BeckyD@RodgersChevrolet
Old 09-19-2011, 04:55 PM   #1
Demon Hunter
Demon Hunter's Avatar
Drives: 2010 Black Camaro LT
Before/After SS Springs on a V6
Did a search and couldn't find anything. Does anyone have any before and after shots of the FE3 SS suspension installed on a V6. Anything will help.
Demon Hunter is offline   Reply With Quote
Old 09-20-2011, 11:18 AM   #2
Demon Hunter
Nobody??? Really? I know there's people out there that have done it...
Old 11-21-2011, 10:19 PM   #3
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
I'd like to see this as well!
Old 11-21-2011, 11:16 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Won't it look like a stock height SS?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-22-2011, 12:05 AM   #5
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I've got some before shots but haven't taken the after pics yet. I will take them tomorrow and post if someone can give me some "How to post pictures for Dummies" instruction.
My V6 sat higher in back prior to the change, and does look to sit like an SS to me now- level all the way around.
The SS spring is about 1.25 inches shorter than the V6, but is less inclined to compress, resulting in a 3/4 inch drop in my rear suspesion. Front springs looked the same, but the SS strut was about 1/2 inch shorter, resulting in the front sitting down just 1/8 inch.
Measuring from the bottom of the wheel to the highest point on the outside fender lip mine rides right at 27.25 inches on all 4 corners.
The SS endlinks are beefier too, so I got a SS front swaybar (5.9 vs 5.1 for the V6 in stiffness, according to Pfadt) and a Pfadt Balance swaybar for the back.
Haven't had time to shoot those after pics cause I haven't stopped driving...and grinning!
Old 11-22-2011, 10:34 AM   #6
blackswan
blackswan's Avatar
Drives: Yes
Subscribed.
Good stuff.
blackswan is offline   Reply With Quote
Old 11-22-2011, 08:52 PM   #7
Ventmaster
Ventmaster's Avatar
Don't know if this worked- but first pics should be before and then the after:
Old 11-22-2011, 11:00 PM   #8
Mach
Mach's Avatar
Drives: White M6 1LT RS
Just go look at an SS.. That's how a FE3 equipped V6 RS looks.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 11-23-2011, 05:53 PM   #9
Ventmaster
Ventmaster's Avatar
Had to post one slightly more complimentary "after" shot:
Old 11-23-2011, 06:00 PM   #10
JusticePete
Wrote the 5th Gen Book
JusticePete's Avatar
Drives: Camaro Justice
It looks much better. Can you do a driving impression compare contrast, V6 suspension to SS?
Old 11-24-2011, 09:27 AM   #11
Ventmaster
Ventmaster's Avatar
Be happy to sir!
I started susp. upgrades with just a Pfadt Balance swaybar on the back (sorry Pete).
I was shocked at the improvement and looked for the next best upgrade for me. The Pedders book made sense and with Australia's greater development time with the Zeta platform I figured they knew what they were talking about.
I'm not an autocrosser so I went with Pedders rear subframe bush inserts and radius arm inserts- Wow, another big improvement. The rear felt firmer but finally I could "goose" it going around a corner and not feel like I was going to have to correct for a slide as the rear end stepped out- it just went. And the steering sharpened too- first time I "flicked" the wheel to check it out, I damn near drove off the road!
It's hard to stop as you enjoy your car more and more- you can drive more quickly without drawing attention if your car's not all "out of shape ".
Next I was thinking drop springs, but the V6 has had so many strut changes many maker's don't offer them for the car. The common solution is to change to SS struts/shocks and then drop. I guess it was just timing, but several C5 members were having trouble with noise issues and some others voiced harsh ride complaints with their new springs.
So I decided to try SS springs with my new struts. I new they had a higher spring rate than the V6's and thought they might offer the best compromise for me. They did.
Handling is bliss for me now- just firm enuff without getting intrusive. Enough ground clearance that I don't have get tense every time I go up a driveway. The car seems to exceed the sum of its parts. Totally controlled without drama even when my pucker factor is off the charts!
Old 11-24-2011, 11:27 AM   #12
JusticePete
Originally Posted by Ventmaster View Post
Be happy to sir!
Hope you have a great Thanksgiving with your family and friends.
CAMARO WIKI Tran Wiki 55 03-28-2017 12:04 PM
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 370 02-19-2017 02:24 AM
OEM SS Rotors, Lines, Pads, Bowtie Delete, And V6 Brake Set Up Aequitas & Veritas Suspension / Chassis / Brakes 38 09-04-2015 09:50 AM
Any V6 with 300whp? FutureCamaroOwner Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 227 07-09-2011 09:32 PM
SS emblem on a V6 tradosaurus Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 128 11-28-2009 12:16 AM
