JUICEDMOTORSPORTS
4th Generation Camaros 1993-2002
Old 03-31-2009, 06:11 PM   #1
Broshot
Drives: 1999 Camaro Z28
Best method to clean a throttle body on '99 Z
I figure this may be simple, but I wanted to put this out there to the forum and see what you guys think. The dealership wanted to charge me $100 bucks to clean my throttle body, but I heard all I would need is a toothbrush and some throttle body cleaner. Can anyone give me some specifics on how to clean the throttle body?
Broshot is offline   Reply With Quote
Old 03-31-2009, 07:47 PM   #2
robby
Drives: 02 B4C 6M
Toothbrush/T-B cleaner will work.
Small rags saturated w/cleaner work well.
Not knowing your capabilities, cleaning to be done holding throttle plate open.
Also, clean as much of the edge of the throttle blade as possible.
DO NOT spray cleaner into the throttle body. It will migrate into the throttle shaft area and dry out the shaft bearings. It also can migrate into the TPS sensor and short it out.
After cleaning, add a bottle of Chevron w/ Techron fuel injector cleaner to a full tank of fuel. Use the size for 20 gallon treatment.
Do not add fuel till your down at the last 1/4 full on the gauge.
Do the injector cleaner routine twice a year as a maintenence program.
Perform throttle body cleaning every year or 12k miles. It's easier to keep it clean than make it clean.
Good luck,
Rob
robby is offline   Reply With Quote
Old 03-31-2009, 08:12 PM   #3
Broshot
So I am hearing that I should totally remove the throttle body from the car and reinstall it after I clean it. Based on what you are saying, I can do it by disconnecting the intake hose and wipe it down while it is connected, right?
Old 04-01-2009, 10:05 AM   #4
robby
Drives: 02 B4C 6M
As long as you are not spraying into it, on car cleaning is fine.
Rob
Old 04-04-2009, 06:28 PM   #5
7CAMARO7
7CAMARO7's Avatar
Drives: '02SS6spdVert
take it off, take it apart, use throttle body cleaner and a towel=BEST
Spray throttle body cleaner inside of it while still on the car and wipe down with rag=FAST, but still good
7CAMARO7 is offline   Reply With Quote
Old 07-19-2009, 11:50 PM   #6
F55C6
F55C6's Avatar
Drives: 1998 Camaro SS 2005 Corvette
BG
I had the same problem after my throttle stuck open and the engine hit the rev limiter. I used BG Throttle Body cleaner on a cold engine. I was told to make sure the engine was cold because the cleaner would ruin the MAF sensor if the cold fluid hit the MAF wire. I was not told about possibly drying out any bearings. I used an entire can of the spray and wiped the throttle body down. I did this while it was installed on the car. No problems since.
F55C6 is offline   Reply With Quote
F.A.S.T. LSXr Intake and Throttle Body Group Buy...Anybody Interested? ZZcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 03-22-2009 01:03 PM
2010 SMS Mustang TFord General Automotive + Other Cars Discussion 19 01-22-2009 11:00 AM
Hardcore racers rejoice!! GM Performance Parts to offer new Camaro body in white radz28 5th Gen Camaro SS LS LT General Discussions 23 12-22-2008 09:57 AM
Edmunds: Tahoe Hybrid vs. GL320 clean diesel Scotsman General Automotive + Other Cars Discussion 2 12-15-2008 08:13 AM
Throttle Stops and DBW? Xanthos Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 14 12-05-2008 09:52 PM
