Gen5DIY
Old 09-19-2011, 03:20 PM   #1
RJT2SSRS
RJT2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS
question for JusticePete.
I have a 2010 2SS/RS that already has the 1400H.P. axles from the Drive Shaft Shop. I would like to install the Supercar coil overs. Is there any interference issue with those axles,coil overs,and a 1" drop at all four corners?
RJT2SSRS is offline   Reply With Quote
Old 09-19-2011, 03:34 PM   #2
600hp-lpe
Drives: 2010
I have that setup... no clearance issues. Everything fits together nicely. I am lowered 1 1/4" or so.
The supercar coilovers have plenty of room to the axles.
There is more room in the front of the car - smaller diameter spring.
600hp-lpe is offline   Reply With Quote
Old 09-19-2011, 09:17 PM   #3
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
as Dan said already,
you will be fine 100%!
Info@PeddersUSA.com is offline   Reply With Quote
Old 09-20-2011, 12:55 AM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Thank you for asking. These other guys stole my answers
Old 09-20-2011, 08:28 PM   #5
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Would you pedders guys say any upgrade on bushings is better than stock? For example diff bushings one is rated at 450 with little noise and the other 450+ with noise. If i dont want noise would it still be good to run the 450 one if i have 556rwhp over stock busing or is it a waste!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 09-20-2011, 10:32 PM   #6
RJT2SSRS
RJT2SSRS's Avatar
Thanks for the quick reply by everybody:-) I will probably have Rodgers Chevrolet do the swap at the end of October.
Old 09-20-2011, 11:18 PM   #7
JusticePete
Interesting question. If we are only talking about doing the differential bushes in the IRS, then the answer would be the overall performance gain would be minimal and could be considered a waste. If we are talking about doing all the bushes in the IRS including the differential bushes it would be a gain.
The EP1167 has holes molded into the bush to control noise while providing much improved control over the OE bushes. The holes or voids do increase the compliance of the 1167 compared to the denser solid material in the EP1167HD. We have a very satisfied group of over 500 RWHP EP1167 clients. They enjoy thier increased RWHP but are not what I would call power users. The hardcore over 500RWHP guys push harder. They are willing to accept an increase in differential noise in exchange for maximum control.
Does this answer your question?
Old 09-21-2011, 09:32 PM   #8
jsharp
jsharp's Avatar
Lol yes and no. Wat would you recommend for me if i want quite? I have 556 now plan 625 tops at rear wheels. What part number? I rarely drive it but demand daily driver mannors
Old 09-21-2011, 09:40 PM   #9
JusticePete
With your headers go with the EP1167HDs
Old 10-19-2011, 10:22 PM   #10
RJT2SSRS
RJT2SSRS's Avatar
Supercar coilovers
Well I finally took the car into Rodgers Chevrolet for the supercar coil over install today. Will post some pic's if the sun ever visits the area again.
I do have a question for JusticePete about how the adjusments should be set for a ride similar to stock Camaro for the winter?
I was wondering if the sway bar settings should be set for a stock like ride
for the winter also.
Old 10-19-2011, 10:36 PM   #11
JusticePete
Becky and Gerry have the secret sauce formula for damping, sway bar and alignment settings in the detroit area
These are my preferred settings regardless of the weather.
Supercar Damper Settings from Full Soft
Front Bound 18
Front Rebound 16
Rear Bound 23
Rear Rebound 16
Rebound is on top. Bound is on the reservoir.
If you find them too tight dial down the rears i.e.
17 Bound and 9 Rebound.
Which sway bar package do you have?
Old 10-20-2011, 11:19 PM   #12
RJT2SSRS
RJT2SSRS's Avatar
The car already has the Pedders solution B sway bar kit,and the bushing insert kit from Pedders both front and back.The rear trailing and toe arms are from BMR
But I didn't know any better starting out on the Camaro upgrade path to really good handling. Next will be 19" wheels and better tires. I guess being a little older I like to have a good foundation before I do any more engine mods.
Old 10-20-2011, 11:27 PM   #13
RJT2SSRS
RJT2SSRS's Avatar
Old 10-20-2011, 11:54 PM   #14
RJT2SSRS
RJT2SSRS's Avatar
I have the Pedders solution B package for the front and rear bars. I also have the Pedders bushing insert package installed front and rear. BMR trailing arms and toerods are installed in the rear of car. Thanks for the advice from JusticePete.
New member, hi! Question about the GFX package... TheDayday New Member Introductions 5 04-24-2011 03:32 PM
stereo question bigted83 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 04-07-2011 05:56 PM
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 08:27 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
