SDTW Custom Wheels & Tires
Old 09-20-2011, 04:05 PM   #1
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
3.73 or 3.90 gears for the M6?
I am looking at doing a gear change and looking for suggestions and data from people with the above 2 gear selections. My car info is in my signature. I am trapping 122-123mph right now around 5200-5500 rpm, I would like to get my fourth gear RPMs at the traps up but still have some room to grow later when I up the boost and not have to get into 5th gear.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 09-20-2011, 04:11 PM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I can only recommend LPE 3.91s or Richmond 4.11s due to reliability issues.
I have one of Each all built with Posi mod and billet caps ready to drop in.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 09-20-2011, 06:11 PM   #3
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
Keep your stock gear! You wouldnt put a gear in a diesel would ya? We have held the 6 speed GTO record since 2006 all with a 3.31 gear,maggies like to pull if your close to 5500 your right in the range you need to be.Use that rear gear money and add a little more hp and youll be perfect with alot of room to grow .
Hendrix-Engineering is offline   Reply With Quote
Old 09-20-2011, 06:29 PM   #4
Parag
Drives: 2010 camaro 2SS LS3
YES regear it, i have 4.10's and love them
cant help you at the traps though, look at the sticky thread on gears alot of info there
Parag is offline   Reply With Quote
Old 09-22-2011, 05:31 PM   #5
Turbo99
Turbo99's Avatar
No I wouldn't gear down a diesel but then again it only turns 4500 at best with peak power about 3000-3200rpm.
I see what your saying but I would like to see my car at this point around 5800-5900 at the trap and that gives me 1000 rpm to grow which would be about 10mph and that would put me mid 10s with a M6 and I don't see me doing that until I do a full build and at that put would prolly go to a slush box anyway. All of my slowness of my car is 1st gear since it take alittle ways to get through it, as soon as I am in second the car moves out.
Old 09-23-2011, 08:26 AM   #6
JANNETTYRACING
Your going 123 MPH which is Stellar, but your ET is Really High for that MPH so that means all of your effort has to be focused on the 60 FT.
Maggie cars have explosive bottom end power and you have to put Slicks on the car to make use of that power.
Gearing down will make the car easier to launch and drive it out of the hole because you won't have to use as much clutch.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-23-2011, 12:16 PM   #7
Turbo99
Turbo99's Avatar
Ted.
That is why I am looking to do this. I would love to be able to ease up on my clutch and not to metion able to pull off from a stop w/o having to give alot of pedal.
Old 09-23-2011, 12:20 PM   #8
JANNETTYRACING
I am with you on that.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-23-2011, 12:26 PM   #9
Merc
In The Circle
Merc's Avatar
Ted do you have a stock of LPE 3:91's? I have your posi kit and billet caps and I'm getting ready to pull trigger on the gear set.
Old 09-23-2011, 12:26 PM   #10
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
I think ted is spot on. Get some slicks or atleast some MT dr's those 555r's and 600rwhp 6 speed dont mix very well.
JLE58 is offline   Reply With Quote
Old 09-23-2011, 12:34 PM   #11
JANNETTYRACING
Yes I do.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-23-2011, 09:18 PM   #12
Turbo99
Turbo99's Avatar
My car doesn't spin bad until I leave at 4200+. It actually bogs at anything under 3700.
Old 09-24-2011, 08:39 AM   #13
JANNETTYRACING
That is where the Gear will Help quite a bit.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-24-2011, 09:11 AM   #14
jam3
jam3's Avatar
Drives: 2010 camaro ss
How much gain will you get going from stock 3.45 gears to the 3.91 gears? In the quarter mile?
jam3 is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
3.73 Gears Installed on Manual V-6 Z Madness V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 233 01-12-2012 03:05 PM
Richmond Gears 3.73 4.10 SupremacyCustoms Transmission / Driveline 12 05-20-2010 11:04 PM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 11:36 AM
