That's exactly what it looks like. And based on how the dipstick feels pulling in and out makes perfect sense. A bit scary at first.
Old 09-19-2011, 08:02 AM   #8
oakaro68
oakaro68's Avatar
Thanks for your suggestions/input everyone. I ordered a Gold Plug yesterday so hopefully it will come in very soon. I'll be draining the oil into a clean containter and fishing around with a magnet to find any other particles as well as cutting the filter open. I'm so close to ordering a Magnuson S/C from Jannetty too! Figures life would throw me a curve ball right before ordering!
Old 09-20-2011, 08:01 AM   #9
oakaro68
oakaro68's Avatar
So I finally drained the oil and combed through it using 5 magnets and didn't find a trace of metal shavings. I also cut the filter open and didn't find anything there either. Sure enough, as ADM Performance hinted, the tip of the dipstick is worn down a bit causing small metal shavings to appear on the dipstick when checking oil. Crappy design! Thanks for the help ADM
Old 09-22-2011, 09:04 PM   #10
rdblan2
Drives: 2SS RS
That likely would have terrified me. Glad it was nothing serious.
rdblan2 is offline   Reply With Quote
A Look at GM's Oil Life Monitoring System franknbeans Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 166 05-23-2014 07:31 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Hawk Performance Brake Pads part HB247Z.575 $85.00 Rogan USA - Florida 2 10-07-2011 01:10 PM
OIL CATCH CANS john468 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 09-16-2010 03:02 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
