Elite Engineering
Old 09-18-2011, 10:44 PM   #1
OuttacontrolAJ
OuttacontrolAJ's Avatar
Drives: 2011 CGM Vert
lowering springs w/grnd efx
Thinking about installing 1" eibach but a little worried about the clearance. Anyone having issues?
OuttacontrolAJ is offline   Reply With Quote
Old 09-18-2011, 11:25 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Are you having issues now? No one can tell you if you'll have issues unless they drive the same roads and go into the same parking lots you do. You have to look at your normal drive and see if there's any places that give you trouble now. We have guys with GFX running drop springs without too much trouble and we have guys that don't have GFX that have trouble.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-18-2011, 11:41 PM   #3
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
I have a set of BMR 1" springs on mine, and no major issues. I don't see you hitting too many scary bumps in CA roads...
Old 09-19-2011, 09:55 AM   #4
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Nice pic Revo1!
BMR guy is offline   Reply With Quote
Old 09-21-2011, 01:56 AM   #5
axis
Search Ninja
axis's Avatar
What about those blocks behind you.
Halltech CF 102 fed
Old 09-21-2011, 04:06 AM   #6
2010SSRSM6
SoCal C5 Family Member
2010SSRSM6's Avatar
As long as you don't pull too far into a parking space with a parking curb, cut too close to a planter box in a parking lot, or take a sharp angle too fast you should be ok. I've got 20k miles on mine since I dropped it with the same springs and haven't had any major issues. Just play nice with the front splitter.
UNDER CONSTRUCTION. ETA 2017 ish...
Old 09-21-2011, 08:51 PM   #7
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
No issues with mine either... just on steep angled driveways. Also, it's a pain in the but to get the floor jack to the front crossmember or even the rear jackpoints now. I have a low pro jack and the saddle is low enough but the jack isn't lengthy enough to reach without touching.
Looks tons better though. Just get some 8x10x2 boards and make a little miny ramp. I just did a two ply set up and it works fine.
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
Old 09-21-2011, 09:21 PM   #8
OuttacontrolAJ
I guess im going to find out cause i dropped off the car today to have them installed.
Old 09-21-2011, 10:10 PM   #9
Li0nel1234
Li0nel1234's Avatar
You'll love it.
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! Apex Motorsports Suspension / Chassis / Brakes 273 04-25-2016 05:17 PM
Pfadt Race Engineering Lowering Springs Improve Looks And Performance. Apex Motorsports Suspension / Chassis / Brakes 341 02-02-2014 11:52 AM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 10:32 AM
