Caryle Racing
Old 09-19-2011, 02:03 PM   #1
cmacclel
Drives: 2010 2SS
L99 Paddle Shift Lag
I searched for the last 30 minutes and can't find anything on the issue I have. When using the paddle shifters and shifting near red line my car has a very noticeable 1/2 second lag before up shifting it's almost like it hits the rev limiter for a 1/2 second and then shifts. Is this normal? In S mode it shifts like a champ
Mac
cmacclel is offline   Reply With Quote
Old 09-19-2011, 03:26 PM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I know I shift at 5500 RPM so I will not bounce off the limit. By the time it does shift I am at 6000 RPM.
Scott@Bjorn3D is offline   Reply With Quote
Old 09-19-2011, 03:31 PM   #3
cam62
Drives: 2012 IBM Vert 2SS/rs
I've learned this trick also !
cam62 is offline   Reply With Quote
Old 09-19-2011, 05:12 PM   #4
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
Unfortunately, what you are experiencing is normal. The tap shifter is not directly wired to the transmission. It goes through the PCM, which accounts for the delay.
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 09-19-2011, 05:45 PM   #5
Kinetic Kev HWSE 2013
Kinetic Kev HWSE 2013's Avatar
Drives: 2013 Hot Wheels Special Edition
yes its not unusual , mine does it from 2nd to 3rd but I am usually shifting at high RPMS its done it from the very first day I have had the car.
Kinetic Kev HWSE 2013 is offline   Reply With Quote
Old 09-21-2011, 09:54 PM   #6
Camaro54
Camaro54's Avatar
Drives: Camaro SS2/RS orange/black stripes
Same here. I just make sure I tap shift around 5500-5700 rpm or I'll hit the rev limiter every time.
2010/2SS/RS/6L80E/Mast built LS3 416 Stroker/Black Lable Heads/Blower Cam/Jannetty Tuned/ 685rwhp/635tq/KookHeaders/3"exhaust/Magnaflows/Whipple Blower/10lbs bst/Duel pumps/85lb inj/2 gauge pillar/CAI/RX catch can/Vmax ported TB/Lexani LX15s/Pedders sub F bushings inserts/Pedders sport extreme coilovers/ZL1 sway bars/Hotchkis strut tower brace/Hawk brake pads/stainless steel brake lines/CTV front calibers/slotted rotors 15"/1 pc drive shaft & loop/hidden radar-laser detect/rear louvers/terminator hood/ SS mats/black outs/Bowties/GM GFX kit/blade spoiler/deading matting/wolf art/
Camaro54 is offline   Reply With Quote
When is a L99 no longer considered a L99 danhr 5th Gen Camaro SS LS LT General Discussions 24 04-05-2011 09:51 PM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
L99 3-4 Shift Wacker Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 10-17-2009 10:22 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
